[PATCH] [RPI BSP] mailbox
QIAO YANG
yangqiao0505 at me.com
Sun Apr 19 19:17:48 UTC 2015
Here is a modified patch for mailbox. If there's still anything against the convention, please point it out and I'll correct it immediately. The mailbox implementation might also be needed by other rpi bsp developpers.
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index c6133df..70bc01d 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -43,6 +43,7 @@ include_bsp_HEADERS += ../shared/include/arm-release-id.h
include_bsp_HEADERS += include/irq.h
include_bsp_HEADERS += include/mmu.h
include_bsp_HEADERS += include/usart.h
+include_bsp_HEADERS += include/mailbox.h
include_bsp_HEADERS += include/raspberrypi.h
include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
@@ -123,6 +124,9 @@ libbsp_a_SOURCES += misc/timer.c
# I2C
+# Mailbox
+libbsp_a_SOURCES += misc/mailbox.c
# Cache
libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
libbsp_a_SOURCES += ../../../libcpu/arm/shared/include/cache_.h
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h b/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
new file mode 100644
index 0000000..fa6a0c2
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
@@ -0,0 +1,33 @@
+ * @file
+ * @ingroup raspberrypi
+ * @brief mailbox support.
+ * Copyright (c) 2015 Yang Qiao
+ * http://www.rtems.org/license/LICENSE
+#ifndef LIBBSP_ARM_RASPBERRYPI_MAILBOX_H
+#define LIBBSP_ARM_RASPBERRYPI_MAILBOX_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+extern unsigned int raspberrypi_mailbox_read(unsigned int channel);
+extern void raspberrypi_mailbox_write(unsigned int channel, unsigned int data);
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_RASPBERRYPI_MAILBOX_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
index c33e22a..3240404 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
@@ -208,6 +208,55 @@
+ * @name Mailbox Registers
+#define BCM2835_MBOX_BASE (RPI_PERIPHERAL_BASE+0xB880)
+#define BCM2835_MBOX_PEEK (BCM2835_MBOX_BASE+0x10)
+#define BCM2835_MBOX_READ (BCM2835_MBOX_BASE+0x00)
+#define BCM2835_MBOX_WRITE (BCM2835_MBOX_BASE+0x20)
+#define BCM2835_MBOX_STATUS (BCM2835_MBOX_BASE+0x18)
+#define BCM2835_MBOX_SENDER (BCM2835_MBOX_BASE+0x14)
+#define BCM2835_MBOX_CONFIG (BCM2835_MBOX_BASE+0x1C)
+#define BCM2835_MBOX_SUCCESS (BCM2835_MBOX_BASE+0x80000000)
+#define BCM2835_MBOX_FULL (BCM2835_MBOX_BASE+0x80000000)
+#define BCM2835_MBOX_EMPTY (BCM2835_MBOX_BASE+0x40000000)
+* @name Mailbox Channels
+/* Power Manager channel */
+#define BCM2835_MBOX_CHANNEL_PM 0
+/* Framebuffer channel */
+#define BCM2835_MBOX_CHANNEL_FB 1
+ /* Virtual UART channel */
+#define BCM2835_MBOX_CHANNEL_VUART 2
+ /* VCHIQ channel */
+#define BCM2835_MBOX_CHANNEL_VCHIQ 3
+ /* LEDs channel */
+#define BCM2835_MBOX_CHANNEL_LED 4
+ /* Button channel */
+#define BCM2835_MBOX_CHANNEL_BUTTON 5
+ /* Touch screen channel */
+#define BCM2835_MBOX_CHANNEL_TOUCHS 6
+/* Property tags (ARM <-> VC) channel */
+#define BCM2835_MBOX_CHANNEL_PROP_AVC 8
+ /* Property tags (VC <-> ARM) channel */
+#define BCM2835_MBOX_CHANNEL_PROP_VCA 9
diff --git a/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c b/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
index 0000000..2a63a41
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
@@ -0,0 +1,44 @@
+ * @file
+#include <stdint.h>
+#include <bsp/raspberrypi.h>
+#include <bsp/mailbox.h>
+unsigned int raspberrypi_mailbox_read (unsigned int channel)
+ unsigned int data;
+ unsigned int read_channel;
+ while ( 1 )
+ while (BCM2835_REG (BCM2835_MBOX_STATUS ) & BCM2835_MBOX_EMPTY);
+ data = BCM2835_REG (BCM2835_MBOX_READ );
+ read_channel = (unsigned int) (data & 0xF );
+ if (read_channel == channel)
+ return (data & 0xFFFFFFF0);
+void raspberrypi_mailbox_write(unsigned int channel, unsigned int data)
+ while (BCM2835_REG(BCM2835_MBOX_STATUS) & BCM2835_MBOX_FULL);
+ BCM2835_REG(BCM2835_MBOX_WRITE) =
+ (data & 0xFFFFFFF0) |
+ (unsigned int) (channel & 0xF);
diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
index 70259e2..4cb7ed6 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
@@ -126,6 +126,10 @@ $(PROJECT_INCLUDE)/bsp/usart.h: include/usart.h $(PROJECT_INCLUDE)/bsp/$(dirstam
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/usart.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/usart.h
+$(PROJECT_INCLUDE)/bsp/mailbox.h: include/mailbox.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mailbox.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mailbox.h
$(PROJECT_INCLUDE)/bsp/raspberrypi.h: include/raspberrypi.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/raspberrypi.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/raspberrypi.h
On Apr 16, 2015, at 11:20 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Are you working to make the corrections I mentioned?
>>> # I2C
>>> +# Mailbox
>>> # Cache
>>> index 0000000..abdb258
>>> --- /dev/null
>>> @@ -0,0 +1,7 @@
>> Need file header documentation. Please see
>> https://devel.rtems.org/wiki/Developer/Coding/Conventions
>>> +#ifndef MAILBOX_H
>>> +#define MAILBOX_H
>>> +extern unsigned int readmailbox(unsigned int channel);
>>> +extern void writemailbox(unsigned int channel, unsigned int data);
>> Please use function names with a "namespace". the usual convention in
>> RTEMS is to use Package_Class_Method like raspberrypi_mailbox_read()
>> and raspberrypi_mailbox_write().
>>> +#endif /* MAILBOX_H */
>>> \ No newline at end of file
>>> index c33e22a..e4ce18f 100644
>>> @@ -208,6 +208,52 @@
>>> + * NOTE:
>>> +/* Property tags (ARM <-> Video Core) channel */
>>> + /* Property tags (Video Core <-> ARM) channel */
>>> index 0000000..7bfb7e3
>>> --- /dev/null
>>> @@ -0,0 +1,22 @@
>>> +unsigned int readmailbox ( unsigned int channel )
>>> + while ( 1 )
>>> + while ( BCM2835_REG ( BCM2835_MBOX_STATUS ) &
>>> BCM2835_MBOX_EMPTY );
>>> + data = BCM2835_REG ( BCM2835_MBOX_READ );
>>> + read_channel = ( unsigned int ) ( data & 0xF );
>>> + if ( read_channel == channel )
>>> + return ( data & 0xFFFFFFF0 );
>> The white spaces look wrong here. Are they tabs? Or 8 blank spaces?
>> Please check the style rules in the Coding Conventions page.
>>> +void writemailbox( unsigned int channel, unsigned int data )
>>> + while ( BCM2835_REG ( BCM2835_MBOX_STATUS ) & BCM2835_MBOX_FULL );
>>> + BCM2835_REG (BCM2835_MBOX_WRITE) = ( data & 0xFFFFFFF0 ) | (unsigned
>>> int) ( channel & 0xF );
>>> Here is a patch for rpi bsp which include the operation and chanel
>>> defininitions for mailbox and its implementations.
>>> I've only tested the framebuffer with it and it works well : set the screen
>>> size and get the informations.
>>> Andre used it for sd card reading. I've checked it out and added full
>>> channel definitions.
>>> Please point it out if further tests should be done.
>>> YANG QIAO
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150419/31275d13/attachment-0001.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150419/31275d13/attachment-0001.bin>
