[PATCH 1/4] score: _Objects_Get_isr_disable()
Sebastian Huber
Mon Apr 20 13:45:03 UTC 2015
Do not disable thread dispatching and do not acquire the Giant lock.
This makes it possible to use this object get variant for fine grained
locking.
Update #2273.
cpukit/posix/src/mutexlocksupp.c | 6 ++++++
cpukit/rtems/src/semobtain.c | 8 ++++++++
cpukit/score/include/rtems/score/objectimpl.h | 3 ---
cpukit/score/src/objectgetisr.c | 6 ------
4 files changed, 14 insertions(+), 9 deletions(-)
diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
index 3678a0b..92c6556 100644
--- a/cpukit/posix/src/mutexlocksupp.c
+++ b/cpukit/posix/src/mutexlocksupp.c
@@ -54,6 +54,9 @@ int _POSIX_Mutex_Lock_support(
switch ( location ) {
case OBJECTS_LOCAL:
+#if defined(RTEMS_SMP)
+ _Thread_Dispatch_disable();
+#endif
executing = _Thread_Executing;
_CORE_mutex_Seize(
&the_mutex->Mutex,
@@ -63,6 +66,9 @@ int _POSIX_Mutex_Lock_support(
timeout,
&lock_context
+ _Thread_Enable_dispatch();
+#endif
_Objects_Put_for_get_isr_disable( &the_mutex->Object );
return _POSIX_Mutex_Translate_core_mutex_return_code(
(CORE_mutex_Status) executing->Wait.return_code
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index 152274e..0edac96 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -56,6 +56,7 @@ rtems_status_code rtems_semaphore_obtain(
attribute_set = the_semaphore->attribute_set;
wait = !_Options_Is_no_wait( option_set );
+ _Thread_Disable_dispatch();
if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
MRSP_Status mrsp_status;
@@ -66,6 +67,7 @@ rtems_status_code rtems_semaphore_obtain(
wait,
timeout
_Objects_Put_for_get_isr_disable( &the_semaphore->Object );
return _Semaphore_Translate_MRSP_status_code( mrsp_status );
} else
@@ -79,6 +81,9 @@ rtems_status_code rtems_semaphore_obtain(
timeout,
&lock_context
+#endif
return _Semaphore_Translate_core_mutex_return_code(
executing->Wait.return_code );
@@ -93,6 +98,9 @@ rtems_status_code rtems_semaphore_obtain(
timeout,
&lock_context
+#endif
return _Semaphore_Translate_core_semaphore_return_code(
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index a137dea..a96dc20 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -1093,9 +1093,6 @@ RTEMS_INLINE_ROUTINE void _Objects_Put_for_get_isr_disable(
(void) the_object;
-#if defined(RTEMS_SMP)
- _Thread_Enable_dispatch();
-#endif
diff --git a/cpukit/score/src/objectgetisr.c b/cpukit/score/src/objectgetisr.c
index 4feb7aa..b1212ac 100644
--- a/cpukit/score/src/objectgetisr.c
+++ b/cpukit/score/src/objectgetisr.c
@@ -33,18 +33,12 @@ Objects_Control *_Objects_Get_isr_disable(
index = id - information->minimum_id + 1;
if ( information->maximum >= index ) {
- _Thread_Disable_dispatch();
-#endif
_ISR_lock_ISR_disable( lock_context );
if ( (the_object = information->local_table[ index ]) != NULL ) {
*location = OBJECTS_LOCAL;
return the_object;
_ISR_lock_ISR_enable( lock_context );
-#endif
*location = OBJECTS_ERROR;
return NULL;
1.8.4.5
