[PATCH 4/4] score: Delete object control block ISR lock
Mon Apr 20 13:45:06 UTC 2015
The Objects_Control::Lock was a software layer violation.  It worked
only for the threads since they are somewhat special.
Update #2273.
 cpukit/score/Makefile.am                      |  1 -
 cpukit/score/include/rtems/score/object.h     |  3 -
 cpukit/score/include/rtems/score/objectimpl.h | 95 ---------------------------
 cpukit/score/include/rtems/score/thread.h     |  1 +
 cpukit/score/src/objectacquire.c              | 80 ----------------------
 cpukit/score/src/objectclose.c                |  2 -
 6 files changed, 1 insertion(+), 181 deletions(-)
 delete mode 100644 cpukit/score/src/objectacquire.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index b12124c..0a6beb4 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -203,7 +203,6 @@ libscore_a_SOURCES += src/objectallocate.c src/objectclose.c \
     src/objectgetinfo.c src/objectgetinfoid.c src/objectapimaximumclass.c \
     src/objectnamespaceremove.c \
     src/objectactivecount.c
-libscore_a_SOURCES += src/objectacquire.c
 ## SCHEDULER_C_FILES
 libscore_a_SOURCES += src/log2table.c
diff --git a/cpukit/score/include/rtems/score/object.h b/cpukit/score/include/rtems/score/object.h
index 3644943..70e5fe6 100644
--- a/cpukit/score/include/rtems/score/object.h
+++ b/cpukit/score/include/rtems/score/object.h
@@ -23,7 +23,6 @@
 #include <rtems/score/cpu.h>
-#include <rtems/score/isrlock.h>
 #ifdef __cplusplus
 extern "C" {
@@ -237,8 +236,6 @@ typedef struct {
   Objects_Id     id;
   /** This is the object's name. */
   Objects_Name   name;
-  /** This is the object's ISR lock. */
-  ISR_LOCK_MEMBER( Lock )
 } Objects_Control;
 #if defined( RTEMS_MULTIPROCESSING )
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index cf14c2d..4080a24 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -591,98 +591,6 @@ Objects_Control *_Objects_Get_no_protection(
- * @brief Acquires an object by its identifier.
- * This function is similar to _Objects_Get_isr_disable().  It disables
- * interrupts and acquires the object specific ISR lock for local objects.
- * Thread dispatching is not disabled for local objects.  For remote objects
- * thread dispatching is disabled.
- * @param[in] information The object information.
- * @param[in] id The object identifier.
- * @param[in] location The location of the object.
- * @param[in] lock_context The lock context for local objects.
- * @retval object The object corresponding to the identifier.
- * @retval NULL No object exists in this domain for this identifier.
- * @see _Objects_ISR_disable_and_acquire(), _Objects_Release(),
- *   _Objects_Release_and_ISR_enable(), and
- *   _Objects_Release_and_thread_dispatch_disable().
-Objects_Control *_Objects_Acquire(
-  const Objects_Information *information,
-  Objects_Id                 id,
-  Objects_Locations         *location,
-  ISR_lock_Context          *lock_context
- * @brief Acquires a local object and disables interrupts.
- * @param[in] the_object The local object to acquire.
- * @param[in] lock_context The lock context.
-RTEMS_INLINE_ROUTINE void _Objects_ISR_disable_and_acquire(
-  Objects_Control  *the_object,
-  _ISR_lock_ISR_disable_and_acquire( &the_object->Lock, lock_context );
- * @brief Releases a local object.
- * @param[in] the_object The local object acquired by _Objects_Acquire().
- * @param[in] lock_context The lock context initialized by _Objects_Acquire().
-RTEMS_INLINE_ROUTINE void _Objects_Release(
-  _ISR_lock_Release( &the_object->Lock, lock_context );
- * @brief Releases a local object and restores the interrupt level.
-RTEMS_INLINE_ROUTINE void _Objects_Release_and_ISR_enable(
-  _ISR_lock_Release_and_ISR_enable( &the_object->Lock, lock_context );
- * @brief Releases a local object, disables thread dispatching and restores the
- * interrupt level.
- * @return The current processor.
-RTEMS_INLINE_ROUTINE Per_CPU_Control *
-_Objects_Release_and_thread_dispatch_disable(
-  Per_CPU_Control *cpu_self;
-  cpu_self = _Thread_Dispatch_disable_critical();
-  _Objects_Release_and_ISR_enable( the_object, lock_context );
-  return cpu_self;
  *  Like @ref _Objects_Get, but is used to find "next" open object.
  *  @param[in] information points to an object class information block.
@@ -995,7 +903,6 @@ RTEMS_INLINE_ROUTINE void _Objects_Open(
   _Assert( the_object != NULL );
   the_object->name = name;
-  _ISR_lock_Initialize( &the_object->Lock, "Object" );
   _Objects_Set_local_object(
     information,
@@ -1020,7 +927,6 @@ RTEMS_INLINE_ROUTINE void _Objects_Open_u32(
   /* ASSERT: information->is_string == false */
   the_object->name.name_u32 = name;
     information,
@@ -1047,7 +953,6 @@ RTEMS_INLINE_ROUTINE void _Objects_Open_string(
     /* ASSERT: information->is_string */
     the_object->name.name_p = name;
   #endif
     information,
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index ef238a3..bc521bb 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -26,6 +26,7 @@
 #if defined(RTEMS_MULTIPROCESSING)
 #include <rtems/score/mppkt.h>
 #endif
+#include <rtems/score/isrlock.h>
 #include <rtems/score/priority.h>
diff --git a/cpukit/score/src/objectacquire.c b/cpukit/score/src/objectacquire.c
deleted file mode 100644
index 57d38f4..0000000
--- a/cpukit/score/src/objectacquire.c
+++ /dev/null
@@ -1,80 +0,0 @@
- * @file
- * @brief Object Acquire
- * @ingroup ScoreObject
- * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-  #include "config.h"
-#endif
-#include <rtems/score/objectimpl.h>
-  Objects_Id                 id,
-  Objects_Control *the_object;
-  uint32_t         index;
-  index = id - information->minimum_id + 1;
-  if ( information->maximum >= index ) {
-     * On uni-processor configurations we disable interrupts before we use the
-     * local table.  This prevents use of freed memory in case the object
-     * information is extended in between.  On SMP configurations bad things
-     * can happen, see https://devel.rtems.org/ticket/2280.
-#if !defined(RTEMS_SMP)
-    ISR_Level level;
-    _ISR_Disable( level );
-#endif
-    if ( ( the_object = information->local_table[ index ] ) != NULL ) {
-      *location = OBJECTS_LOCAL;
-#if defined(RTEMS_SMP)
-#else
-      lock_context->isr_level = level;
-#endif
-      return the_object;
-    _ISR_Enable( level );
-#endif
-    *location = OBJECTS_ERROR;
-    return NULL;
-#if defined(RTEMS_MULTIPROCESSING)
-  _Objects_MP_Is_remote( information, id, location, &the_object );
-#else
-  return NULL;
-#endif
diff --git a/cpukit/score/src/objectclose.c b/cpukit/score/src/objectclose.c
index 25c7aa1..52eb10c 100644
--- a/cpukit/score/src/objectclose.c
+++ b/cpukit/score/src/objectclose.c
@@ -28,6 +28,4 @@ void _Objects_Close(
   _Objects_Invalidate_Id( information, the_object );
   _Objects_Namespace_remove( information, the_object );
-  _ISR_lock_Destroy( &the_object->Lock );
1.8.4.5
