[PATCH] score: Fix priority message queue insert
Tue Apr 21 07:24:13 UTC 2015
Move the linear search into a critical section to avoid corruption due
to higher priority interrupts.  The interrupt disable time depends now
on the count of pending messages.
Close #2328.
 cpukit/score/include/rtems/score/coremsgimpl.h |  32 +------
 cpukit/score/src/coremsginsert.c               | 113 +++++++++++--------------
 2 files changed, 50 insertions(+), 95 deletions(-)
diff --git a/cpukit/score/include/rtems/score/coremsgimpl.h b/cpukit/score/include/rtems/score/coremsgimpl.h
index 52796ad..cedf276 100644
--- a/cpukit/score/include/rtems/score/coremsgimpl.h
+++ b/cpukit/score/include/rtems/score/coremsgimpl.h
@@ -443,7 +443,7 @@ RTEMS_INLINE_ROUTINE void _CORE_message_queue_Free_message_buffer (
  *       disabled if no API requires it.
 RTEMS_INLINE_ROUTINE int _CORE_message_queue_Get_message_priority (
-  CORE_message_queue_Buffer_control *the_message
+  const CORE_message_queue_Buffer_control *the_message
   #if defined(RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY)
@@ -494,36 +494,6 @@ RTEMS_INLINE_ROUTINE bool _CORE_message_queue_Is_priority(
     (the_attribute->discipline == CORE_MESSAGE_QUEUE_DISCIPLINES_PRIORITY);
- * This routine places the_message at the rear of the outstanding
- * messages on the_message_queue.
-RTEMS_INLINE_ROUTINE void _CORE_message_queue_Append_unprotected (
-  CORE_message_queue_Control        *the_message_queue,
-  _Chain_Append_unprotected(
-    &the_message_queue->Pending_messages,
-    &the_message->Node
- * This routine places the_message at the front of the outstanding
-RTEMS_INLINE_ROUTINE void _CORE_message_queue_Prepend_unprotected (
-  _Chain_Prepend_unprotected(
 #if defined(RTEMS_SCORE_COREMSG_ENABLE_NOTIFICATION)
    * This function returns true if notification is enabled on this message
diff --git a/cpukit/score/src/coremsginsert.c b/cpukit/score/src/coremsginsert.c
index 2e42349..35ec954 100644
--- a/cpukit/score/src/coremsginsert.c
+++ b/cpukit/score/src/coremsginsert.c
@@ -18,12 +18,25 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
-#include <rtems/score/chain.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/wkspace.h>
+#include <rtems/score/isrlevel.h>
+#if defined(RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY)
+static bool _CORE_message_queue_Order(
+  const Chain_Node *left,
+  const Chain_Node *right
+   const CORE_message_queue_Buffer_control *left_message;
+   const CORE_message_queue_Buffer_control *right_message;
+   left_message = (const CORE_message_queue_Buffer_control *) left;
+   right_message = (const CORE_message_queue_Buffer_control *) right;
+   return _CORE_message_queue_Get_message_priority( left_message ) <
+     _CORE_message_queue_Get_message_priority( right_message );
+#endif
 void _CORE_message_queue_Insert_message(
@@ -31,71 +44,43 @@ void _CORE_message_queue_Insert_message(
   CORE_message_queue_Submit_types    submit_type
-  ISR_Level  level;
-  #if defined(RTEMS_SCORE_COREMSG_ENABLE_NOTIFICATION)
-    bool    notify = false;
-    #define SET_NOTIFY() \
-      do { \
-        if ( the_message_queue->number_of_pending_messages == 0 ) \
-          notify = true; \
-      } while (0)
-  #else
-  #endif
+  Chain_Control *pending_messages;
+  ISR_Level      level;
+#if defined(RTEMS_SCORE_COREMSG_ENABLE_NOTIFICATION)
+  bool           notify;
+#endif
   _CORE_message_queue_Set_message_priority( the_message, submit_type );
+  pending_messages = &the_message_queue->Pending_messages;
-  #if !defined(RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY)
-    _ISR_Disable( level );
-      SET_NOTIFY();
-      the_message_queue->number_of_pending_messages++;
-      if ( submit_type == CORE_MESSAGE_QUEUE_SEND_REQUEST )
-        _CORE_message_queue_Append_unprotected(the_message_queue, the_message);
-      else
-        _CORE_message_queue_Prepend_unprotected(the_message_queue, the_message);
-    _ISR_Enable( level );
-  #else
-    if ( submit_type == CORE_MESSAGE_QUEUE_SEND_REQUEST ) {
-        SET_NOTIFY();
-    } else if ( submit_type == CORE_MESSAGE_QUEUE_URGENT_REQUEST ) {
-        SET_NOTIFY();
-    } else {
-      CORE_message_queue_Buffer_control *this_message;
-      Chain_Node                        *the_node;
-      Chain_Control                     *the_header;
-      int                                the_priority;
-      the_priority = _CORE_message_queue_Get_message_priority(the_message);
-      the_header = &the_message_queue->Pending_messages;
-      the_node = _Chain_First( the_header );
-      while ( !_Chain_Is_tail( the_header, the_node ) ) {
-        int this_priority;
+  _ISR_Disable( level );
-        this_message = (CORE_message_queue_Buffer_control *) the_node;
+  notify = the_message_queue->number_of_pending_messages == 0;
+#endif
+  ++the_message_queue->number_of_pending_messages;
-        this_priority = _CORE_message_queue_Get_message_priority(this_message);
+  switch ( submit_type ) {
+    case CORE_MESSAGE_QUEUE_SEND_REQUEST:
+      _Chain_Append_unprotected( pending_messages, &the_message->Node );
+      break;
+    default:
+      _Chain_Insert_ordered_unprotected(
+        pending_messages,
+        &the_message->Node,
+        _CORE_message_queue_Order
+      break;
+#else
+      /* Fall through */
+#endif
+    case CORE_MESSAGE_QUEUE_URGENT_REQUEST:
+      _Chain_Prepend_unprotected( pending_messages, &the_message->Node );
+      break;
-        if ( this_priority <= the_priority ) {
-          the_node = the_node->next;
-          continue;
-        break;
-        SET_NOTIFY();
-        _Chain_Insert_unprotected( the_node->previous, &the_message->Node );
-  #endif
+  _ISR_Enable( level );
1.8.4.5
