[PATCH] score: Fix priority message queue insert
Tue Apr 21 16:13:18 UTC 2015
On 4/21/2015 2:24 AM, Sebastian Huber wrote:
> Move the linear search into a critical section to avoid corruption due
> to higher priority interrupts.  The interrupt disable time depends now
> on the count of pending messages.
> Close #2328.
>  cpukit/score/include/rtems/score/coremsgimpl.h |  32 +------
>  cpukit/score/src/coremsginsert.c               | 113 +++++++++++--------------
>  2 files changed, 50 insertions(+), 95 deletions(-)
> diff --git a/cpukit/score/include/rtems/score/coremsgimpl.h b/cpukit/score/include/rtems/score/coremsgimpl.h
> index 52796ad..cedf276 100644
> --- a/cpukit/score/include/rtems/score/coremsgimpl.h
> +++ b/cpukit/score/include/rtems/score/coremsgimpl.h
> @@ -443,7 +443,7 @@ RTEMS_INLINE_ROUTINE void _CORE_message_queue_Free_message_buffer (
>   *       disabled if no API requires it.
>  RTEMS_INLINE_ROUTINE int _CORE_message_queue_Get_message_priority (
> -  CORE_message_queue_Buffer_control *the_message
> +  const CORE_message_queue_Buffer_control *the_message
>    #if defined(RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY)
> @@ -494,36 +494,6 @@ RTEMS_INLINE_ROUTINE bool _CORE_message_queue_Is_priority(
>      (the_attribute->discipline == CORE_MESSAGE_QUEUE_DISCIPLINES_PRIORITY);
> - * This routine places the_message at the rear of the outstanding
> - * messages on the_message_queue.
> -RTEMS_INLINE_ROUTINE void _CORE_message_queue_Append_unprotected (
> -  CORE_message_queue_Control        *the_message_queue,
> -  _Chain_Append_unprotected(
> -    &the_message_queue->Pending_messages,
> -    &the_message->Node
> - * This routine places the_message at the front of the outstanding
> -RTEMS_INLINE_ROUTINE void _CORE_message_queue_Prepend_unprotected (
> -  _Chain_Prepend_unprotected(
>  #if defined(RTEMS_SCORE_COREMSG_ENABLE_NOTIFICATION)
>     * This function returns true if notification is enabled on this message
> diff --git a/cpukit/score/src/coremsginsert.c b/cpukit/score/src/coremsginsert.c
> index 2e42349..35ec954 100644
> --- a/cpukit/score/src/coremsginsert.c
> +++ b/cpukit/score/src/coremsginsert.c
> @@ -18,12 +18,25 @@
>  #include "config.h"
>  #endif
> -#include <rtems/system.h>
> -#include <rtems/score/chain.h>
> -#include <rtems/score/isr.h>
>  #include <rtems/score/coremsgimpl.h>
> -#include <rtems/score/thread.h>
> -#include <rtems/score/wkspace.h>
> +#include <rtems/score/isrlevel.h>
> +#if defined(RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY)
> +static bool _CORE_message_queue_Order(
> +  const Chain_Node *left,
> +  const Chain_Node *right
> +   const CORE_message_queue_Buffer_control *left_message;
> +   const CORE_message_queue_Buffer_control *right_message;
> +   left_message = (const CORE_message_queue_Buffer_control *) left;
> +   right_message = (const CORE_message_queue_Buffer_control *) right;
> +   return _CORE_message_queue_Get_message_priority( left_message ) <
> +     _CORE_message_queue_Get_message_priority( right_message );
> +#endif
>  void _CORE_message_queue_Insert_message(
> @@ -31,71 +44,43 @@ void _CORE_message_queue_Insert_message(
>    CORE_message_queue_Submit_types    submit_type
> -  ISR_Level  level;
> -  #if defined(RTEMS_SCORE_COREMSG_ENABLE_NOTIFICATION)
> -    bool    notify = false;
> -    #define SET_NOTIFY() \
> -      do { \
> -        if ( the_message_queue->number_of_pending_messages == 0 ) \
> -          notify = true; \
> -      } while (0)
> -  #else
> -  #endif
> +  Chain_Control *pending_messages;
> +  ISR_Level      level;
> +#if defined(RTEMS_SCORE_COREMSG_ENABLE_NOTIFICATION)
> +  bool           notify;
> +#endif
>    _CORE_message_queue_Set_message_priority( the_message, submit_type );
> +  pending_messages = &the_message_queue->Pending_messages;
> -  #if !defined(RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY)
> -    _ISR_Disable( level );
> -      SET_NOTIFY();
> -      the_message_queue->number_of_pending_messages++;
> -      if ( submit_type == CORE_MESSAGE_QUEUE_SEND_REQUEST )
> -        _CORE_message_queue_Append_unprotected(the_message_queue, the_message);
> -      else
> -        _CORE_message_queue_Prepend_unprotected(the_message_queue, the_message);
> -    _ISR_Enable( level );
> -  #else
> -    if ( submit_type == CORE_MESSAGE_QUEUE_SEND_REQUEST ) {
> -        SET_NOTIFY();
> -    } else if ( submit_type == CORE_MESSAGE_QUEUE_URGENT_REQUEST ) {
> -        SET_NOTIFY();
> -    } else {
> -      CORE_message_queue_Buffer_control *this_message;
> -      Chain_Node                        *the_node;
> -      Chain_Control                     *the_header;
> -      int                                the_priority;
> -      the_priority = _CORE_message_queue_Get_message_priority(the_message);
> -      the_header = &the_message_queue->Pending_messages;
> -      the_node = _Chain_First( the_header );
> -      while ( !_Chain_Is_tail( the_header, the_node ) ) {
> -        int this_priority;
> +  _ISR_Disable( level );
> -        this_message = (CORE_message_queue_Buffer_control *) the_node;
> +  notify = the_message_queue->number_of_pending_messages == 0;
> +#endif
Add parentheses around expression to make it clear that is the intent.
> +  ++the_message_queue->number_of_pending_messages;
> -        this_priority = _CORE_message_queue_Get_message_priority(this_message);
> +  switch ( submit_type ) {
> +    case CORE_MESSAGE_QUEUE_SEND_REQUEST:
> +      _Chain_Append_unprotected( pending_messages, &the_message->Node );
> +      break;
> +    default:
> +      _Chain_Insert_ordered_unprotected(
> +        pending_messages,
> +        &the_message->Node,
> +        _CORE_message_queue_Order
> +      break;
> +#else
> +      /* Fall through */
> +#endif
> +    case CORE_MESSAGE_QUEUE_URGENT_REQUEST:
> +      _Chain_Prepend_unprotected( pending_messages, &the_message->Node );
> +      break;
I know we should never hit the default but would it make more sense to fall
into a normal append with possibly a debug assert before it?
Or was this done to put the common case first with no interference so
it would most like be in the cache?
If so, put a comment above the switch explaining that the order is not
random and explain it.
> -        if ( this_priority <= the_priority ) {
> -          the_node = the_node->next;
> -          continue;
> -        break;
> -        SET_NOTIFY();
> -        _Chain_Insert_unprotected( the_node->previous, &the_message->Node );
> -  #endif
> +  _ISR_Enable( level );
