[PATCH] score: Fix priority message queue insert
Wed Apr 22 14:05:21 UTC 2015
Joel,
On Tue, Apr 21, 2015 at 12:13 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 4/21/2015 2:24 AM, Sebastian Huber wrote:
>> Move the linear search into a critical section to avoid corruption due
>> to higher priority interrupts.  The interrupt disable time depends now
>> on the count of pending messages.
>> Close #2328.
>>  cpukit/score/include/rtems/score/coremsgimpl.h |  32 +------
>>  cpukit/score/src/coremsginsert.c               | 113 +++++++++++--------------
>>  2 files changed, 50 insertions(+), 95 deletions(-)
>> +#if defined(RTEMS_SCORE_COREMSG_ENABLE_NOTIFICATION)
>> +  notify = the_message_queue->number_of_pending_messages == 0;
>> +#endif
> Add parentheses around expression to make it clear that is the intent.
Our coding conventions say to avoid unnecessary parens. If you'd like
to make some adjustment to the conventions please start a separate
thread.
Gedare
