[PATCH 10/10] sp13/system.h: Account for all message buffers
Wed Apr 22 14:13:06 UTC 2015
There may be a way to reduce the memory requirements but it
will require time to ensure the math is right and it passes
on all targets. At the current time, it fails on 22 BSPs which
run on simulators.
 testsuites/sptests/sp13/system.h | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/testsuites/sptests/sp13/system.h b/testsuites/sptests/sp13/system.h
index f879096..20ecc2f 100644
--- a/testsuites/sptests/sp13/system.h
+++ b/testsuites/sptests/sp13/system.h
@@ -90,10 +90,10 @@ TEST_EXTERN rtems_name Queue_name[ 4 ];      /* array of queue names */
 #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
    /* Q1 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
-   /* Q2 */ /* CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE ) + */ \
+   /* Q2 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE ) + \
    /* Q3 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
    /* Q1 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, 20 ) + \
-   /* Q1 */ /* CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 2,  1030 ) */
+   /* Q1 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 2,  1030 )
 #define CONFIGURE_EXTRA_TASK_STACKS         (3 * RTEMS_MINIMUM_STACK_SIZE)
1.9.3
