RTEMS Fault Tolerance Project for SOCIS 2015
Wed Apr 22 18:33:56 UTC 2015
On Wed, Apr 22, 2015 at 2:15 PM, Saeed Ehteshamifar
<salpha.2004 at gmail.com> wrote:
> Hi,
> I'm interested to take part in development of RTEMS via fault tolerance
> project. I've read the wiki page for the project, the page for open
> projects, and the page for GSoC and GSoC getting started. I've also skimmed
> RTEMS 4.5.0 evaluation report.
Make sure you complete the hello world requirements.
> I also have the experience of using RTEMS for 14 months as part of a
> research team during 05.12 - 07.13.
> My idea is to apply an extended tool based on CMU's Ballista to generate
> test cases for injecting faults (RTEMS C programs). However I've 2 basic
> questions:
> 1. What is the scope of this SOCIS project? Should it include all the scopes
> as written in the evaluation report (i.e. RTEMS Executive Core, RTEMS
> Classic API, POSIX, Robustness, and Stress Testing)? Or it could be narrowed
> down?
You should narrow it down to be feasible during the program duration (3 months?)
> 2. Of course source codes, documentation, and the tests output should be
> included in the final result but what about an analysis on tests output?
> should that be included as well?
Analysis or better yet tools for analysis would be useful.
> Thanks in advance, for your time and attention.
> Kind Regards,
> SAeeD
> devel mailing list
> devel at rtems.org
