[PATCH] score: Delete Thread_queue_Control::state
Sebastian Huber
Wed Apr 22 19:34:08 UTC 2015
Use a parameter for _Thread_queue_Enqueue() instead to reduce memory
usage.
cpukit/libfs/src/pipe/fifo.c | 25 -------------------------
cpukit/posix/src/condinit.c | 1 -
cpukit/posix/src/condwaitsupp.c | 9 ++++++++-
cpukit/posix/src/psignal.c | 2 --
cpukit/posix/src/pthread.c | 1 -
cpukit/posix/src/pthreadjoin.c | 2 ++
cpukit/posix/src/sigtimedwait.c | 7 ++++++-
cpukit/rtems/src/regioncreate.c | 2 --
cpukit/rtems/src/regiongetsegment.c | 2 ++
cpukit/score/include/rtems/score/threadq.h | 4 ----
cpukit/score/include/rtems/score/threadqimpl.h | 4 ++--
cpukit/score/src/corebarrier.c | 2 --
cpukit/score/src/corebarrierwait.c | 8 +++++++-
cpukit/score/src/coremsg.c | 2 --
cpukit/score/src/coremsgseize.c | 8 +++++++-
cpukit/score/src/coremsgsubmit.c | 2 ++
cpukit/score/src/coremutex.c | 1 -
cpukit/score/src/coremutexseize.c | 8 +++++++-
cpukit/score/src/corerwlock.c | 2 --
cpukit/score/src/corerwlockobtainread.c | 2 ++
cpukit/score/src/corerwlockobtainwrite.c | 2 ++
cpukit/score/src/coresem.c | 2 --
cpukit/score/src/coresemseize.c | 7 ++++++-
cpukit/score/src/threadq.c | 2 --
cpukit/score/src/threadqenqueue.c | 5 +++--
25 files changed, 56 insertions(+), 56 deletions(-)
diff --git a/cpukit/libfs/src/pipe/fifo.c b/cpukit/libfs/src/pipe/fifo.c
index 91d95dc..76550dd 100644
--- a/cpukit/libfs/src/pipe/fifo.c
+++ b/cpukit/libfs/src/pipe/fifo.c
@@ -61,27 +61,6 @@ static rtems_id pipe_semaphore = RTEMS_ID_NONE;
#define PIPE_WAKEUPWRITERS(_pipe) \
do {uint32_t n; rtems_barrier_release(_pipe->writeBarrier, &n); } while(0)
-#ifdef RTEMS_POSIX_API
-#include <rtems/rtems/barrier.h>
-#include <rtems/score/thread.h>
-/* Set barriers to be interruptible by signals. */
-static void pipe_interruptible(pipe_control_t *pipe)
- Objects_Locations location;
- Barrier_Control *the_barrier;
- the_barrier = _Barrier_Get(pipe->readBarrier, &location);
- the_barrier->Barrier.Wait_queue.state |= STATES_INTERRUPTIBLE_BY_SIGNAL;
- _Objects_Put( &the_barrier->Object );
- the_barrier = _Barrier_Get(pipe->writeBarrier, &location);
-#endif
* Alloc pipe control structure, buffer, and resources.
* Called with pipe_semaphore held.
@@ -122,10 +101,6 @@ static int pipe_alloc(
RTEMS_NO_PRIORITY, &pipe->Semaphore) != RTEMS_SUCCESSFUL)
goto err_sem;
- pipe_interruptible(pipe);
-#endif
*pipep = pipe;
if (c ++ == 'z')
c = 'a';
diff --git a/cpukit/posix/src/condinit.c b/cpukit/posix/src/condinit.c
index 81575f2..c1c14b8 100644
--- a/cpukit/posix/src/condinit.c
+++ b/cpukit/posix/src/condinit.c
@@ -65,7 +65,6 @@ int pthread_cond_init(
_Thread_queue_Initialize(
&the_cond->Wait_queue,
THREAD_QUEUE_DISCIPLINE_FIFO,
- STATES_WAITING_FOR_CONDITION_VARIABLE | STATES_INTERRUPTIBLE_BY_SIGNAL,
ETIMEDOUT
diff --git a/cpukit/posix/src/condwaitsupp.c b/cpukit/posix/src/condwaitsupp.c
index 2a0b57f..1abdc42 100644
--- a/cpukit/posix/src/condwaitsupp.c
+++ b/cpukit/posix/src/condwaitsupp.c
@@ -23,6 +23,7 @@
+#include <rtems/score/statesimpl.h>
#include <rtems/posix/condimpl.h>
#include <rtems/posix/time.h>
@@ -79,7 +80,13 @@ int _POSIX_Condition_variables_Wait_support(
executing->Wait.queue = &the_cond->Wait_queue;
executing->Wait.id = *cond;
- _Thread_queue_Enqueue( &the_cond->Wait_queue, executing, timeout );
+ _Thread_queue_Enqueue(
+ &the_cond->Wait_queue,
+ executing,
+ STATES_WAITING_FOR_CONDITION_VARIABLE
+ | STATES_INTERRUPTIBLE_BY_SIGNAL,
+ timeout
_Objects_Put( &the_cond->Object );
diff --git a/cpukit/posix/src/psignal.c b/cpukit/posix/src/psignal.c
index 0e2a018..eec4d95 100644
--- a/cpukit/posix/src/psignal.c
+++ b/cpukit/posix/src/psignal.c
@@ -24,7 +24,6 @@
#include <rtems/score/isrlevel.h>
-#include <rtems/score/statesimpl.h>
@@ -194,7 +193,6 @@ void _POSIX_signals_Manager_Initialization(void)
&_POSIX_signals_Wait_queue,
- STATES_WAITING_FOR_SIGNAL | STATES_INTERRUPTIBLE_BY_SIGNAL,
EAGAIN
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 6b1e555..4d28de5 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -238,7 +238,6 @@ static bool _POSIX_Threads_Create_extension(
&api->Join_List,
- STATES_WAITING_FOR_JOIN_AT_EXIT | STATES_INTERRUPTIBLE_BY_SIGNAL,
0
diff --git a/cpukit/posix/src/pthreadjoin.c b/cpukit/posix/src/pthreadjoin.c
index 136eea6..99cc4d3 100644
--- a/cpukit/posix/src/pthreadjoin.c
+++ b/cpukit/posix/src/pthreadjoin.c
@@ -26,6 +26,7 @@
int pthread_join(
pthread_t thread,
@@ -70,6 +71,7 @@ on_EINTR:
&api->Join_List,
executing,
+ STATES_WAITING_FOR_JOIN_AT_EXIT | STATES_INTERRUPTIBLE_BY_SIGNAL,
WATCHDOG_NO_TIMEOUT
diff --git a/cpukit/posix/src/sigtimedwait.c b/cpukit/posix/src/sigtimedwait.c
index 4c456dd..8d86ba7 100644
--- a/cpukit/posix/src/sigtimedwait.c
+++ b/cpukit/posix/src/sigtimedwait.c
@@ -158,7 +158,12 @@ int sigtimedwait(
executing->Wait.return_argument = the_info;
_Thread_queue_Enter_critical_section( &_POSIX_signals_Wait_queue );
_POSIX_signals_Release( &lock_context );
- _Thread_queue_Enqueue( &_POSIX_signals_Wait_queue, executing, interval );
+ &_POSIX_signals_Wait_queue,
+ executing,
+ STATES_WAITING_FOR_SIGNAL | STATES_INTERRUPTIBLE_BY_SIGNAL,
+ interval
_Thread_Enable_dispatch();
diff --git a/cpukit/rtems/src/regioncreate.c b/cpukit/rtems/src/regioncreate.c
index 6c623c8..0daf644 100644
--- a/cpukit/rtems/src/regioncreate.c
+++ b/cpukit/rtems/src/regioncreate.c
@@ -22,7 +22,6 @@
#include <rtems/score/apimutex.h>
@@ -94,7 +93,6 @@ rtems_status_code rtems_region_create(
&the_region->Wait_queue,
_Attributes_Is_priority( attribute_set ) ?
THREAD_QUEUE_DISCIPLINE_PRIORITY : THREAD_QUEUE_DISCIPLINE_FIFO,
- STATES_WAITING_FOR_SEGMENT,
RTEMS_TIMEOUT
diff --git a/cpukit/rtems/src/regiongetsegment.c b/cpukit/rtems/src/regiongetsegment.c
index 4bd2445..1a52bc1 100644
--- a/cpukit/rtems/src/regiongetsegment.c
+++ b/cpukit/rtems/src/regiongetsegment.c
@@ -22,6 +22,7 @@
#include <rtems/rtems/optionsimpl.h>
rtems_status_code rtems_region_get_segment(
rtems_id id,
@@ -88,6 +89,7 @@ rtems_status_code rtems_region_get_segment(
executing,
+ STATES_WAITING_FOR_SEGMENT,
timeout
diff --git a/cpukit/score/include/rtems/score/threadq.h b/cpukit/score/include/rtems/score/threadq.h
index 6dcdf41..00b9221 100644
--- a/cpukit/score/include/rtems/score/threadq.h
+++ b/cpukit/score/include/rtems/score/threadq.h
@@ -66,10 +66,6 @@ typedef struct {
Thread_blocking_operation_States sync_state;
/** This field indicates the thread queue's blocking discipline. */
Thread_queue_Disciplines discipline;
- /** This indicates the blocking state for threads waiting on this
- * thread queue.
- States_Control state;
/** This is the status value returned to threads which timeout while
* waiting on this thread queue.
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index 57bdf05..c1bd902 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -71,6 +71,7 @@ Thread_Control *_Thread_queue_Dequeue(
* @param[in] the_thread_queue pointer to threadq
* @param[in] the_thread the thread to enqueue
+ * @param[in] state is the new state of the thread
* @param[in] timeout interval to wait
* - INTERRUPT LATENCY:
@@ -79,6 +80,7 @@ Thread_Control *_Thread_queue_Dequeue(
void _Thread_queue_Enqueue(
Thread_queue_Control *the_thread_queue,
Thread_Control *the_thread,
+ States_Control state,
Watchdog_Interval timeout
@@ -170,13 +172,11 @@ void _Thread_queue_Flush(
* @param[in] the_thread_queue is the pointer to a threadq header
* @param[in] the_discipline is the queueing discipline
- * @param[in] state is the state of waiting threads
* @param[in] timeout_status is the return on a timeout
void _Thread_queue_Initialize(
Thread_queue_Disciplines the_discipline,
- States_Control state,
uint32_t timeout_status
diff --git a/cpukit/score/src/corebarrier.c b/cpukit/score/src/corebarrier.c
index fe2a2e9..2035961 100644
--- a/cpukit/score/src/corebarrier.c
+++ b/cpukit/score/src/corebarrier.c
@@ -19,7 +19,6 @@
#endif
#include <rtems/score/corebarrierimpl.h>
void _CORE_barrier_Initialize(
@@ -34,7 +33,6 @@ void _CORE_barrier_Initialize(
&the_barrier->Wait_queue,
- STATES_WAITING_FOR_BARRIER,
CORE_BARRIER_TIMEOUT
diff --git a/cpukit/score/src/corebarrierwait.c b/cpukit/score/src/corebarrierwait.c
index 3fedb31..6267ae6 100644
--- a/cpukit/score/src/corebarrierwait.c
+++ b/cpukit/score/src/corebarrierwait.c
@@ -20,6 +20,7 @@
void _CORE_barrier_Wait(
@@ -51,5 +52,10 @@ void _CORE_barrier_Wait(
executing->Wait.id = id;
_ISR_Enable( level );
- _Thread_queue_Enqueue( &the_barrier->Wait_queue, executing, timeout );
+ &the_barrier->Wait_queue,
+ executing,
+ STATES_WAITING_FOR_BARRIER,
+ timeout
diff --git a/cpukit/score/src/coremsg.c b/cpukit/score/src/coremsg.c
index fc1ca45..0790221 100644
--- a/cpukit/score/src/coremsg.c
+++ b/cpukit/score/src/coremsg.c
@@ -19,7 +19,6 @@
#endif
@@ -113,7 +112,6 @@ bool _CORE_message_queue_Initialize(
&the_message_queue->Wait_queue,
_CORE_message_queue_Is_priority( the_message_queue_attributes ) ?
- STATES_WAITING_FOR_MESSAGE,
CORE_MESSAGE_QUEUE_STATUS_TIMEOUT
diff --git a/cpukit/score/src/coremsgseize.c b/cpukit/score/src/coremsgseize.c
index e4a4270..db8d558 100644
--- a/cpukit/score/src/coremsgseize.c
+++ b/cpukit/score/src/coremsgseize.c
@@ -23,6 +23,7 @@
#include <rtems/score/isr.h>
void _CORE_message_queue_Seize(
@@ -121,5 +122,10 @@ void _CORE_message_queue_Seize(
/* Wait.count will be filled in with the message priority */
- _Thread_queue_Enqueue( &the_message_queue->Wait_queue, executing, timeout );
+ &the_message_queue->Wait_queue,
+ executing,
+ STATES_WAITING_FOR_MESSAGE,
+ timeout
diff --git a/cpukit/score/src/coremsgsubmit.c b/cpukit/score/src/coremsgsubmit.c
index 4ee41b8..4437856 100644
--- a/cpukit/score/src/coremsgsubmit.c
+++ b/cpukit/score/src/coremsgsubmit.c
@@ -22,6 +22,7 @@
CORE_message_queue_Status _CORE_message_queue_Submit(
@@ -133,6 +134,7 @@ CORE_message_queue_Status _CORE_message_queue_Submit(
executing,
timeout
diff --git a/cpukit/score/src/coremutex.c b/cpukit/score/src/coremutex.c
index 949aa70..b5e8a5e 100644
--- a/cpukit/score/src/coremutex.c
+++ b/cpukit/score/src/coremutex.c
@@ -84,7 +84,6 @@ CORE_mutex_Status _CORE_mutex_Initialize(
&the_mutex->Wait_queue,
_CORE_mutex_Is_fifo( the_mutex_attributes ) ?
THREAD_QUEUE_DISCIPLINE_FIFO : THREAD_QUEUE_DISCIPLINE_PRIORITY,
- STATES_WAITING_FOR_MUTEX,
CORE_MUTEX_TIMEOUT
diff --git a/cpukit/score/src/coremutexseize.c b/cpukit/score/src/coremutexseize.c
index 2f9c8da..d49b566 100644
--- a/cpukit/score/src/coremutexseize.c
+++ b/cpukit/score/src/coremutexseize.c
@@ -22,6 +22,7 @@
#if defined(__RTEMS_DO_NOT_INLINE_CORE_MUTEX_SEIZE__)
@@ -63,7 +64,12 @@ void _CORE_mutex_Seize_interrupt_blocking(
- _Thread_queue_Enqueue( &the_mutex->Wait_queue, executing, timeout );
+ &the_mutex->Wait_queue,
+ executing,
+ STATES_WAITING_FOR_MUTEX,
+ timeout
diff --git a/cpukit/score/src/corerwlock.c b/cpukit/score/src/corerwlock.c
index 0c66f52..0d47db4 100644
--- a/cpukit/score/src/corerwlock.c
+++ b/cpukit/score/src/corerwlock.c
@@ -19,7 +19,6 @@
#endif
#include <rtems/score/corerwlockimpl.h>
void _CORE_RWLock_Initialize(
@@ -38,7 +37,6 @@ void _CORE_RWLock_Initialize(
&the_rwlock->Wait_queue,
- STATES_WAITING_FOR_RWLOCK,
CORE_RWLOCK_TIMEOUT
diff --git a/cpukit/score/src/corerwlockobtainread.c b/cpukit/score/src/corerwlockobtainread.c
index f3851b4..203680f 100644
--- a/cpukit/score/src/corerwlockobtainread.c
+++ b/cpukit/score/src/corerwlockobtainread.c
@@ -20,6 +20,7 @@
void _CORE_RWLock_Obtain_for_reading(
@@ -87,6 +88,7 @@ void _CORE_RWLock_Obtain_for_reading(
executing,
+ STATES_WAITING_FOR_RWLOCK,
timeout
diff --git a/cpukit/score/src/corerwlockobtainwrite.c b/cpukit/score/src/corerwlockobtainwrite.c
index ea7d25c..3499bcd 100644
--- a/cpukit/score/src/corerwlockobtainwrite.c
+++ b/cpukit/score/src/corerwlockobtainwrite.c
@@ -20,6 +20,7 @@
void _CORE_RWLock_Obtain_for_writing(
@@ -77,6 +78,7 @@ void _CORE_RWLock_Obtain_for_writing(
executing,
timeout
diff --git a/cpukit/score/src/coresem.c b/cpukit/score/src/coresem.c
index 32b3458..eb1ba7e 100644
--- a/cpukit/score/src/coresem.c
+++ b/cpukit/score/src/coresem.c
@@ -19,7 +19,6 @@
#endif
#include <rtems/score/coresemimpl.h>
void _CORE_semaphore_Initialize(
CORE_semaphore_Control *the_semaphore,
@@ -35,7 +34,6 @@ void _CORE_semaphore_Initialize(
&the_semaphore->Wait_queue,
_CORE_semaphore_Is_priority( the_semaphore_attributes ) ?
- STATES_WAITING_FOR_SEMAPHORE,
CORE_SEMAPHORE_TIMEOUT
diff --git a/cpukit/score/src/coresemseize.c b/cpukit/score/src/coresemseize.c
index d991af6..9c0db96 100644
--- a/cpukit/score/src/coresemseize.c
+++ b/cpukit/score/src/coresemseize.c
@@ -63,6 +63,11 @@ void _CORE_semaphore_Seize(
executing->Wait.queue = &the_semaphore->Wait_queue;
- _Thread_queue_Enqueue( &the_semaphore->Wait_queue, executing, timeout );
+ &the_semaphore->Wait_queue,
+ executing,
+ STATES_WAITING_FOR_SEMAPHORE,
+ timeout
#endif
diff --git a/cpukit/score/src/threadq.c b/cpukit/score/src/threadq.c
index 1f416ba..bdd380d 100644
--- a/cpukit/score/src/threadq.c
+++ b/cpukit/score/src/threadq.c
@@ -47,11 +47,9 @@ RBTree_Compare_result _Thread_queue_Compare_priority(
- the_thread_queue->state = state;
the_thread_queue->discipline = the_discipline;
the_thread_queue->timeout_status = timeout_status;
the_thread_queue->sync_state = THREAD_BLOCKING_OPERATION_SYNCHRONIZED;
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index 9048551..5c23756 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -104,6 +104,7 @@ static void _Thread_queue_Requeue_priority(
@@ -112,13 +113,13 @@ void _Thread_queue_Enqueue(
#if defined(RTEMS_MULTIPROCESSING)
if ( _Thread_MP_Is_receive( the_thread ) && the_thread->receive_packet )
- the_thread = _Thread_MP_Allocate_proxy( the_thread_queue->state );
+ the_thread = _Thread_MP_Allocate_proxy( state );
else
#endif
* Set the blocking state for this thread queue in the thread.
- _Thread_Set_state( the_thread, the_thread_queue->state );
+ _Thread_Set_state( the_thread, state );
* If the thread wants to timeout, then schedule its timer.
2.1.4
