[PATCH] [RSB] Add support for building Epiphany tools
Hesham ALMatary heshamelmatary at gmail.com
Thu Apr 23 10:46:08 UTC 2015
Hi Chris,
On Tue, Apr 21, 2015 at 11:30 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 22/04/2015 2:33 am, Hesham ALMatary wrote:
>> This patch adds support for building Epiphany tools.
> Great to see this support being adding.
>> Currently some tools
>> are fetched from my repositories (until my pull requests get merged), and
>> other tools are fetched from Adapteva repositories. In the future, the
>> tools should be fetched from GNU upstreams when Adapteva folks push
>> their latest changes there.
> Have you posted your changes to Adapteva ? Would they accept them ?
>>  rtems/config/4.11/rtems-epiphany.bset  | 43 ++++++++++++++++++++++++++++++++++
>>  source-builder/config/binutils-2-1.cfg |  4 ++--
>>  source-builder/config/gcc-common-1.cfg |  5 ++--
>>  source-builder/config/gdb-7-1.cfg      |  4 ++--
>>  4 files changed, 50 insertions(+), 6 deletions(-)
>>  create mode 100644 rtems/config/4.11/rtems-epiphany.bset
>> diff --git a/rtems/config/4.11/rtems-epiphany.bset b/rtems/config/4.11/rtems-epiphany.bset
>> new file mode 100644
>> index 0000000..429031f
>> --- /dev/null
>> +++ b/rtems/config/4.11/rtems-epiphany.bset
>> @@ -0,0 +1,43 @@
>> +# Tools Set for RTEMS Epiphany 4.11 Stable
>> +%define release 1
>> +%define rtems_arch epiphany
>> +# Get GNU tools from external repositories.
>> +%define binutils_external 1
>> +%define gcc_external 1
>> +%define gdb_external 1
>> +# Expanded names of the GNU tools
>> +%define binutils_expand_name epiphany-binutils-gdb-epiphany-binutils-2.23-software-cache
>> +%define gcc_expand_name epiphany-gcc-epiphany-gcc-4.9
>> +%define gdb_expand_name epiphany-binutils-gdb-epiphany-gdb-7.8
> Is this really 'binutils_source_name' or 'binutils_source_top' ?
>> +# Fetch GNU tools from external repos (temporarly).
>> +%source set binutils https://github.com/adapteva/epiphany-binutils-gdb/archive/epiphany-binutils-2.23-software-cache.zip
> Is the expanded tree in the ZIP file not the same as the file name ?
>> +%source set gcc https://github.com/heshamelmatary/epiphany-gcc/archive/epiphany-gcc-4.9.zip
>> +%source set gdb https://github.com/heshamelmatary/epiphany-binutils-gdb/archive/epiphany-gdb-7.8.zip
>> +# The RTEMS 4.11 base defines.
>> +%include rtems-4.11-base.bset
>> +# Tools configuration.
>> +4.11/rtems-autotools
>> +devel/expat-2.1.0-1
>> +tools/rtems-binutils-2.23.1-1
>> +tools/rtems-gcc-4.9.1-newlib-git-1
>> +tools/rtems-gdb-7.8.1-1
>> +tools/rtems-tools-4.11-1
>> diff --git a/source-builder/config/binutils-2-1.cfg b/source-builder/config/binutils-2-1.cfg
>> index c74a2c7..d37674d 100644
>> --- a/source-builder/config/binutils-2-1.cfg
>> +++ b/source-builder/config/binutils-2-1.cfg
>> @@ -37,8 +37,8 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
>>  %prep
>>    build_top=$(pwd)
>> -  source_dir_binutils="binutils-%{binutils_version}"
>> -  %source setup binutils -q -n binutils-%{binutils_version}
>> +  source_dir_binutils=%{?binutils_external:%{binutils_expand_name}}%{!?binutils_external:"binutils-%{binutils_version}"}
>> +  %source setup binutils -q -n %{?binutils_external:%{binutils_expand_name}}%{!?binutils_external:binutils-%{binutils_version}}
> Can this be simplified with something like:
> %binutils_sources=%{?binutils_source_name:%{binutils_source_name}}%{!?binutils_source_name:"binutils-%{binutils_version}"}
> source_dir_binutils=%{binutils_sources}
> %source setup binutils -q -n %{binutils_sources}
I don't know why, but I get the following error when applying your
simplified version.
config: tools/rtems-binutils-2.23.1-1.cfg
error: binutils-2-1.cfg:42: macro '%{binutils_sources}' not found
warning: switched to dry run due to errors
error: binutils-2-1.cfg:43: macro '%{binutils_sources}' not found
The same for gcc and gdb.
BTW, my GCC and binutils pull requests have been merged, there is only
one last pending GDB pull request.
> The same would go for the other tools.
> Chris
>>    %patch setup binutils -p1
>>    cd ${build_top}
>> diff --git a/source-builder/config/gcc-common-1.cfg b/source-builder/config/gcc-common-1.cfg
>> index dd0cf4c..b6fa4bd 100644
>> --- a/source-builder/config/gcc-common-1.cfg
>> +++ b/source-builder/config/gcc-common-1.cfg
>> @@ -41,8 +41,9 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
>>    build_top=$(pwd)
>>    # gcc and optional the g++ core if separate packages
>> -  source_dir_gcc="gcc-%{gcc_version}"
>> -  %source setup gcc -q -n gcc-%{gcc_version}
>> +  source_dir_gcc=%{?gcc_external:%{gcc_expand_name}}%{!?gcc_external:"gcc-%{gcc_version}"}
>> +  %source setup gcc -q -n %{?gcc_external:%{gcc_expand_name}}%{!?gcc_external:gcc-%{gcc_version}}
>>    %patch setup gcc -p1
>>    cd ${build_top}
>> diff --git a/source-builder/config/gdb-7-1.cfg b/source-builder/config/gdb-7-1.cfg
>> index 6e84375..792db50 100644
>> --- a/source-builder/config/gdb-7-1.cfg
>> +++ b/source-builder/config/gdb-7-1.cfg
>> @@ -66,8 +66,8 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
>>  %prep
>>    build_top=$(pwd)
>> -  source_dir_gdb="gdb-%{gdb_version}"
>> -  %source setup gdb -q -n gdb-%{gdb_version}
>> +  source_dir_gdb=%{?gdb_external:%{gdb_expand_name}}%{!?gdb_external:"gdb-%{gdb_version}"}
>> +  %source setup gdb -q -n %{?gdb_external:%{gdb_expand_name}}%{!?gdb_external:gdb-%{gdb_version}}
>>    %patch setup gdb -p1
>>    cd ${build_top}
Hesham
