[PATCH] score: Fix POSIX thread join
Thu Apr 23 14:23:50 UTC 2015
On Thu, Apr 23, 2015 at 9:30 AM, Sebastian Huber
> A thread join twofold.  One side uses a thread queue and the other not.
> So we must not use the same state.
> Update #2035.
>  cpukit/libmisc/monitor/mon-prmisc.c           | 1 +
>  cpukit/posix/src/pthreadjoin.c                | 2 +-
>  cpukit/score/include/rtems/score/statesimpl.h | 4 +++-
>  3 files changed, 5 insertions(+), 2 deletions(-)
> diff --git a/cpukit/libmisc/monitor/mon-prmisc.c b/cpukit/libmisc/monitor/mon-prmisc.c
> index ff54d79..f981a4e 100644
> --- a/cpukit/libmisc/monitor/mon-prmisc.c
> +++ b/cpukit/libmisc/monitor/mon-prmisc.c
> @@ -138,6 +138,7 @@ static const rtems_assoc_t rtems_monitor_state_assoc[] = {
>      { "ZOMBI",  STATES_ZOMBIE, 0 },
>      { "MIGRA",  STATES_MIGRATING, 0 },
>      { "RESTA",  STATES_RESTARTING, 0 },
> +    { "Wjoin",  STATES_WAITING_FOR_JOIN, 0 },
Does the order matter here, or can the state be located next to "Wjatx"?
>      { 0, 0, 0 },
> diff --git a/cpukit/posix/src/pthreadjoin.c b/cpukit/posix/src/pthreadjoin.c
> index 99cc4d3..e2b1664 100644
> --- a/cpukit/posix/src/pthreadjoin.c
> +++ b/cpukit/posix/src/pthreadjoin.c
> @@ -71,7 +71,7 @@ on_EINTR:
>          _Thread_queue_Enqueue(
>            &api->Join_List,
>            executing,
> -          STATES_WAITING_FOR_JOIN_AT_EXIT | STATES_INTERRUPTIBLE_BY_SIGNAL,
> +          STATES_WAITING_FOR_JOIN | STATES_INTERRUPTIBLE_BY_SIGNAL,
>            WATCHDOG_NO_TIMEOUT
> diff --git a/cpukit/score/include/rtems/score/statesimpl.h b/cpukit/score/include/rtems/score/statesimpl.h
> index 074b352..9f94675 100644
> --- a/cpukit/score/include/rtems/score/statesimpl.h
> +++ b/cpukit/score/include/rtems/score/statesimpl.h
> @@ -84,6 +84,8 @@ extern "C" {
>  #define STATES_MIGRATING                       0x400000
>  /** This macro corresponds to a task restarting. */
>  #define STATES_RESTARTING                      0x800000
> +/** This macro corresponds to a task waiting for a join. */
> +#define STATES_WAITING_FOR_JOIN                0x1000000
>  /** This macro corresponds to a task which is in an interruptible
>   *  blocking state.
> @@ -97,7 +99,7 @@ extern "C" {
>                                   STATES_WAITING_FOR_SEMAPHORE          | \
>                                   STATES_WAITING_FOR_MUTEX              | \
>                                   STATES_WAITING_FOR_CONDITION_VARIABLE | \
> -                                 STATES_WAITING_FOR_JOIN_AT_EXIT       | \
> +                                 STATES_WAITING_FOR_JOIN               | \
Is it right to remove WAITING_FOR_JOIN_AT_EXIT here?
Is it possible to replace all WAITING_FOR_JOIN_AT_EXIT with
WAITING_FOR_JOIN? Then the enum and bit values can be just renamed.
>                                   STATES_WAITING_FOR_SIGNAL             | \
>                                   STATES_WAITING_FOR_BARRIER            | \
>                                   STATES_WAITING_FOR_BSD_WAKEUP         | \
> 1.8.4.5
> devel mailing list
> devel at rtems.org
