[rtems commit] posix: Use right thread dispatch disable function
Gedare Bloom gedare at gwu.edu
Fri Apr 24 14:20:07 UTC 2015
Why do we have these two functions with similar names and commented to
have the same functionality? If one is for SMP and the other for UP,
should they be unified or is there a good reason to have separate
functions?
On Fri, Apr 24, 2015 at 2:42 AM, Sebastian Huber <sebh at rtems.org> wrote:
> Module:    rtems
> Branch:    master
> Commit:    d83127e9bd39c1a8c7ef51aa4d9034b06a2bd115
> Changeset: http://git.rtems.org/rtems/commit/?id=d83127e9bd39c1a8c7ef51aa4d9034b06a2bd115
> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:      Fri Apr 24 08:36:33 2015 +0200
>  cpukit/posix/src/mutexlocksupp.c | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
> index 92c6556..9b20f58 100644
> --- a/cpukit/posix/src/mutexlocksupp.c
> +++ b/cpukit/posix/src/mutexlocksupp.c
> @@ -55,7 +55,7 @@ int _POSIX_Mutex_Lock_support(
>      case OBJECTS_LOCAL:
>  #if defined(RTEMS_SMP)
> -      _Thread_Dispatch_disable();
> +      _Thread_Disable_dispatch();
>  #endif
>        executing = _Thread_Executing;
>        _CORE_mutex_Seize(
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
