4.11 BLOCKER - Multiple BSPs fail to build - cache changes?
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Apr 24 16:16:49 UTC 2015
Hi
Multiple BSPs failed to build in my overnight sweep. All
bfin and or1k BSPs plus 18 m68k failed with this:
../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:340:1:
error: static declaration of '_CPU_cache_invalidate_instruction_range'
follows non-static declaration
_CPU_cache_invalidate_instruction_range(
In file included from
../../../../../../../rtems/c/src/lib/libcpu/m68k/shared/cache/cache_.h:37:0,
from
../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:39:
../../../../.././mcf5329/lib/include/libcpu/cache.h:30:6: note: previous
declaration of '_CPU_cache_invalidate_instruction_range' was here
void _CPU_cache_invalidate_instruction_range(const void *i_addr, size_t
n_bytes);
bfin/bf537Stamp, or1k/or1k_generic, and m68k/mvme136 should
be sufficient to reproduce and fix the problem.
