4.11 BLOCKER - Multiple BSPs fail to build - cache changes?
Hesham ALMatary heshamelmatary at gmail.com
Fri Apr 24 17:07:18 UTC 2015
Hi,
I believe this commit is the one which broke it [1], I'm going to
discard the usage of the shared cache_manager.c file and provide or1k
with private stubs.
[1] https://github.com/RTEMS/rtems/commit/26c142e5ad4a63ad42baa17159c1821afe473a00
On Fri, Apr 24, 2015 at 5:16 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> Multiple BSPs failed to build in my overnight sweep.  All
> bfin and or1k BSPs plus 18 m68k failed with this:
> ../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:340:1:
> error: static declaration of '_CPU_cache_invalidate_instruction_range'
> follows non-static declaration
>  _CPU_cache_invalidate_instruction_range(
> In file included from
> ../../../../../../../rtems/c/src/lib/libcpu/m68k/shared/cache/cache_.h:37:0,
>                  from
> ../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:39:
> ../../../../.././mcf5329/lib/include/libcpu/cache.h:30:6: note: previous
> declaration of '_CPU_cache_invalidate_instruction_range' was here
>  void _CPU_cache_invalidate_instruction_range(const void *i_addr, size_t
> n_bytes);
> bfin/bf537Stamp, or1k/or1k_generic, and m68k/mvme136 should
> be sufficient to reproduce and fix the problem.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
Hesham
