4.11 BLOCKER - Multiple BSPs fail to build - cache changes?
Hesham ALMatary heshamelmatary at gmail.com
Fri Apr 24 17:32:23 UTC 2015
s/already/only
Both are working fine with or1k. Let me know which is better. I'd
suggest getting rid of the static declaration as sparc (the only other
CPU that empty-implements the same function) implements it without
"static".
On Fri, Apr 24, 2015 at 6:20 PM, Hesham ALMatary
<heshamelmatary at gmail.com> wrote:
> Gedare,
> The corresponding function declaration and implementation are included
> from libcpu/shared. There are two solutions to fix this for the all
> broken BSPs:
> 1- Get rid of _CPU_cache_invalidate_instruction_range declaration at
> libcpu/shared/include/cache.h, since this functions is already called
> at cache_manager.c
> 2- Get rid of the static keyword at cache_manager.c.
> On Fri, Apr 24, 2015 at 6:13 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On 4/24/2015 12:07 PM, Hesham ALMatary wrote:
>>> Hi,
>>> I believe this commit is the one which broke it [1], I'm going to
>>> discard the usage of the shared cache_manager.c file and provide or1k
>>> with private stubs.
>>> [1] https://github.com/RTEMS/rtems/commit/26c142e5ad4a63ad42baa17159c1821afe473a00
>> This also broke two other architectures. Fixing it for the or1k is not
>> sufficient.
>> Please either provide proper caching for the or1k or fix it in a way that
>> fixes all three architectures.
>>> On Fri, Apr 24, 2015 at 5:16 PM, Joel Sherrill
>>>> Hi
>>>> Multiple BSPs failed to build in my overnight sweep.  All
>>>> bfin and or1k BSPs plus 18 m68k failed with this:
>>>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:340:1:
>>>> error: static declaration of '_CPU_cache_invalidate_instruction_range'
>>>> follows non-static declaration
>>>>  _CPU_cache_invalidate_instruction_range(
>>>> In file included from
>>>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/shared/cache/cache_.h:37:0,
>>>>                  from
>>>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:39:
>>>> ../../../../.././mcf5329/lib/include/libcpu/cache.h:30:6: note: previous
>>>> declaration of '_CPU_cache_invalidate_instruction_range' was here
>>>>  void _CPU_cache_invalidate_instruction_range(const void *i_addr, size_t
>>>> n_bytes);
>>>> bfin/bf537Stamp, or1k/or1k_generic, and m68k/mvme136 should
>>>> be sufficient to reproduce and fix the problem.
>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>> Support Available                (256) 722-9985
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
> Hesham
Hesham
