4.11 BLOCKER - Multiple BSPs fail to build - cache changes?
Fri Apr 24 17:34:26 UTC 2015
----- Hesham ALMatary <heshamelmatary at gmail.com> schrieb:
> Gedare,
> The corresponding function declaration and implementation are included
> from libcpu/shared. There are two solutions to fix this for the all
> broken BSPs:
> 1- Get rid of _CPU_cache_invalidate_instruction_range declaration at
> libcpu/shared/include/cache.h, since this functions is already called
> at cache_manager.c
Yes, this _CPU_cache_invalidate_instruction_range() declaration is a complete nonsense in this file.
> 2- Get rid of the static keyword at cache_manager.c.
> On Fri, Apr 24, 2015 at 6:13 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
> > On 4/24/2015 12:07 PM, Hesham ALMatary wrote:
> >> Hi,
> >> I believe this commit is the one which broke it [1], I'm going to
> >> discard the usage of the shared cache_manager.c file and provide or1k
> >> with private stubs.
> >> [1] https://github.com/RTEMS/rtems/commit/26c142e5ad4a63ad42baa17159c1821afe473a00
> > This also broke two other architectures. Fixing it for the or1k is not
> > sufficient.
> > Please either provide proper caching for the or1k or fix it in a way that
> > fixes all three architectures.
> >> On Fri, Apr 24, 2015 at 5:16 PM, Joel Sherrill
> >>> Hi
> >>> Multiple BSPs failed to build in my overnight sweep.  All
> >>> bfin and or1k BSPs plus 18 m68k failed with this:
> >>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:340:1:
> >>> error: static declaration of '_CPU_cache_invalidate_instruction_range'
> >>> follows non-static declaration
> >>> In file included from
> >>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/shared/cache/cache_.h:37:0,
> >>>                  from
> >>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:39:
> >>> ../../../../.././mcf5329/lib/include/libcpu/cache.h:30:6: note: previous
> >>> declaration of '_CPU_cache_invalidate_instruction_range' was here
> >>>  void _CPU_cache_invalidate_instruction_range(const void *i_addr, size_t
> >>> n_bytes);
> >>> bfin/bf537Stamp, or1k/or1k_generic, and m68k/mvme136 should
> >>> be sufficient to reproduce and fix the problem.
> >>> Joel Sherrill, Ph.D.             Director of Research & Development
> >>> joel.sherrill at OARcorp.com        On-Line Applications Research
> >>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >>> Support Available                (256) 722-9985
> >>> _______________________________________________
> >>> devel mailing list
> >>> devel at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/devel
> Hesham
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
