4.11 BLOCKER - Multiple BSPs fail to build - cache changes?
Fri Apr 24 17:38:11 UTC 2015
----- Hesham ALMatary <heshamelmatary at gmail.com> schrieb:
> s/already/only
> Both are working fine with or1k. Let me know which is better. I'd
> suggest getting rid of the static declaration as sparc (the only other
> CPU that empty-implements the same function) implements it without
> "static".
Providing an empty implementation is wrong.  Thus function needs to get removed for the SPARC.
> On Fri, Apr 24, 2015 at 6:20 PM, Hesham ALMatary
> <heshamelmatary at gmail.com> wrote:
> > Gedare,
> > The corresponding function declaration and implementation are included
> > from libcpu/shared. There are two solutions to fix this for the all
> > broken BSPs:
> > 1- Get rid of _CPU_cache_invalidate_instruction_range declaration at
> > libcpu/shared/include/cache.h, since this functions is already called
> > at cache_manager.c
> > 2- Get rid of the static keyword at cache_manager.c.
> > On Fri, Apr 24, 2015 at 6:13 PM, Joel Sherrill
> > <joel.sherrill at oarcorp.com> wrote:
> >> On 4/24/2015 12:07 PM, Hesham ALMatary wrote:
> >>> Hi,
> >>> I believe this commit is the one which broke it [1], I'm going to
> >>> discard the usage of the shared cache_manager.c file and provide or1k
> >>> with private stubs.
> >>> [1] https://github.com/RTEMS/rtems/commit/26c142e5ad4a63ad42baa17159c1821afe473a00
> >> This also broke two other architectures. Fixing it for the or1k is not
> >> sufficient.
> >> Please either provide proper caching for the or1k or fix it in a way that
> >> fixes all three architectures.
> >>> On Fri, Apr 24, 2015 at 5:16 PM, Joel Sherrill
> >>>> Hi
> >>>> Multiple BSPs failed to build in my overnight sweep.  All
> >>>> bfin and or1k BSPs plus 18 m68k failed with this:
> >>>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:340:1:
> >>>> error: static declaration of '_CPU_cache_invalidate_instruction_range'
> >>>> follows non-static declaration
> >>>>  _CPU_cache_invalidate_instruction_range(
> >>>> In file included from
> >>>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/shared/cache/cache_.h:37:0,
> >>>>                  from
> >>>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:39:
> >>>> ../../../../.././mcf5329/lib/include/libcpu/cache.h:30:6: note: previous
> >>>> declaration of '_CPU_cache_invalidate_instruction_range' was here
> >>>>  void _CPU_cache_invalidate_instruction_range(const void *i_addr, size_t
> >>>> n_bytes);
> >>>> bfin/bf537Stamp, or1k/or1k_generic, and m68k/mvme136 should
> >>>> be sufficient to reproduce and fix the problem.
> >>>> Joel Sherrill, Ph.D.             Director of Research & Development
> >>>> joel.sherrill at OARcorp.com        On-Line Applications Research
> >>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >>>> Support Available                (256) 722-9985
> >>>> _______________________________________________
> >>>> devel mailing list
> >>>> devel at rtems.org
> >>>> http://lists.rtems.org/mailman/listinfo/devel
> > Hesham
> Hesham
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
