4.11 BLOCKER - Multiple BSPs fail to build - cache changes?
Hesham ALMatary heshamelmatary at gmail.com
Fri Apr 24 17:40:41 UTC 2015
On Fri, Apr 24, 2015 at 6:38 PM, Sebastian Huber
> ----- Hesham ALMatary <heshamelmatary at gmail.com> schrieb:
>> s/already/only
>> Both are working fine with or1k. Let me know which is better. I'd
>> suggest getting rid of the static declaration as sparc (the only other
>> CPU that empty-implements the same function) implements it without
>> "static".
> Providing an empty implementation is wrong.  Thus function needs to get removed for the SPARC.
Agreed. If deleted will this break other SPARC BSPs that depend on
this empty implementation? I don't know which SPARC BSPs do.
>> On Fri, Apr 24, 2015 at 6:20 PM, Hesham ALMatary
>> <heshamelmatary at gmail.com> wrote:
>> > Gedare,
>> > The corresponding function declaration and implementation are included
>> > from libcpu/shared. There are two solutions to fix this for the all
>> > broken BSPs:
>> > 1- Get rid of _CPU_cache_invalidate_instruction_range declaration at
>> > libcpu/shared/include/cache.h, since this functions is already called
>> > at cache_manager.c
>> > 2- Get rid of the static keyword at cache_manager.c.
>> > On Fri, Apr 24, 2015 at 6:13 PM, Joel Sherrill
>> > <joel.sherrill at oarcorp.com> wrote:
>> >> On 4/24/2015 12:07 PM, Hesham ALMatary wrote:
>> >>> Hi,
>> >>> I believe this commit is the one which broke it [1], I'm going to
>> >>> discard the usage of the shared cache_manager.c file and provide or1k
>> >>> with private stubs.
>> >>> [1] https://github.com/RTEMS/rtems/commit/26c142e5ad4a63ad42baa17159c1821afe473a00
>> >> This also broke two other architectures. Fixing it for the or1k is not
>> >> sufficient.
>> >> Please either provide proper caching for the or1k or fix it in a way that
>> >> fixes all three architectures.
>> >>> On Fri, Apr 24, 2015 at 5:16 PM, Joel Sherrill
>> >>>> Hi
>> >>>> Multiple BSPs failed to build in my overnight sweep.  All
>> >>>> bfin and or1k BSPs plus 18 m68k failed with this:
>> >>>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:340:1:
>> >>>> error: static declaration of '_CPU_cache_invalidate_instruction_range'
>> >>>> follows non-static declaration
>> >>>>  _CPU_cache_invalidate_instruction_range(
>> >>>> In file included from
>> >>>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/shared/cache/cache_.h:37:0,
>> >>>>                  from
>> >>>> ../../../../../../../rtems/c/src/lib/libcpu/m68k/../shared/src/cache_manager.c:39:
>> >>>> ../../../../.././mcf5329/lib/include/libcpu/cache.h:30:6: note: previous
>> >>>> declaration of '_CPU_cache_invalidate_instruction_range' was here
>> >>>>  void _CPU_cache_invalidate_instruction_range(const void *i_addr, size_t
>> >>>> n_bytes);
>> >>>> bfin/bf537Stamp, or1k/or1k_generic, and m68k/mvme136 should
>> >>>> be sufficient to reproduce and fix the problem.
>> >>>> Joel Sherrill, Ph.D.             Director of Research & Development
>> >>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> >>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> >>>> Support Available                (256) 722-9985
>> >>>> _______________________________________________
>> >>>> devel mailing list
>> >>>> devel at rtems.org
>> >>>> http://lists.rtems.org/mailman/listinfo/devel
>> > Hesham
>> Hesham
>> devel mailing list
>> devel at rtems.org
Hesham
