[rtems commit] Fix or1k C++ build failure
Sebastian Huber
Mon Apr 27 06:48:38 UTC 2015
I doubt that this fix is correct. This variable is usually defined in
the GCC libgcc/crtstuff.c file. I guess something is wrong with the GCC
configuration for this target.
On 26/04/15 21:56, Joel Sherril wrote:
> Module: rtems
> Branch: master
> Commit: 3dead51eddcdb734b36c949cbc1e4c2cd21c52d4
> Changeset: http://git.rtems.org/rtems/commit/?id=3dead51eddcdb734b36c949cbc1e4c2cd21c52d4
> Author: Hesham ALMatary <heshamelmatary at gmail.com>
> Date: Sun Apr 26 11:28:08 2015 -0500
> Closes #2329
> c/src/lib/libbsp/or1k/generic_or1k/start/start.S | 7 +++++++
> 1 file changed, 7 insertions(+)
> diff --git a/c/src/lib/libbsp/or1k/generic_or1k/start/start.S b/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
> index d951a55..ae6d41a 100644
> --- a/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
> +++ b/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
> @@ -180,3 +180,10 @@ _end_clear_bss:
> unhandled_exception:
> l.nop
> +/* Make C++ compiler happy */
> +.section .data
> +.global __dso_handle
> +.weak __dso_handle
> +__dso_handle:
> +.long 0
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
