[rtems commit] Fix or1k C++ build failure
Hesham ALMatary heshamelmatary at gmail.com
Mon Apr 27 07:21:51 UTC 2015
On Mon, Apr 27, 2015 at 7:48 AM, Sebastian Huber
> I doubt that this fix is correct. This variable is usually defined in the
> GCC libgcc/crtstuff.c file. I guess something is wrong with the GCC
> configuration for this target.
I imitated what's in gdbv850sim/start/start.S. I'll check the GCC side.
> On 26/04/15 21:56, Joel Sherril wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    3dead51eddcdb734b36c949cbc1e4c2cd21c52d4
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=3dead51eddcdb734b36c949cbc1e4c2cd21c52d4
>> Author:    Hesham ALMatary <heshamelmatary at gmail.com>
>> Date:      Sun Apr 26 11:28:08 2015 -0500
>> Closes #2329
>>   c/src/lib/libbsp/or1k/generic_or1k/start/start.S | 7 +++++++
>>   1 file changed, 7 insertions(+)
>> diff --git a/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
>> b/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
>> index d951a55..ae6d41a 100644
>> --- a/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
>> +++ b/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
>> @@ -180,3 +180,10 @@ _end_clear_bss:
>>     unhandled_exception:
>>     l.nop
>> +/* Make C++ compiler happy */
>> +.section .data
>> +.global __dso_handle
>> +.weak   __dso_handle
>> +__dso_handle:
>> +.long 0
>> vc mailing list
>> vc at rtems.org
>> http://lists.rtems.org/mailman/listinfo/vc
Hesham
