[rtems commit] Fix or1k C++ build failure
Mon Apr 27 07:48:51 UTC 2015
On 27/04/15 09:44, Hesham ALMatary wrote:
> It's not defined anywhere at libgcc/config/or1k/crt*. I can add it to
> libgcc/config/or1k/crti.S but I'm not sure this will also be correct.
It is defined in libgcc/crtstuff.c. The target must define
INIT_SECTION_ASM_OP or INIT_ARRAY_SECTION_ASM_OP somehow.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
