[PATCH] Fix or1k C++ build failure
Hesham ALMatary heshamelmatary at gmail.com
Mon Apr 27 12:51:45 UTC 2015
On Mon, Apr 27, 2015 at 12:17 PM, Emil Nordling <emil.nordling at gmail.com> wrote:
> Will this fix global ctor/dtor's? (Tested e.g. by compiling and running
> testsuites/samples/cdtest in or1ksim.)
cdtest is built and compiled fine, it's also running but I'm not sure
if it behaves properly.
> Regards,
> /Emil Nordling
> On Mon, Apr 27, 2015 at 12:51 PM <devel-request at rtems.org> wrote:
>> Send devel mailing list submissions to
>>         devel at rtems.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>>         http://lists.rtems.org/mailman/listinfo/devel
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>         devel-owner at rtems.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of devel digest..."
>> Today's Topics:
>>    1. [PATCH] Fix or1k C++ build failure (Hesham ALMatary)
>>    2. 4.11 Branching (Joel Sherrill)
>>    3. Re: 4.11 Branching (Chris Johns)
>>    4. Re: 4.11 Branching (Joel Sherrill)
>>    5. Re: [rtems commit] Fix or1k C++ build failure (Sebastian Huber)
>>    6. Re: [rtems commit] Fix or1k C++ build failure (Hesham ALMatary)
>>    7. Re: [rtems commit] Fix or1k C++ build failure (Hesham ALMatary)
>>    8. Re: [rtems commit] Fix or1k C++ build failure (Sebastian Huber)
>>    9. Re: 4.11 Branching (Sebastian Huber)
>>   10. [PATCH] [RSB] or1k: correct the md5 hash of the GCC patch
>>       (Hesham ALMatary)
>> Message: 1
>> Date: Sun, 26 Apr 2015 17:28:08 +0100
>> From: Hesham ALMatary <heshamelmatary at gmail.com>
>> To: devel at rtems.org
>> Subject: [PATCH] Fix or1k C++ build failure
>> Message-ID:
>>         <1430065688-18143-1-git-send-email-heshamelmatary at gmail.com>
>> Closes #2329
>>  c/src/lib/libbsp/or1k/generic_or1k/start/start.S | 7 +++++++
>>  1 file changed, 7 insertions(+)
>> diff --git a/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
>> b/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
>> index d951a55..ae6d41a 100644
>> --- a/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
>> +++ b/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
>> @@ -180,3 +180,10 @@ _end_clear_bss:
>>  unhandled_exception:
>>    l.nop
>> +/* Make C++ compiler happy */
>> +.section .data
>> +.global __dso_handle
>> +.weak   __dso_handle
>> +__dso_handle:
>> +.long 0
>> 2.1.0
>> Message: 2
>> Date: Sun, 26 Apr 2015 20:15:04 -0500
>> From: Joel Sherrill <joel.sherrill at oarcorp.com>
>> To: "devel at rtems.org" <devel at rtems.org>
>> Subject: 4.11 Branching
>> Message-ID: <2EDD6976-780E-4172-B49F-F60D9E029471 at oarcorp.com>
>> Content-Type: text/plain; charset="UTF-8"
>> Hi
>> I have a fix in the test queue for the build breakages I reported last
>> week. Hesham fixed C++ on the or1k.
>> I need to bump the dates on the documentation before branching.
>> I had the impression Sebastian wanted to merge one more patch set. Is this
>> true?
>> Anything else?
>> --joel
>> Message: 3
>> Date: Mon, 27 Apr 2015 11:41:34 +1000
>> From: Chris Johns <chrisj at rtems.org>
>> To: Joel Sherrill <joel.sherrill at oarcorp.com>, "devel at rtems.org"
>> Subject: Re: 4.11 Branching
>> Message-ID: <553D93CE.9040003 at rtems.org>
>> Content-Type: text/plain; charset=windows-1252
>> On 27/04/2015 11:15 am, Joel Sherrill wrote:
>> > Anything else?
>> I have a change for the cpuuse top command to correctly display the
>> current usage rather than the total usage. This is not a bug fix as such
>> so I am not sure it is ok to go in.
>> Chris
>> Message: 4
>> Date: Sun, 26 Apr 2015 20:44:13 -0500
>> To: Chris Johns <chrisj at rtems.org>,"devel at rtems.org" <devel at rtems.org>
>> Message-ID: <7D1AE1B5-1ED9-48C7-BCE4-ED5927B649FA at oarcorp.com>
>> On April 26, 2015 8:41:34 PM CDT, Chris Johns <chrisj at rtems.org> wrote:
>> >> Anything else?
>> >such
>> It's ok to merge it. Top is new so fixing something is ok. Just timing on
>> when it is ready.
>> >Chris
>> --joel
>> Message: 5
>> Date: Mon, 27 Apr 2015 08:48:38 +0200
>> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
>> To: "rtems-devel at rtems.org" <devel at rtems.org>
>> Subject: Re: [rtems commit] Fix or1k C++ build failure
>> Message-ID: <553DDBC6.9040403 at embedded-brains.de>
>> Content-Type: text/plain; charset=windows-1252; format=flowed
>> I doubt that this fix is correct. This variable is usually defined in
>> the GCC libgcc/crtstuff.c file. I guess something is wrong with the GCC
>> configuration for this target.
>> On 26/04/15 21:56, Joel Sherril wrote:
>> > Module:    rtems
>> > Branch:    master
>> > Commit:    3dead51eddcdb734b36c949cbc1e4c2cd21c52d4
>> > Changeset:
>> > http://git.rtems.org/rtems/commit/?id=3dead51eddcdb734b36c949cbc1e4c2cd21c52d4
>> > Author:    Hesham ALMatary <heshamelmatary at gmail.com>
>> > Date:      Sun Apr 26 11:28:08 2015 -0500
>> > Closes #2329
>> >     l.nop
>> > +.section .data
>> > +.weak   __dso_handle
>> > +__dso_handle:
>> > +.long 0
>> > _______________________________________________
>> > vc mailing list
>> > vc at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/vc
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine gesch?ftliche Mitteilung im Sinne des EHUG.
>> Message: 6
>> Date: Mon, 27 Apr 2015 08:21:51 +0100
>> To: Sebastian Huber <sebastian.huber at embedded-brains.de>
>> Cc: "rtems-devel at rtems.org" <devel at rtems.org>
>> Message-ID:
>> <CA+wsVCAOiQSjWLN3qYmb8bnNQ3sm570RL_HUKxQkidbp7hz5NQ at mail.gmail.com>
>> Content-Type: text/plain; charset=UTF-8
>> On Mon, Apr 27, 2015 at 7:48 AM, Sebastian Huber
>> > the
>> I imitated what's in gdbv850sim/start/start.S. I'll check the GCC side.
>> >> Module:    rtems
>> >> Branch:    master
>> >> Changeset:
>> >> Closes #2329
>> >>     l.nop
>> >> +.section .data
>> >> +.weak   __dso_handle
>> >> +__dso_handle:
>> >> +.long 0
>> >> vc mailing list
>> >> vc at rtems.org
>> Hesham
>> Message: 7
>> Date: Mon, 27 Apr 2015 08:44:12 +0100
>> Message-ID:
>> <CA+wsVCBEbCmGUeu4X3Kd3ReB9Lw9u=KipkGpSZq-iCFA2pWRWw at mail.gmail.com>
>> It's not defined anywhere at libgcc/config/or1k/crt*. I can add it to
>> libgcc/config/or1k/crti.S but I'm not sure this will also be correct.
>> On Mon, Apr 27, 2015 at 8:21 AM, Hesham ALMatary
>> >> the
>> >>> Module:    rtems
>> >>> Branch:    master
>> >>> Changeset:
>> >>> Closes #2329
>> >>>     l.nop
>> >>> +.section .data
>> >>> +.weak   __dso_handle
>> >>> +__dso_handle:
>> >>> +.long 0
>> >>> vc mailing list
>> >>> vc at rtems.org
>> > Hesham
>> Hesham
>> Message: 8
>> Date: Mon, 27 Apr 2015 09:48:51 +0200
>> To: Hesham ALMatary <heshamelmatary at gmail.com>
>> Message-ID: <553DE9E3.4040202 at embedded-brains.de>
>> Content-Type: text/plain; charset=utf-8; format=flowed
>> It is defined in libgcc/crtstuff.c. The target must define
>> INIT_SECTION_ASM_OP or INIT_ARRAY_SECTION_ASM_OP somehow.
>> Message: 9
>> Date: Mon, 27 Apr 2015 10:32:56 +0200
>> Message-ID: <553DF438.3030302 at embedded-brains.de>
>> > this true?
>> I checked in some fixes for the cache manager and the cache support for
>> SPARC. That's all for now.
>> Message: 10
>> Date: Mon, 27 Apr 2015 11:51:16 +0100
>> Subject: [PATCH] [RSB] or1k: correct the md5 hash of the GCC patch
>> Message-ID:
>>         <1430131876-19517-1-git-send-email-heshamelmatary at gmail.com>
>>  rtems/config/4.11/rtems-or1k.bset | 2 +-
>>  1 file changed, 1 insertion(+), 1 deletion(-)
>> diff --git a/rtems/config/4.11/rtems-or1k.bset
>> b/rtems/config/4.11/rtems-or1k.bset
>> index b486885..2e6fb01 100644
>> --- a/rtems/config/4.11/rtems-or1k.bset
>> +++ b/rtems/config/4.11/rtems-or1k.bset
>> @@ -17,7 +17,7 @@
>>  #gcc
>>  %patch add gcc -p1
>> https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gcc-4.8.3-or1k-rtems-29072014.diff
>> -%hash  md5 gcc-4.8.3-or1k-rtems-29072014.diff
>> df2555b2dd4de2d78366fabd705f36ac
>> +%hash  md5 gcc-4.8.3-or1k-rtems-29072014.diff
>> 97be92fbe69a355625633a8d128fb5f5
>>  #gdb
>>  %patch add gdb -p1
>> https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gdb-7.7-or1k-rtems.diff
>> 2.1.0
>> Subject: Digest Footer
>> devel mailing list
>> devel at rtems.org
>> End of devel Digest, Vol 41, Issue 81
Hesham
