[PATCH] Fix or1k C++ build failure
Emil Nordling
emil.nordling at gmail.com
Mon Apr 27 13:10:50 UTC 2015
Great!
If I'm not mistaken, cdtest should mention calling global ctors, local
ctors, local dtors and global dtors. Somewhere in between there is a
section testing exceptions. If it ends with the "header"-printout for the
exceptions, the global initialization is missing.
Regards,
/Emil Nordling
On Mon, Apr 27, 2015 at 2:51 PM Hesham ALMatary <heshamelmatary at gmail.com>
wrote:
> On Mon, Apr 27, 2015 at 12:17 PM, Emil Nordling <emil.nordling at gmail.com>
> wrote:
> > Will this fix global ctor/dtor's? (Tested e.g. by compiling and running
> > testsuites/samples/cdtest in or1ksim.)
> cdtest is built and compiled fine, it's also running but I'm not sure
> if it behaves properly.
> > Regards,
> > /Emil Nordling
> > On Mon, Apr 27, 2015 at 12:51 PM <devel-request at rtems.org> wrote:
> >> Send devel mailing list submissions to
> >> devel at rtems.org
> >> To subscribe or unsubscribe via the World Wide Web, visit
> >> http://lists.rtems.org/mailman/listinfo/devel
> >> or, via email, send a message with subject or body 'help' to
> >> You can reach the person managing the list at
> >> devel-owner at rtems.org
> >> When replying, please edit your Subject line so it is more specific
> >> than "Re: Contents of devel digest..."
> >> Today's Topics:
> >> 1. [PATCH] Fix or1k C++ build failure (Hesham ALMatary)
> >> 2. 4.11 Branching (Joel Sherrill)
> >> 3. Re: 4.11 Branching (Chris Johns)
> >> 4. Re: 4.11 Branching (Joel Sherrill)
> >> 5. Re: [rtems commit] Fix or1k C++ build failure (Sebastian Huber)
> >> 6. Re: [rtems commit] Fix or1k C++ build failure (Hesham ALMatary)
> >> 7. Re: [rtems commit] Fix or1k C++ build failure (Hesham ALMatary)
> >> 8. Re: [rtems commit] Fix or1k C++ build failure (Sebastian Huber)
> >> 9. Re: 4.11 Branching (Sebastian Huber)
> >> 10. [PATCH] [RSB] or1k: correct the md5 hash of the GCC patch
> >> (Hesham ALMatary)
> >> Message: 1
> >> Date: Sun, 26 Apr 2015 17:28:08 +0100
> >> From: Hesham ALMatary <heshamelmatary at gmail.com>
> >> To: devel at rtems.org
> >> Subject: [PATCH] Fix or1k C++ build failure
> >> Message-ID:
> >> <1430065688-18143-1-git-send-email-heshamelmatary at gmail.com>
> >> Closes #2329
> >> c/src/lib/libbsp/or1k/generic_or1k/start/start.S | 7 +++++++
> >> 1 file changed, 7 insertions(+)
> >> diff --git a/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
> >> b/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
> >> index d951a55..ae6d41a 100644
> >> --- a/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
> >> +++ b/c/src/lib/libbsp/or1k/generic_or1k/start/start.S
> >> @@ -180,3 +180,10 @@ _end_clear_bss:
> >> unhandled_exception:
> >> l.nop
> >> +/* Make C++ compiler happy */
> >> +.section .data
> >> +.global __dso_handle
> >> +.weak __dso_handle
> >> +__dso_handle:
> >> +.long 0
> >> 2.1.0
> >> Message: 2
> >> Date: Sun, 26 Apr 2015 20:15:04 -0500
> >> From: Joel Sherrill <joel.sherrill at oarcorp.com>
> >> To: "devel at rtems.org" <devel at rtems.org>
> >> Subject: 4.11 Branching
> >> Message-ID: <2EDD6976-780E-4172-B49F-F60D9E029471 at oarcorp.com>
> >> Content-Type: text/plain; charset="UTF-8"
> >> Hi
> >> I have a fix in the test queue for the build breakages I reported last
> >> week. Hesham fixed C++ on the or1k.
> >> I need to bump the dates on the documentation before branching.
> >> I had the impression Sebastian wanted to merge one more patch set. Is
> this
> >> true?
> >> Anything else?
> >> --joel
> >> Message: 3
> >> Date: Mon, 27 Apr 2015 11:41:34 +1000
> >> From: Chris Johns <chrisj at rtems.org>
> >> To: Joel Sherrill <joel.sherrill at oarcorp.com>, "devel at rtems.org"
> >> Subject: Re: 4.11 Branching
> >> Message-ID: <553D93CE.9040003 at rtems.org>
> >> Content-Type: text/plain; charset=windows-1252
> >> On 27/04/2015 11:15 am, Joel Sherrill wrote:
> >> > Anything else?
> >> I have a change for the cpuuse top command to correctly display the
> >> current usage rather than the total usage. This is not a bug fix as such
> >> so I am not sure it is ok to go in.
> >> Chris
> >> Message: 4
> >> Date: Sun, 26 Apr 2015 20:44:13 -0500
> >> To: Chris Johns <chrisj at rtems.org>,"devel at rtems.org" <devel at rtems.org>
> >> Message-ID: <7D1AE1B5-1ED9-48C7-BCE4-ED5927B649FA at oarcorp.com>
> >> On April 26, 2015 8:41:34 PM CDT, Chris Johns <chrisj at rtems.org> wrote:
> >> >> Anything else?
> >> >such
> >> It's ok to merge it. Top is new so fixing something is ok. Just timing
> on
> >> when it is ready.
> >> >Chris
> >> --joel
> >> Message: 5
> >> Date: Mon, 27 Apr 2015 08:48:38 +0200
> >> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> >> To: "rtems-devel at rtems.org" <devel at rtems.org>
> >> Subject: Re: [rtems commit] Fix or1k C++ build failure
> >> Message-ID: <553DDBC6.9040403 at embedded-brains.de>
> >> Content-Type: text/plain; charset=windows-1252; format=flowed
> >> I doubt that this fix is correct. This variable is usually defined in
> >> the GCC libgcc/crtstuff.c file. I guess something is wrong with the GCC
> >> configuration for this target.
> >> On 26/04/15 21:56, Joel Sherril wrote:
> >> > Module: rtems
> >> > Branch: master
> >> > Commit: 3dead51eddcdb734b36c949cbc1e4c2cd21c52d4
> >> > Changeset:
> http://git.rtems.org/rtems/commit/?id=3dead51eddcdb734b36c949cbc1e4c2cd21c52d4
> >> > Author: Hesham ALMatary <heshamelmatary at gmail.com>
> >> > Date: Sun Apr 26 11:28:08 2015 -0500
> >> > Closes #2329
> >> > l.nop
> >> > +.section .data
> >> > +.weak __dso_handle
> >> > +__dso_handle:
> >> > +.long 0
> >> > _______________________________________________
> >> > vc mailing list
> >> > vc at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/vc
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone : +49 89 189 47 41-16
> >> Fax : +49 89 189 47 41-09
> >> E-Mail : sebastian.huber at embedded-brains.de
> >> PGP : Public key available on request.
> >> Diese Nachricht ist keine gesch?ftliche Mitteilung im Sinne des EHUG.
> >> Message: 6
> >> Date: Mon, 27 Apr 2015 08:21:51 +0100
> >> To: Sebastian Huber <sebastian.huber at embedded-brains.de>
> >> Cc: "rtems-devel at rtems.org" <devel at rtems.org>
> >> Message-ID:
> >> <CA+wsVCAOiQSjWLN3qYmb8bnNQ3sm570RL_HUKxQkidbp7hz5NQ at mail.gmail.com>
> >> Content-Type: text/plain; charset=UTF-8
> >> On Mon, Apr 27, 2015 at 7:48 AM, Sebastian Huber
> >> > the
> >> I imitated what's in gdbv850sim/start/start.S. I'll check the GCC side.
> >> >> Module: rtems
> >> >> Branch: master
> >> >> Changeset:
> >> >> Closes #2329
> >> >> l.nop
> >> >> +.section .data
> >> >> +.weak __dso_handle
> >> >> +__dso_handle:
> >> >> +.long 0
> >> >> vc mailing list
> >> >> vc at rtems.org
> >> Hesham
> >> Message: 7
> >> Date: Mon, 27 Apr 2015 08:44:12 +0100
> >> Message-ID:
> >> <CA+wsVCBEbCmGUeu4X3Kd3ReB9Lw9u=KipkGpSZq-iCFA2pWRWw at mail.gmail.com>
> >> It's not defined anywhere at libgcc/config/or1k/crt*. I can add it to
> >> libgcc/config/or1k/crti.S but I'm not sure this will also be correct.
> >> On Mon, Apr 27, 2015 at 8:21 AM, Hesham ALMatary
> >> >> the
> side.
> >> >>> Module: rtems
> >> >>> Branch: master
> >> >>> Changeset:
> >> >>> Closes #2329
> >> >>> l.nop
> >> >>> +.section .data
> >> >>> +.weak __dso_handle
> >> >>> +__dso_handle:
> >> >>> +.long 0
> >> >>> vc mailing list
> >> >>> vc at rtems.org
> >> > Hesham
> >> Hesham
> >> Message: 8
> >> Date: Mon, 27 Apr 2015 09:48:51 +0200
> >> To: Hesham ALMatary <heshamelmatary at gmail.com>
> >> Message-ID: <553DE9E3.4040202 at embedded-brains.de>
> >> Content-Type: text/plain; charset=utf-8; format=flowed
> >> It is defined in libgcc/crtstuff.c. The target must define
> >> INIT_SECTION_ASM_OP or INIT_ARRAY_SECTION_ASM_OP somehow.
> >> Message: 9
> >> Date: Mon, 27 Apr 2015 10:32:56 +0200
> >> Message-ID: <553DF438.3030302 at embedded-brains.de>
> >> > this true?
> >> I checked in some fixes for the cache manager and the cache support for
> >> SPARC. That's all for now.
> >> Message: 10
> >> Date: Mon, 27 Apr 2015 11:51:16 +0100
> >> Subject: [PATCH] [RSB] or1k: correct the md5 hash of the GCC patch
> >> Message-ID:
> >> <1430131876-19517-1-git-send-email-heshamelmatary at gmail.com>
> >> rtems/config/4.11/rtems-or1k.bset | 2 +-
> >> 1 file changed, 1 insertion(+), 1 deletion(-)
> >> diff --git a/rtems/config/4.11/rtems-or1k.bset
> >> b/rtems/config/4.11/rtems-or1k.bset
> >> index b486885..2e6fb01 100644
> >> --- a/rtems/config/4.11/rtems-or1k.bset
> >> +++ b/rtems/config/4.11/rtems-or1k.bset
> >> @@ -17,7 +17,7 @@
> >> #gcc
> >> %patch add gcc -p1
> https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gcc-4.8.3-or1k-rtems-29072014.diff
> >> -%hash md5 gcc-4.8.3-or1k-rtems-29072014.diff
> >> df2555b2dd4de2d78366fabd705f36ac
> >> +%hash md5 gcc-4.8.3-or1k-rtems-29072014.diff
> >> 97be92fbe69a355625633a8d128fb5f5
> >> #gdb
> >> %patch add gdb -p1
> https://raw.githubusercontent.com/heshamelmatary/or1k-rtems/master/patches/gdb-7.7-or1k-rtems.diff
> >> 2.1.0
> >> Subject: Digest Footer
> >> devel mailing list
> >> devel at rtems.org
> >> End of devel Digest, Vol 41, Issue 81
> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150427/3249d80e/attachment-0001.html>
