[PATCH] libmisc/cpuuse: Top support for current load.
Tue Apr 28 13:46:36 UTC 2015
Is there user-facing documentation for this that should be updated?
On Mon, Apr 27, 2015 at 7:08 PM, Chris Johns <chrisj at rtems.org> wrote:
> The cpuuse top command now supports the current load where the list of
> tasks is ordered based on the current load rather than the total cpu usage.
> This lets you see what is using the processor at any specific instance. You
> can toggle between the modes.
> Added memory usage stats for unified and separate workspace and C heaps as
> well as displaying the allocated stack space.
> Added a few more command keys to refresh the display, show all tasks in the
> system, control the lines display and a scrolling mode that does not clear
> the display on each refresh.
> Removed support for tick kernel builds. The tick support in the kernel is to
> be removed.
>  cpukit/libmisc/cpuuse/cpuusagetop.c | 691 ++++++++++++++++++++++++++----------
>  1 file changed, 496 insertions(+), 195 deletions(-)
> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
> index e47ba59..13b659e 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagetop.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
> @@ -18,6 +18,7 @@
>  #include "config.h"
>  #endif
> +#include <stdbool.h>
>  #include <string.h>
>  #include <stdlib.h>
>  #include <stdio.h>
> @@ -25,29 +26,97 @@
>  #include <inttypes.h>
>  #include <rtems/cpuuse.h>
> +#include <rtems/malloc.h>
>  #include <rtems/score/objectimpl.h>
> +#include <rtems/score/protectedheap.h>
>  #include <rtems/score/threadimpl.h>
>  #include <rtems/score/todimpl.h>
>  #include <rtems/score/watchdogimpl.h>
> +#include <rtems/score/wkspace.h>
>   * Common variable to sync the load monitor task.
> -static volatile int rtems_cpuusage_top_thread_active;
> -typedef struct {
> -  void                  *context;
> +typedef struct
> +  void*                  context;
>    rtems_printk_plugin_t  print;
> -}rtems_cpu_usage_plugin_t;
> +} rtems_cpu_usage_plugin;
> + * Use a struct for all data to allow more than one top and to support the
> + * thread iterator.
> +typedef struct
> +  volatile bool          thread_run;
> +  volatile bool          thread_active;
> +  volatile bool          single_page;
> +  volatile bool          sort_current;
> +  volatile uint32_t      poll_rate_usecs;
> +  volatile uint32_t      show;
> +  rtems_cpu_usage_plugin plugin;
> +  Thread_CPU_usage_t     zero;
> +  Timestamp_Control      uptime;
> +  Timestamp_Control      last_uptime;
> +  Timestamp_Control      period;
> +  int                    task_count;        /* Number of tasks. */
> +  int                    last_task_count;   /* Number of tasks in the previous sample. */
> +  int                    task_size;         /* The size of the arrays */
> +  Thread_Control**       tasks;             /* List of tasks in this sample. */
> +  Thread_Control**       last_tasks;        /* List of tasks in the last sample. */
> +  Thread_CPU_usage_t*    usage;             /* Usage of task's in this sample. */
> +  Thread_CPU_usage_t*    last_usage;        /* Usage of task's in the last sample. */
> +  Thread_CPU_usage_t*    current_usage;     /* Current usage for this sample. */
> +  Timestamp_Control      total;             /* Total run run, should equal the uptime. */
> +  Timestamp_Control      idle;              /* Time spent in idle. */
> +  Timestamp_Control      current;           /* Current time run in this period. */
> +  Timestamp_Control      current_idle;      /* Current time in idle this period. */
> +  uint32_t               stack_size;        /* Size of stack allocated. */
> +} rtems_cpu_usage_data;
> + * Private version of the iterator with an arg. This will be moved
> + * to the public in 5.0.
> +typedef void (*rtems_per_thread_routine_2)( Thread_Control *, void* );
> -#define RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS (20)
> +void rtems_iterate_over_all_threads_2(rtems_per_thread_routine_2 routine,
> +                                      void*                      arg);
> +                                      void*                      arg)
> +  uint32_t             i;
> +  uint32_t             api_index;
> +  Thread_Control      *the_thread;
> +  Objects_Information *information;
> +  if ( !routine )
> +    return;
> +  for ( api_index = 1 ; api_index <= OBJECTS_APIS_LAST ; api_index++ ) {
> +    #if !defined(RTEMS_POSIX_API) || defined(RTEMS_DEBUG)
> +      if ( !_Objects_Information_table[ api_index ] )
> +        continue;
> +    #endif
> +    information = _Objects_Information_table[ api_index ][ 1 ];
> +    if ( information ) {
> +      for ( i=1 ; i <= information->maximum ; i++ ) {
> +        the_thread = (Thread_Control *)information->local_table[ i ];
> +        if ( the_thread )
> +          (*routine)(the_thread, arg);
>  static inline bool equal_to_uint32_t( uint32_t * lhs, uint32_t * rhs )
>     if ( *lhs == *rhs )
>       return true;
> -   else
> +   else
>       return false;
> @@ -60,31 +129,163 @@ static inline bool less_than_uint32_t( uint32_t * lhs, uint32_t * rhs )
>  #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__
> -  #define _Thread_CPU_usage_Equal_to( _lhs, _rhs ) \
> +  #define CPU_usage_Equal_to( _lhs, _rhs ) \
>            _Timestamp_Equal_to( _lhs, _rhs )
>  #else
>            equal_to_uint32_t( _lhs, _rhs )
>  #endif
> -#define  _Thread_CPU_usage_Set_to_zero( _time ) \
> +  #define CPU_usage_Set_to_zero( _time ) \
>           _Timestamp_Set_to_zero( _time )
>  #else
>         do { \
>           *_time = 0; \
>         } while (0)
>  #endif
> -#define _Thread_CPU_usage_Less_than( _lhs, _rhs ) \
> +  #define CPU_usage_Less_than( _lhs, _rhs ) \
>          _Timestamp_Less_than( _lhs, _rhs )
>  #else
>           less_than_uint32_t( _lhs, _rhs )
>  #endif
> +static void
> +print_memsize(rtems_cpu_usage_data* data, const uint32_t size, const char* label)
> +  if (size > (1024 * 1024))
> +    (*data->plugin.print)(data->plugin.context, "%4" PRIu32 "M %s",
> +                          size / (1024 * 1024), label);
> +  else if (size > 1024)
> +    (*data->plugin.print)(data->plugin.context, "%4" PRIu32 "K %s",
> +                          size / 1024, label);
> +  else
> +    (*data->plugin.print)(data->plugin.context, "%4" PRIu32 " %s",
> +                          size, label);
> +static int
> +print_time(rtems_cpu_usage_data*    data,
> +           const Timestamp_Control* time,
> +           const int                length)
> +  uint32_t secs = _Timestamp_Get_seconds( time );
> +  uint32_t usecs = _Timestamp_Get_nanoseconds( time ) / TOD_NANOSECONDS_PER_MICROSECOND;
> +  int      len = 0;
> +  if (secs > 60)
> +    uint32_t mins = secs / 60;
> +    if (mins > 60)
> +      uint32_t hours = mins / 60;
> +      if (hours > 24)
> +        len += (*data->plugin.print)(data->plugin.context, "%" PRIu32 "d", hours / 24);
> +        hours %= 24;
> +      len += (*data->plugin.print)(data->plugin.context, "%" PRIu32 "hr", hours);
> +      mins %= 60;
> +    len += (*data->plugin.print)(data->plugin.context, "%" PRIu32 "m", mins);
> +    secs %= 60;
> +  len += (*data->plugin.print)(data->plugin.context, "%" PRIu32 ".%06" PRIu32, secs, usecs);
> +  if (len < length)
> +    (*data->plugin.print)(data->plugin.context, "%*c", length - len, ' ');
> +  return len;
> + * Count the number of tasks.
> +static void
> +task_counter(Thread_Control *thrad, void* arg)
> +  rtems_cpu_usage_data* data = (rtems_cpu_usage_data*) arg;
> +  ++data->task_count;
> + * Create the usage and currant usage table for display.
> +static void
> +task_usage(Thread_Control* thread, void* arg)
> +  Thread_CPU_usage_t    usage = thread->cpu_time_used;
> +  Thread_CPU_usage_t    current = data->zero;
> +  int                   j;
> +  data->stack_size += thread->Start.Initial_stack.size;
> +  for (j = 0; j < data->last_task_count; j++)
> +    if (thread == data->last_tasks[j])
> +      _Timestamp_Subtract(&data->last_usage[j], &usage, &current);
> +      break;
> +   * When not using nanosecond CPU usage resolution, we have to count the
> +   * number of "ticks" we gave credit for to give the user a rough guideline as
> +   * to what each number means proportionally.
> +  _Timestamp_Add_to(&data->total, &usage);
> +  _Timestamp_Add_to(&data->current, &current);
> +  if (thread->Object.id == 0x09010001)
> +    data->idle = usage;
> +    data->current_idle = current;
> +   * Create the tasks to display soring as we create.
> +  for (j = 0; j < data->task_count; j++)
> +    if (data->tasks[j])
> +      int k;
> +       * Sort on the current load.
> +      if (data->sort_current)
> +        if (CPU_usage_Equal_to(&current, &data->zero) ||
> +             CPU_usage_Less_than(&current, &data->current_usage[j]))
> +          continue;
> +      else
> +        if (CPU_usage_Equal_to(&usage, &data->zero) ||
> +            CPU_usage_Less_than(&usage, &data->usage[j]))
> +          continue;
> +      for (k = (data->task_count - 1); k >= j; k--)
> +        data->tasks[k + 1] = data->tasks[k];
> +        data->usage[k + 1]  = data->usage[k];
> +        data->current_usage[k + 1]  = data->current_usage[k];
> +    data->tasks[j] = thread;
> +    data->usage[j] = usage;
> +    data->current_usage[j] = current;
> +    break;
>   * rtems_cpuusage_top_thread
> @@ -94,202 +295,251 @@ static inline bool less_than_uint32_t( uint32_t * lhs, uint32_t * rhs )
>  static void
>  rtems_cpuusage_top_thread (rtems_task_argument arg)
> -  uint32_t                  api_index;
> -  Thread_Control*           the_thread;
> -  int                       i;
> -  int                       j;
> -  int                       k;
> -  Objects_Information*      information;
> -  char                      name[13];
> -  int                       task_count = 0;
> -  uint32_t                  seconds, nanoseconds;
> -  rtems_cpu_usage_plugin_t* plugin = (rtems_cpu_usage_plugin_t*)arg;
> -  Thread_Control*           load_tasks[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
> -  Thread_CPU_usage_t        load[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
> -  Thread_CPU_usage_t        zero;
> -  Timestamp_Control         uptime;
> -  uint32_t                  ival, fval;
> -  while (true) {
> -    #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__
> -      Timestamp_Control  total, ran, uptime_at_last_reset;
> -    #else
> -      uint32_t           total_units = 0;
> -    #endif
> +  char                   name[13];
> +  int                    i;
> +  Heap_Information_block wksp;
> +  uint32_t               ival, fval;
> +  int                    task_count;
> +  rtems_event_set        out;
> +  rtems_status_code      sc;
> +  bool                   first_time = true;
> -    rtems_cpuusage_top_thread_active = 1;
> +  data->thread_active = true;
> -    _Thread_CPU_usage_Set_to_zero( &zero);
> -    memset (load_tasks, 0, sizeof (load_tasks));
> -    for (i=0; i< (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1); i++)
> -      _Thread_CPU_usage_Set_to_zero( &load[i] );
> +  _TOD_Get_uptime(&data->last_uptime);
> -     * Iterate over the tasks and sort the highest load tasks
> -     * into our local arrays. We only handle a limited number of
> -     * tasks.
> -    for ( api_index = 1 ; api_index <= OBJECTS_APIS_LAST ; api_index++ ) {
> -      #if !defined(RTEMS_POSIX_API) || defined(RTEMS_DEBUG)
> -        if ( !_Objects_Information_table[ api_index ] )
> -          continue;
> -      #endif
> -      information = _Objects_Information_table[ api_index ][ 1 ];
> -      if ( information ) {
> -        for ( i=1 ; i <= information->maximum ; i++ ) {
> -          the_thread = (Thread_Control *)information->local_table[ i ];
> -          if ( the_thread ) {
> -            Thread_CPU_usage_t usage = the_thread->cpu_time_used;
> -             *  When not using nanosecond CPU usage resolution, we have to count
> -             *  the number of "ticks" we gave credit for to give the user a rough
> -             *  guideline as to what each number means proportionally.
> -            #ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
> -              total_units += usage;
> -            #endif
> -            /* Count the number of tasks and sort this load value */
> -            task_count++;
> -            for (j = 0; j < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; j++) {
> -              if (load_tasks[j]) {
> -                if ( _Thread_CPU_usage_Equal_to( &usage, &zero) ||
> -                     _Thread_CPU_usage_Less_than( &usage, &load[j]))
> -                  continue;
> -                for (k = (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - 1); k >= j; k--){
> -                  load_tasks[k + 1] = load_tasks[k];
> -                  load[k + 1]  = load[k];
> -              load_tasks[j] = the_thread;
> -              load[j]  = usage;
> -              break;
> +  CPU_usage_Set_to_zero(&data->zero);
> +  while (data->thread_run)
> +    Timestamp_Control uptime_at_last_reset = CPU_usage_Uptime_at_last_reset;
> +    size_t            tasks_size;
> +    size_t            usage_size;
> +    Timestamp_Control load;
> +    data->task_count = 0;
> +    rtems_iterate_over_all_threads_2(task_counter, data);
> +    tasks_size = sizeof(Thread_Control*) * (data->task_count + 1);
> +    usage_size = sizeof(Thread_CPU_usage_t) * (data->task_count + 1);
> +    if (data->task_count > data->task_size)
> +      data->tasks = realloc(data->tasks, tasks_size);
> +      data->usage = realloc(data->usage, usage_size);
> +      data->current_usage = realloc(data->current_usage, usage_size);
> +      if ((data->tasks == NULL) || (data->usage == NULL) || (data->current_usage == NULL))
> +        (*data->plugin.print)(data->plugin.context, "top worker: error: no memory\n");
> +        data->thread_run = false;
> +        break;
> -      _Timestamp_Set_to_zero( &total );
> -      uptime_at_last_reset = CPU_usage_Uptime_at_last_reset;
> -    #endif
> +    memset(data->tasks, 0, tasks_size);
> +    memset(data->usage, 0, usage_size);
> +    memset(data->current_usage, 0, usage_size);
> -    _TOD_Get_uptime( &uptime );
> -    seconds = _Timestamp_Get_seconds( &uptime );
> -    nanoseconds = _Timestamp_Get_nanoseconds( &uptime ) /
> -                  TOD_NANOSECONDS_PER_MICROSECOND;
> -    (*plugin->print)(plugin->context, "\x1b[H\x1b[J Press ENTER to exit.\n\n");
> -    (*plugin->print)(plugin->context, "uptime: ");
> -      "%7" PRIu32 ".%06" PRIu32 "\n",  seconds, nanoseconds
> +    _Timestamp_Set_to_zero(&data->total);
> +    _Timestamp_Set_to_zero(&data->current);
> +    data->stack_size = 0;
> +    _TOD_Get_uptime(&data->uptime);
> +    _Timestamp_Subtract(&uptime_at_last_reset, &data->uptime, &data->uptime);
> +    _Timestamp_Subtract(&data->last_uptime, &data->uptime, &data->period);
> +    data->last_uptime = data->uptime;
> -    (*plugin->print)(
> -       plugin->context,
> -       "-------------------------------------------------------------------------------\n"
> -       "                              CPU USAGE BY THREAD\n"
> -       "------------+---------------------+---------------+---------------+------------\n"
> -        " ID         | NAME                | RPRI | CPRI   | SECONDS       | PERCENT\n"
> -       #else
> -        " ID         | NAME                | RPRI | CPRI   | TICKS         | PERCENT\n"
> -       #endif
> +    rtems_iterate_over_all_threads_2(task_usage, data);
> +      data->last_tasks = realloc(data->last_tasks, tasks_size);
> +      data->last_usage = realloc(data->last_usage, usage_size);
> +      if ((data->last_tasks == NULL) || (data->last_usage == NULL))
> +        break;
> +      data->task_size = data->task_count;
> +    memcpy(data->last_tasks, data->tasks, tasks_size);
> +    memcpy(data->last_usage, data->usage, usage_size);
> +    data->last_task_count = data->task_count;
> +    if (data->sort_current  && first_time)
> +      rtems_task_wake_after(RTEMS_MILLISECONDS_TO_TICKS(500));
> +      first_time = false;
> +      continue;
> +    _Protected_heap_Get_information(&_Workspace_Area, &wksp);
> +    if (data->single_page)
> +                            "\x1b[H\x1b[J"
> +                            " <ENTER>:Exit  <C>:%s  <SPACE>:Refresh"
> +                            "  <S>:Scroll  <A>:All  <+/->:Lines\n",
> +                            data->sort_current ? "Total  " : "Current");
> +    (*data->plugin.print)(data->plugin.context,"\n");
> +     * Uptime and period of this sample.
> +    (*data->plugin.print)(data->plugin.context, "Uptime: ");
> +    print_time(data, &data->uptime, 20);
> +    (*data->plugin.print)(data->plugin.context, " Period: ");
> +    print_time(data, &data->period, 20);
> +     * Task count, load and idle levels.
> +    (*data->plugin.print)(data->plugin.context, "\nTasks: %4i  ", data->task_count);
> +    _Timestamp_Subtract(&data->idle, &data->total, &load);
> +    _Timestamp_Divide(&load, &data->uptime, &ival, &fval);
> +                          "Load Average: %4" PRIu32 ".%03" PRIu32 "%%", ival, fval);
> +    _Timestamp_Subtract(&data->current_idle, &data->current, &load);
> +    _Timestamp_Divide(&load, &data->period, &ival, &fval);
> +                          "  Load: %4" PRIu32 ".%03" PRIu32 "%%", ival, fval);
> +    _Timestamp_Divide(&data->current_idle, &data->period, &ival, &fval);
> +                          "  Idle: %4" PRIu32 ".%03" PRIu32 "%%", ival, fval);
> +     * Memory usage.
> +    if (rtems_configuration_get_unified_work_area())
> +      (*data->plugin.print)(data->plugin.context, "\nMem: ");
> +      print_memsize(data, wksp.Free.total, "free");
> +      print_memsize(data, wksp.Used.total, "used");
> +    else
> +      region_information_block libc_heap;
> +      malloc_info(&libc_heap);
> +      (*data->plugin.print)(data->plugin.context, "\nMem: Wksp: ");
> +      print_memsize(data, wksp.Used.total, "used  Heap: ");
> +      print_memsize(data, libc_heap.Free.total, "free");
> +      print_memsize(data, libc_heap.Used.total, "used");
> +    print_memsize(data, data->stack_size, "stack\n");
> +       "\n"
> +        " ID         | NAME                | RPRI | CPRI   | TIME                | TOTAL   | CURRENT\n"
> +       "------------+---------------------+---------------+---------------------+-----%s-+-----%s-\n",
> +       data->sort_current ? "---" : "***",
> +       data->sort_current ? "***" : "---"
> -    for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++) {
> +    task_count = 0;
> +    for (i = 0; i < data->task_count; i++)
> +      Thread_Control*   thread = data->tasks[i];
> +      Timestamp_Control last;
> +      Timestamp_Control usage;
> +      Timestamp_Control current_usage;
> -      if (!load_tasks[i])
> +      if (thread == NULL)
> +        break;
> +      if (data->single_page && (data->show != 0) && (i >= data->show))
>          break;
> -       * If this is the currently executing thread, account for time
> -       * since the last context switch.
> +       * We need to count the number displayed to clear the remainder of the
> +       * the display.
> -      the_thread = load_tasks[i];
> -      rtems_object_get_name( the_thread->Object.id, sizeof(name), name );
> -      (*plugin->print)(
> -        plugin->context,
> -        " 0x%08" PRIx32 " | %-19s |  %3" PRId32 " |  %3" PRId32 "   |",
> -        the_thread->Object.id,
> -        name,
> -        the_thread->real_priority,
> -        the_thread->current_priority
> -        Timestamp_Control last;
> +      ++task_count;
> -        ran = load[i];
> -        if ( _Thread_Get_time_of_last_context_switch( the_thread, &last ) ) {
> -          Timestamp_Control used;
> -          _Timestamp_Subtract( &last, &uptime, &used );
> -          _Timestamp_Add_to( &ran, &used );
> -        } else {
> -        _Timestamp_Subtract( &uptime_at_last_reset, &uptime, &total );
> -        _Timestamp_Divide( &ran, &total, &ival, &fval );
> +       * If the API os POSIX print the entry point.
> +      rtems_object_get_name(thread->Object.id, sizeof(name), name);
> +      if (name[0] == '\0')
> +        snprintf(name, sizeof(name) - 1, "(%p)", thread->Start.entry_point);
> +                            " 0x%08" PRIx32 " | %-19s |  %3" PRId32 " |  %3" PRId32 "   | ",
> +                            thread->Object.id,
> +                            name,
> +                            thread->real_priority,
> +                            thread->current_priority);
> +      usage = data->usage[i];
> +      current_usage = data->current_usage[i];
> +       * If this is the currently executing thread, account for time since
> +       * the last context switch.
> +      if (_Thread_Get_time_of_last_context_switch(thread, &last))
> +        Timestamp_Control used;
> +        Timestamp_Control now;
> -         * Print the information
> +         * Get the current uptime and assume we are not pre-empted to
> +         * measure the time from the last switch this thread and now.
> -        seconds = _Timestamp_Get_seconds( &ran );
> -        nanoseconds = _Timestamp_Get_nanoseconds( &ran ) /
> -       (*plugin->print)( plugin->context,
> -          "%7" PRIu32 ".%06" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
> -          seconds, nanoseconds,
> -            ival, fval
> +        _TOD_Get_uptime(&now);
> +        _Timestamp_Subtract(&last, &now, &used);
> +        _Timestamp_Add_to(&usage, &used);
> +        _Timestamp_Add_to(&current_usage, &used);
> -      #else
> -        if (total_units) {
> -          uint64_t ival_64;
> -          ival_64 = load[i];
> -          ival_64 *= 100000;
> -          ival = ival_64 / total_units;
> -        } else {
> -          ival = 0;
> -        fval = ival % 1000;
> -        ival /= 1000;
> -          "%14" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
> -          load[i],
> -          ival,
> -          fval
> -      #endif
> +       * Print the information
> +      print_time(data, &usage, 19);
> +      _Timestamp_Divide(&usage, &data->total, &ival, &fval);
> +                            " |%4" PRIu32 ".%03" PRIu32, ival, fval);
> +      _Timestamp_Divide(&current_usage, &data->period, &ival, &fval);
> +                            " |%4" PRIu32 ".%03" PRIu32 "\n", ival, fval);
> -    if (task_count < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS)
> +    if (data->single_page && (data->show != 0) && (task_count < data->show))
> -      j = RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - task_count;
> -      while (j > 0)
> +      i = data->show - task_count;
> +      while (i > 0)
> -       (*plugin->print)( plugin->context, "\x1b[K\n");
> -        j--;
> +        (*data->plugin.print)(data->plugin.context, "\x1b[K\n");
> +        i--;
> -    rtems_cpuusage_top_thread_active = 0;
> -    rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (5000000));
> +    sc = rtems_event_receive(RTEMS_EVENT_1,
> +                             RTEMS_EVENT_ANY,
> +                             RTEMS_MILLISECONDS_TO_TICKS (data->poll_rate_usecs),
> +                             &out);
> +    if ((sc != RTEMS_SUCCESSFUL) && (sc != RTEMS_TIMEOUT))
> +                            "error: event receive: %s\n", rtems_status_text(sc));
> +      break;
> +  free(data->tasks);
> +  free(data->last_tasks);
> +  free(data->last_usage);
> +  free(data->current_usage);
> +  data->thread_active = false;
> +  rtems_task_delete (RTEMS_SELF);
>  void rtems_cpu_usage_top_with_plugin(
> @@ -297,17 +547,30 @@ void rtems_cpu_usage_top_with_plugin(
> -  rtems_status_code   sc;
> -  rtems_task_priority priority;
> -  rtems_name          name;
> -  rtems_id            id;
> -  rtems_cpu_usage_plugin_t  plugin;
> +#ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
> +  if ( !print )
> +    return;
> +  (*print)(context, "error: tick kernels not supported\n");
> +#else
> +  rtems_task_priority    priority;
> +  rtems_name             name;
> +  rtems_id               id;
> +  rtems_cpu_usage_data   data;
> +  int                    show_lines = 25;
>    if ( !print )
>      return;
> -  plugin.context = context;
> -  plugin.print   = print;
> +  memset(&data, 0, sizeof(data));
> +  data.thread_run = true;
> +  data.single_page = true;
> +  data.sort_current = true;
> +  data.poll_rate_usecs = 3000;
> +  data.show = show_lines;
> +  data.plugin.context = context;
> +  data.plugin.print = print;
>    sc = rtems_task_set_priority (RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &priority);
> @@ -339,7 +602,7 @@ void rtems_cpu_usage_top_with_plugin(
>    sc = rtems_task_start (
> -    id, rtems_cpuusage_top_thread, (rtems_task_argument)&plugin
> +    id, rtems_cpuusage_top_thread, (rtems_task_argument) &data
>    if (sc != RTEMS_SUCCESSFUL)
> @@ -352,23 +615,61 @@ void rtems_cpu_usage_top_with_plugin(
>      return;
> -  for (;;)
> +  while (true)
>      int c = getchar ();
> -    if ((c == '\r') || (c == '\n'))
> +    if ((c == '\r') || (c == '\n') || (c == 'q') || (c == 'Q'))
> -      int loops = 20;
> +      int loops = 50;
> -      while (loops && rtems_cpuusage_top_thread_active)
> -        rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (100000));
> +      data.thread_run = false;
> +      rtems_event_send(id, RTEMS_EVENT_1);
> -      rtems_task_delete (id);
> +      while (loops && data.thread_active)
> +        rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (100000));
>        (*print)(context, "load monitoring stopped.\n");
>        return;
> +    else if ((c == 'c') || (c == 'C'))
> +      data.sort_current = !data.sort_current;
> +    else if ((c == 's') || (c == 'S'))
> +      data.single_page = !data.single_page;
> +    else if ((c == 'a') || (c == 'A'))
> +      if (data.show == 0)
> +      else
> +        data.show = 0;
> +    else if (c == '+')
> +      ++show_lines;
> +      if (data.show != 0)
> +    else if (c == '-')
> +      if (show_lines > 5)
> +        --show_lines;
> +    else if (c == ' ')
> +#endif
>  void rtems_cpu_usage_top( void )
> 2.2.2
> devel mailing list
> devel at rtems.org
