[PATCH] libmisc/cpuuse: Top support for current load.
Tue Apr 28 19:22:00 UTC 2015
On 29/04/2015 4:48 am, Gedare Bloom wrote:
> On Tue, Apr 28, 2015 at 2:19 PM, Chris Johns <chrisj at rtems.org> wrote:
>> On 28/04/2015 11:46 pm, Gedare Bloom wrote:
>>> Is there user-facing documentation for this that should be updated?
>> I did not check the shell's user manual as I am only refactoring the code and not adding the command. It is just the 'top' command and no options and then the top line of the output lists the valid keys. Here is a sample from an idle Zynq board:
> Thanks Chris, I guess I wondered if it is obvious how to "Toggle" the
> ordering.
The <C> key.
> Is it like 'top' with > and <?
Not sure. Those keys do not work on MacOS or FreeBSD.
> Are other fields worth being
> used to sort? (Could be a small open project)
It could be added without much effort. I will have a look.
