[PATCH 1/2] SPARC Floating Point Context switch
Alexander Krutwig alexander.krutwig at embedded-brains.de
Thu Apr 30 09:38:26 UTC 2015
two new Assembler Files for SPCONTEXT01 test on sparc
1) _CPU_Context_validate
2) _CPU_Context_volatile_clobber
Update #2270.
 cpukit/score/cpu/sparc/Makefile.am                 |   2 +
 cpukit/score/cpu/sparc/rtems/score/cpu.h           |  12 +-
 cpukit/score/cpu/sparc/sparc-context-validate.S    | 283 +++++++++++++++++++++
 .../cpu/sparc/sparc-context-volatile-clobber.S     |  92 +++++++
 4 files changed, 379 insertions(+), 10 deletions(-)
 create mode 100644 cpukit/score/cpu/sparc/sparc-context-validate.S
 create mode 100644 cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
diff --git a/cpukit/score/cpu/sparc/Makefile.am b/cpukit/score/cpu/sparc/Makefile.am
index c6ea1c3..8cf4f4a 100644
--- a/cpukit/score/cpu/sparc/Makefile.am
+++ b/cpukit/score/cpu/sparc/Makefile.am
@@ -11,6 +11,8 @@ include_rtems_score_HEADERS += rtems/score/cpuatomic.h
 noinst_LIBRARIES = libscorecpu.a
 libscorecpu_a_SOURCES = cpu.c cpu_asm.S
+libscorecpu_a_SOURCES += sparc-context-volatile-clobber.S
+libscorecpu_a_SOURCES += sparc-context-validate.S
 libscorecpu_a_SOURCES += sparc-counter.c
 libscorecpu_a_SOURCES += sparcv8-atomic.c
 libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index 235b365..64e8750 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -1216,17 +1216,9 @@ void _CPU_Context_restore_fp(
   Context_Control_fp **fp_context_ptr
-static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
-  /* TODO */
+void _CPU_Context_volatile_clobber( uintptr_t pattern );
-static inline void _CPU_Context_validate( uintptr_t pattern )
-  while (1) {
-    /* TODO */
+void _CPU_Context_validate( uintptr_t pattern );
 typedef struct {
   uint32_t trap;
diff --git a/cpukit/score/cpu/sparc/sparc-context-validate.S b/cpukit/score/cpu/sparc/sparc-context-validate.S
new file mode 100644
index 0000000..b75cf83
--- /dev/null
+++ b/cpukit/score/cpu/sparc/sparc-context-validate.S
@@ -0,0 +1,283 @@
+ * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/asm.h>
+#include <rtems/score/cpu.h>
+#define FRAME_OFFSET_L0 68
+#define FRAME_OFFSET_L1 72
+#define FRAME_OFFSET_L2 76
+#define FRAME_OFFSET_L3 80
+#define FRAME_OFFSET_L4 84
+#define FRAME_OFFSET_L5 88
+#define FRAME_OFFSET_L6 92
+#define FRAME_OFFSET_L7 96
+#define FRAME_OFFSET_I0 100
+#define FRAME_OFFSET_I1 104
+#define FRAME_OFFSET_I2 108
+#define FRAME_OFFSET_I3 112
+#define FRAME_OFFSET_I4 116
+#define FRAME_OFFSET_I5 120
+#define FRAME_OFFSET_I6 124
+#define FRAME_OFFSET_I7 128
+#define FRAME_OFFSET_O7 132
+#define BUFFER_STORAGE 136
+#define FRAME_SIZE (BUFFER_STORAGE + 8)
+#if ((FRAME_SIZE % 8) != 0)
+#error "Frame size alignment violated"
+#endif
+        .align 4
+        PUBLIC(_CPU_Context_validate)
+SYM(_CPU_Context_validate):
+	add	%sp, -FRAME_SIZE, %sp
+	st	%l0, [%sp + FRAME_OFFSET_L0]
+	st	%l1, [%sp + FRAME_OFFSET_L1]
+	st	%l2, [%sp + FRAME_OFFSET_L2]
+	st	%l3, [%sp + FRAME_OFFSET_L3]
+	st	%l4, [%sp + FRAME_OFFSET_L4]
+	st	%l5, [%sp + FRAME_OFFSET_L5]
+	st	%l6, [%sp + FRAME_OFFSET_L6]
+	st	%l7, [%sp + FRAME_OFFSET_L7]
+	st	%i0, [%sp + FRAME_OFFSET_I0]
+	st	%i1, [%sp + FRAME_OFFSET_I1]
+	st	%i2, [%sp + FRAME_OFFSET_I2]
+	st	%i3, [%sp + FRAME_OFFSET_I3]
+	st	%i4, [%sp + FRAME_OFFSET_I4]
+	st	%i5, [%sp + FRAME_OFFSET_I5]
+	st	%i6, [%sp + FRAME_OFFSET_I6]
+	st	%i7, [%sp + FRAME_OFFSET_I7]
+	/* Save callback address in case of error */
+	st 	%o7, [%sp + FRAME_OFFSET_O7]
+.macro fill_register reg
+	add	%g1, 1, %g1
+	mov	%g1, \reg
+.endm
+	/* Fill */
+	/* g1 is used for temporary values */
+	mov	%o0, %g1
+	mov	%sp, %g2
+	fill_register	%o1
+	fill_register	%o2
+	fill_register	%o3
+	fill_register	%o4
+	fill_register	%o5
+	fill_register	%l0
+	fill_register	%l1
+	fill_register	%l2
+	fill_register	%l3
+	fill_register	%l4
+	fill_register	%l5
+	fill_register	%l6
+	fill_register	%l7
+	fill_register	%i0
+	fill_register	%i1
+	fill_register	%i2
+	fill_register	%i3
+	fill_register	%i4
+	fill_register	%i5
+	/* Don't fill register $i6 => frame pointer */
+	fill_register	%i7
+	fill_register	%y
+	/* g3 checks if the Floating Point Unit in the Processor Status
+	   Register (PSR) is set */
+	mov	%psr, %g3
+	sethi	%hi(4096), %g4
+	and	%g3, %g4, %g3
+	cmp	%g3, 0
+	be	check
+	 nop
+.macro fill_float_register reg
+	add	%g1, 1, %g1
+	st	%g1, [%sp+BUFFER_STORAGE]
+	ld	[%sp+BUFFER_STORAGE], \reg
+.endm
+	fill_float_register	%f0
+	fill_float_register	%f1
+	fill_float_register	%f2
+	fill_float_register	%f3
+	fill_float_register	%f4
+	fill_float_register	%f5
+	fill_float_register	%f6
+	fill_float_register	%f7
+	fill_float_register	%f8
+	fill_float_register	%f9
+	fill_float_register	%f10
+	fill_float_register	%f11
+	fill_float_register	%f12
+	fill_float_register	%f13
+	fill_float_register	%f14
+	fill_float_register	%f15
+	fill_float_register	%f16
+	fill_float_register	%f17
+	fill_float_register	%f18
+	fill_float_register	%f19
+	fill_float_register	%f20
+	fill_float_register	%f21
+	fill_float_register	%f22
+	fill_float_register	%f23
+	fill_float_register	%f24
+	fill_float_register	%f25
+	fill_float_register	%f26
+	fill_float_register	%f27
+	fill_float_register	%f28
+	fill_float_register	%f29
+	fill_float_register	%f30
+	fill_float_register	%f31
+	/* Check normal registers*/
+check:
+.macro check_register reg
+	add	%g1, 1, %g1
+	cmp	%g1, \reg
+	bne	restore
+	 nop
+.endm
+	cmp	%g2, %sp
+	bne	restore
+	 mov	%o0, %g1
+	fill_register	%o1
+	mov	%o0, %g1
+	check_register	%o1
+	check_register	%o2
+	check_register	%o3
+	check_register	%o4
+	check_register	%o5
+	check_register	%l0
+	check_register	%l1
+	check_register	%l2
+	check_register	%l3
+	check_register	%l4
+	check_register	%l5
+	check_register	%l6
+	check_register	%l7
+	check_register	%i0
+	check_register	%i1
+	check_register	%i2
+	check_register	%i3
+	check_register	%i4
+	check_register	%i5
+	check_register	%i7
+	/* Check special purpose register Y */
+	mov	%y, %o1
+	cmp	%g3, 0
+	bne	check_float
+	 nop
+	be	check
+	 nop
+	/* Restore non-volatile registers */
+restore:
+	ld	[%sp + FRAME_OFFSET_L0], %l0
+	ld	[%sp + FRAME_OFFSET_L1], %l1
+	ld	[%sp + FRAME_OFFSET_L2], %l2
+	ld	[%sp + FRAME_OFFSET_L3], %l3
+	ld	[%sp + FRAME_OFFSET_L4], %l4
+	ld	[%sp + FRAME_OFFSET_L5], %l5
+	ld	[%sp + FRAME_OFFSET_L6], %l6
+	ld	[%sp + FRAME_OFFSET_L7], %l7
+	ld	[%sp + FRAME_OFFSET_I0], %i0
+	ld	[%sp + FRAME_OFFSET_I1], %i1
+	ld	[%sp + FRAME_OFFSET_I2], %i2
+	ld	[%sp + FRAME_OFFSET_I3], %i3
+	ld	[%sp + FRAME_OFFSET_I4], %i4
+	ld	[%sp + FRAME_OFFSET_I5], %i5
+	ld	[%sp + FRAME_OFFSET_I6], %i6
+	ld	[%sp + FRAME_OFFSET_I7], %i7
+	/* Load callback address and jump back*/
+	ld	[%sp + FRAME_OFFSET_O7], %o7
+	jmp	%o7+8
+	 add	%sp, FRAME_SIZE, %sp
+	/* Check floating-point registers */
+check_float:
+.macro check_float_register reg
+	add	%g1, 1, %g1
+	st	\reg, [%sp+BUFFER_STORAGE]
+	ld	[%sp+BUFFER_STORAGE], %o1
+	cmp	%g1, %o1
+	bne	restore
+	 nop
+.endm
+	check_float_register	%f0
+	check_float_register	%f1
+	check_float_register	%f2
+	check_float_register	%f3
+	check_float_register	%f4
+	check_float_register	%f5
+	check_float_register	%f6
+	check_float_register	%f7
+	check_float_register	%f8
+	check_float_register	%f9
+	check_float_register	%f10
+	check_float_register	%f11
+	check_float_register	%f12
+	check_float_register	%f13
+	check_float_register	%f14
+	check_float_register	%f15
+	check_float_register	%f16
+	check_float_register	%f17
+	check_float_register	%f18
+	check_float_register	%f19
+	check_float_register	%f20
+	check_float_register	%f21
+	check_float_register	%f22
+	check_float_register	%f23
+	check_float_register	%f24
+	check_float_register	%f25
+	check_float_register	%f26
+	check_float_register	%f27
+	check_float_register	%f28
+	check_float_register	%f29
+	check_float_register	%f30
+	check_float_register	%f31
+	mov	%o0, %g1
+	fill_register	%o1
+	b	check
+	 nop
diff --git a/cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S b/cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
index 0000000..b30a303
--- /dev/null
+++ b/cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
@@ -0,0 +1,92 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#endif
+#include <rtems/system.h>
+        .align 4
+        PUBLIC(_CPU_Context_volatile_clobber)
+SYM(_CPU_Context_volatile_clobber):
+.macro clobber_register reg
+	sub	%o0, 1, %o0
+	mov	%o0, \reg
+.endm
+.macro clobber_fp_register reg
+	sub	%o0, 1, %o0
+	st	%o0, [%sp+72]
+	ld	[%sp+72], \reg
+.endm
+	add	%sp, -80, %sp
+	st	%o7, [%sp+76]
+	clobber_register	%o1
+	clobber_register	%o2
+	clobber_register	%o3
+	clobber_register	%o4
+	clobber_register	%o5
+	clobber_register	%o7
+	clobber_register	%y
+	mov	%psr, %o1
+	sethi	%hi(4096), %o2
+	and 	%o1, %o2, %o2
+	cmp	%o2, 0
+	be	clobber_return
+	 nop
+	clobber_fp_register	%f0
+	clobber_fp_register	%f1
+	clobber_fp_register	%f2
+	clobber_fp_register	%f3
+	clobber_fp_register	%f4
+	clobber_fp_register	%f5
+	clobber_fp_register	%f6
+	clobber_fp_register	%f7
+	clobber_fp_register	%f8
+	clobber_fp_register	%f9
+	clobber_fp_register	%f10
+	clobber_fp_register	%f11
+	clobber_fp_register	%f12
+	clobber_fp_register	%f13
+	clobber_fp_register	%f14
+	clobber_fp_register	%f15
+	clobber_fp_register	%f16
+	clobber_fp_register	%f17
+	clobber_fp_register	%f18
+	clobber_fp_register	%f19
+	clobber_fp_register	%f20
+	clobber_fp_register	%f21
+	clobber_fp_register	%f22
+	clobber_fp_register	%f23
+	clobber_fp_register	%f24
+	clobber_fp_register	%f25
+	clobber_fp_register	%f26
+	clobber_fp_register	%f27
+	clobber_fp_register	%f28
+	clobber_fp_register	%f29
+	clobber_fp_register	%f30
+	clobber_fp_register	%f31
+clobber_return:
+	ld	[%sp+76], %o7
+	jmp	%o7+8
+	 add	%sp, 80, %sp
1.8.4.5
