[PATCH 2/2] SPCONTEXT01: checks correct switching on and off of the Floating Point Unit
Thu Apr 30 14:47:38 UTC 2015
Should fp validation be a separate test from integer reg validation to
ensure int-only works as expected?
On Thu, Apr 30, 2015 at 5:38 AM, Alexander Krutwig
<alexander.krutwig at embedded-brains.de> wrote:
>  testsuites/sptests/spcontext01/init.c | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/testsuites/sptests/spcontext01/init.c b/testsuites/sptests/spcontext01/init.c
> index 039dd63..3406367 100644
> --- a/testsuites/sptests/spcontext01/init.c
> +++ b/testsuites/sptests/spcontext01/init.c
> @@ -56,7 +56,7 @@ static void start_validate_task(
>      priority,
>      RTEMS_MINIMUM_STACK_SIZE,
>      RTEMS_DEFAULT_MODES,
> -    RTEMS_DEFAULT_ATTRIBUTES,
> +    RTEMS_FLOATING_POINT,
>      id
>    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> 1.8.4.5
> devel mailing list
> devel at rtems.org
