[PATCH 3/4] new rtems environment with the implementation of FreeBSD timecounters; modifications of certain tests in the testsuite New test: timecounter02
Gedare Bloom
gedare at rtems.org
Wed Apr 1 15:01:42 UTC 2015
I didn't read much of this, but it needs doxygen, and probably part of
the previous patch should be merged in here, or some better
splitting/recombining of patches so I don't have to review code that
gets fixed. It's worth repeating, the "rtems_*time" functions are not
following the API conventions of rtems_package_method, it should be
rtems_timecounter_*time like rtems_timecounter_bintime.
Please use a short git-commit message for the first line, and longer
git commit message after a blank line. This will avoid really long
lines in git log, and long subjects in git-send-email. I guess this
advice is in the Git page
(https://devel.rtems.org/wiki/Developer/Git).
Gedare
On Wed, Apr 1, 2015 at 10:37 AM, Alexander Krutwig
<alexander.krutwig at embedded-brains.de> wrote:
> cpukit/libnetworking/rtems/rtems_bsdnet_internal.h | 3 +-
> cpukit/libnetworking/rtems/rtems_glue.c | 4 -
> cpukit/posix/src/clockgettime.c | 3 +-
> cpukit/posix/src/posixtimespecabsolutetimeout.c | 2 +-
> cpukit/posix/src/timergettime.c | 2 +-
> cpukit/posix/src/timersettime.c | 4 +-
> cpukit/posix/src/timertsr.c | 2 +-
> cpukit/rtems/Makefile.am | 1 -
> cpukit/rtems/include/rtems/rtems/clock.h | 25 --
> cpukit/rtems/src/clockgetuptimenanoseconds.c | 9 +-
> cpukit/rtems/src/clockgetuptimeseconds.c | 6 +-
> cpukit/rtems/src/clocksetnsecshandler.c | 34 --
> cpukit/sapi/Makefile.am | 1 +
> cpukit/sapi/include/rtems/timecounter.h | 89 +++++
> cpukit/sapi/preinstall.am | 4 +
> cpukit/sapi/src/exinit.c | 3 +
> cpukit/score/Makefile.am | 18 +-
> cpukit/score/include/rtems/score/timecounter.h | 59 +++-
> cpukit/score/include/rtems/score/timecounterimpl.h | 119 +++++++
> cpukit/score/include/rtems/score/timestamp.h | 267 ++++++++-------
> cpukit/score/include/rtems/score/timestamp64.h | 379 ---------------------
> cpukit/score/include/rtems/score/tod.h | 9 -
> cpukit/score/include/rtems/score/todimpl.h | 101 ++----
> cpukit/score/preinstall.am | 10 +-
> cpukit/score/src/coretod.c | 18 +-
> cpukit/score/src/coretodadjust.c | 9 +-
> cpukit/score/src/coretodget.c | 46 ---
> cpukit/score/src/coretodgetuptimetimespec.c | 32 --
> cpukit/score/src/coretodsecondssinceepoch.c | 32 --
> cpukit/score/src/coretodset.c | 10 +-
> cpukit/score/src/coretodtickle.c | 22 +-
> cpukit/score/src/tcgetscalerandmask.c | 40 +++
> cpukit/score/src/ts64addto.c | 31 --
> cpukit/score/src/ts64divide.c | 51 ---
> cpukit/score/src/ts64equalto.c | 31 --
> cpukit/score/src/ts64getnanoseconds.c | 30 --
> cpukit/score/src/ts64getseconds.c | 30 --
> cpukit/score/src/ts64lessthan.c | 31 --
> cpukit/score/src/ts64set.c | 33 --
> cpukit/score/src/ts64settozero.c | 31 --
> cpukit/score/src/ts64subtract.c | 31 --
> cpukit/score/src/ts64totimespec.c | 32 --
> cpukit/score/src/ts64totimeval.c | 37 --
> testsuites/sptests/Makefile.am | 2 +
> testsuites/sptests/configure.ac | 2 +
> testsuites/sptests/spclock_err01/init.c | 8 -
> testsuites/sptests/spsize/size.c | 3 -
> testsuites/sptests/sptimecounter02/Makefile.am | 19 ++
> testsuites/sptests/sptimecounter02/init.c | 266 +++++++++++++++
> .../sptests/sptimecounter02/sptimecounter02.doc | 11 +
> .../sptests/sptimecounter02/sptimecounter02.scn | 0
> 51 files changed, 818 insertions(+), 1224 deletions(-)
> delete mode 100644 cpukit/rtems/src/clocksetnsecshandler.c
> create mode 100644 cpukit/sapi/include/rtems/timecounter.h
> create mode 100644 cpukit/score/include/rtems/score/timecounterimpl.h
> delete mode 100644 cpukit/score/include/rtems/score/timestamp64.h
> delete mode 100644 cpukit/score/src/coretodget.c
> delete mode 100644 cpukit/score/src/coretodgetuptimetimespec.c
> delete mode 100644 cpukit/score/src/coretodsecondssinceepoch.c
> create mode 100644 cpukit/score/src/tcgetscalerandmask.c
> delete mode 100644 cpukit/score/src/ts64addto.c
> delete mode 100644 cpukit/score/src/ts64divide.c
> delete mode 100644 cpukit/score/src/ts64equalto.c
> delete mode 100644 cpukit/score/src/ts64getnanoseconds.c
> delete mode 100644 cpukit/score/src/ts64getseconds.c
> delete mode 100644 cpukit/score/src/ts64lessthan.c
> delete mode 100644 cpukit/score/src/ts64set.c
> delete mode 100644 cpukit/score/src/ts64settozero.c
> delete mode 100644 cpukit/score/src/ts64subtract.c
> delete mode 100644 cpukit/score/src/ts64totimespec.c
> delete mode 100644 cpukit/score/src/ts64totimeval.c
> create mode 100644 testsuites/sptests/sptimecounter02/Makefile.am
> create mode 100644 testsuites/sptests/sptimecounter02/init.c
> create mode 100644 testsuites/sptests/sptimecounter02/sptimecounter02.doc
> create mode 100644 testsuites/sptests/sptimecounter02/sptimecounter02.scn
> diff --git a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
> index fc0370c..01562b1 100644
> --- a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
> +++ b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
> @@ -12,6 +12,7 @@
> #include <rtems.h>
> #include <rtems/fs.h>
> +#include <rtems/timecounter.h>
> #ifdef __cplusplus
> extern "C" {
> @@ -61,7 +62,7 @@ void *memset(void *s, int c, size_t n);
> #define panic rtems_panic
> #define suser(a,b) 0
> -void microtime(struct timeval *tv);
> +#define microtime(tv) rtems_microtime(tv)
> #define hz rtems_bsdnet_ticks_per_second
> #define tick rtems_bsdnet_microseconds_per_tick
> diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
> index f05530e..0a42f97 100644
> --- a/cpukit/libnetworking/rtems/rtems_glue.c
> +++ b/cpukit/libnetworking/rtems/rtems_glue.c
> @@ -1344,7 +1344,3 @@ m_clalloc(int ncl, int nowait)
> return 1;
> - rtems_clock_get_uptime_timeval(tv);
> diff --git a/cpukit/posix/src/clockgettime.c b/cpukit/posix/src/clockgettime.c
> index 2838ba6..06cafa5 100644
> --- a/cpukit/posix/src/clockgettime.c
> +++ b/cpukit/posix/src/clockgettime.c
> @@ -37,7 +37,8 @@ int clock_gettime(
> rtems_set_errno_and_return_minus_one( EINVAL );
> if ( clock_id == CLOCK_REALTIME ) {
> - _TOD_Get(tp);
> + _TOD_Get_as_timespec(tp);
> return 0;
> #ifdef CLOCK_MONOTONIC
> diff --git a/cpukit/posix/src/posixtimespecabsolutetimeout.c b/cpukit/posix/src/posixtimespecabsolutetimeout.c
> index 32da45f..f302986 100644
> --- a/cpukit/posix/src/posixtimespecabsolutetimeout.c
> +++ b/cpukit/posix/src/posixtimespecabsolutetimeout.c
> @@ -57,7 +57,7 @@ POSIX_Absolute_timeout_conversion_results_t _POSIX_Absolute_timeout_to_ticks(
> * Is the absolute time in the past?
> - _TOD_Get( ¤t_time );
> + _TOD_Get_as_timespec( ¤t_time );
> if ( _Timespec_Less_than( abstime, ¤t_time ) )
> return POSIX_ABSOLUTE_TIMEOUT_IS_IN_PAST;
> diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
> index 2a810ef..f065cc9 100644
> --- a/cpukit/posix/src/timergettime.c
> +++ b/cpukit/posix/src/timergettime.c
> @@ -49,7 +49,7 @@ int timer_gettime(
> /* Reads the current time */
> ptimer = _POSIX_Timer_Get( timerid, &location );
> switch ( location ) {
> diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
> index 6cc3780..4d2af5d 100644
> --- a/cpukit/posix/src/timersettime.c
> +++ b/cpukit/posix/src/timersettime.c
> @@ -66,7 +66,7 @@ int timer_settime(
> /* Convert absolute to relative time */
> if (flags == TIMER_ABSTIME) {
> struct timespec now;
> - _TOD_Get( &now );
> + _TOD_Get_as_timespec( &now );
> /* Check for seconds in the past */
> if ( _Timespec_Greater_than( &now, &normalize.it_value ) )
> @@ -125,7 +125,7 @@ int timer_settime(
> /* Indicate that the time is running */
> ptimer->state = POSIX_TIMER_STATE_CREATE_RUN;
> - _TOD_Get( &ptimer->time );
> + _TOD_Get_as_timespec( &ptimer->time );
> _Objects_Put( &ptimer->Object );
> return 0;
> diff --git a/cpukit/posix/src/timertsr.c b/cpukit/posix/src/timertsr.c
> index 8555463..512dd06 100644
> --- a/cpukit/posix/src/timertsr.c
> +++ b/cpukit/posix/src/timertsr.c
> @@ -58,7 +58,7 @@ void _POSIX_Timer_TSR(
> return;
> /* Store the time when the timer was started again */
> /* The state really did not change but just to be safe */
> diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
> index 5e6f2ea..1af8536 100644
> --- a/cpukit/rtems/Makefile.am
> +++ b/cpukit/rtems/Makefile.am
> @@ -158,7 +158,6 @@ librtems_a_SOURCES += src/clockgetuptimetimeval.c
> librtems_a_SOURCES += src/clockgetuptimeseconds.c
> librtems_a_SOURCES += src/clockgetuptimenanoseconds.c
> librtems_a_SOURCES += src/clockset.c
> -librtems_a_SOURCES += src/clocksetnsecshandler.c
> librtems_a_SOURCES += src/clocktick.c
> librtems_a_SOURCES += src/clocktodtoseconds.c
> librtems_a_SOURCES += src/clocktodvalidate.c
> diff --git a/cpukit/rtems/include/rtems/rtems/clock.h b/cpukit/rtems/include/rtems/rtems/clock.h
> index 2a1c772..89750cf 100644
> --- a/cpukit/rtems/include/rtems/rtems/clock.h
> +++ b/cpukit/rtems/include/rtems/rtems/clock.h
> @@ -14,7 +14,6 @@
> * - set the current date and time
> * - obtain the current date and time
> - * - set the nanoseconds since last clock tick handler
> * - announce a clock tick
> * - obtain the system uptime
> @@ -69,12 +68,6 @@ typedef enum {
> } rtems_clock_get_options;
> - * Type for the nanoseconds since last tick BSP extension.
> -typedef TOD_Nanoseconds_since_last_tick_routine
> - rtems_nanoseconds_extension_routine;
> * @brief Obtain Current Time of Day
> * @deprecated rtems_clock_get() is deprecated. Use the more explicit
> @@ -279,24 +272,6 @@ rtems_status_code rtems_clock_set(
> rtems_status_code rtems_clock_tick( void );
> - * @brief Set the BSP specific Nanoseconds Extension
> - * Clock Manager
> - * This directive sets the BSP provided nanoseconds since last tick
> - * extension.
> - * @param[in] routine is a pointer to the extension routine
> - * @return This method returns RTEMS_SUCCESSFUL if there was not an
> - * error. Otherwise, a status code is returned indicating the
> - * source of the error.
> -rtems_status_code rtems_clock_set_nanoseconds_extension(
> - rtems_nanoseconds_extension_routine routine
> * @brief Obtain the System Uptime
> * This directive returns the system uptime.
> diff --git a/cpukit/rtems/src/clockgetuptimenanoseconds.c b/cpukit/rtems/src/clockgetuptimenanoseconds.c
> index 0310e59..d43f672 100644
> --- a/cpukit/rtems/src/clockgetuptimenanoseconds.c
> +++ b/cpukit/rtems/src/clockgetuptimenanoseconds.c
> @@ -23,13 +23,8 @@
> uint64_t rtems_clock_get_uptime_nanoseconds( void )
> Timestamp_Control snapshot_as_timestamp;
> - uint32_t nanoseconds;
> - ISR_lock_Context lock_context;
> - _TOD_Acquire( &_TOD, &lock_context );
> - snapshot_as_timestamp = _TOD.uptime;
> - nanoseconds = ( *_TOD.nanoseconds_since_last_tick )();
> - _TOD_Release( &_TOD, &lock_context );
> + _TOD_Get_uptime(&snapshot_as_timestamp);
> - return _Timestamp_Get_As_nanoseconds( &snapshot_as_timestamp, nanoseconds );
> + return _Timestamp_Get_nanoseconds(&snapshot_as_timestamp);
> diff --git a/cpukit/rtems/src/clockgetuptimeseconds.c b/cpukit/rtems/src/clockgetuptimeseconds.c
> index 0312921..5c6b57c 100644
> --- a/cpukit/rtems/src/clockgetuptimeseconds.c
> +++ b/cpukit/rtems/src/clockgetuptimeseconds.c
> @@ -28,14 +28,10 @@
> time_t rtems_clock_get_uptime_seconds( void )
> - TOD_Control *tod = &_TOD;
> struct timespec snapshot_as_timespec;
> - _TOD_Acquire( tod, &lock_context );
> - snapshot_as_timestamp = tod->uptime;
> - _TOD_Release( tod, &lock_context );
> _Timestamp_To_timespec( &snapshot_as_timestamp, &snapshot_as_timespec );
> diff --git a/cpukit/rtems/src/clocksetnsecshandler.c b/cpukit/rtems/src/clocksetnsecshandler.c
> deleted file mode 100644
> index ae08246..0000000
> --- a/cpukit/rtems/src/clocksetnsecshandler.c
> +++ /dev/null
> @@ -1,34 +0,0 @@
> - * @file
> - * @ingroup ClassicClock Clocks
> - * COPYRIGHT (c) 1989-2006.
> - * On-Line Applications Research Corporation (OAR).
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> -#if HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <rtems/rtems/clock.h>
> -#include <rtems/score/todimpl.h>
> - if ( !routine )
> - return RTEMS_INVALID_ADDRESS;
> - _TOD_Set_nanoseconds_since_last_tick_handler( routine );
> - return RTEMS_SUCCESSFUL;
> diff --git a/cpukit/sapi/Makefile.am b/cpukit/sapi/Makefile.am
> index 070800e..17f0e4f 100644
> --- a/cpukit/sapi/Makefile.am
> +++ b/cpukit/sapi/Makefile.am
> @@ -19,6 +19,7 @@ include_rtems_HEADERS += include/rtems/rbheap.h
> include_rtems_HEADERS += include/rtems/rbtree.h
> include_rtems_HEADERS += include/rtems/scheduler.h
> include_rtems_HEADERS += include/rtems/sptables.h
> +include_rtems_HEADERS += include/rtems/timecounter.h
> include_rtems_HEADERS += include/rtems/timespec.h
> EXTRA_DIST = include/rtems/README
> diff --git a/cpukit/sapi/include/rtems/timecounter.h b/cpukit/sapi/include/rtems/timecounter.h
> new file mode 100644
> index 0000000..a496e64
> --- /dev/null
> +++ b/cpukit/sapi/include/rtems/timecounter.h
> @@ -0,0 +1,89 @@
> + * Copyright (c) 2015 embedded brains GmbH. All rights reserved.
> + * embedded brains GmbH
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> + * <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#ifndef _RTEMS_TIMECOUNTER_H
> +#define _RTEMS_TIMECOUNTER_H
> +#include <rtems/score/timecounter.h>
> +#include <rtems/score/basedefs.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +RTEMS_INLINE_ROUTINE void rtems_bintime( struct bintime *bt )
> + _Timecounter_Bintime( bt );
> +RTEMS_INLINE_ROUTINE void rtems_nanotime( struct timespec *ts )
> + _Timecounter_Nanotime( ts );
> +RTEMS_INLINE_ROUTINE void rtems_microtime( struct timeval *tv )
> + _Timecounter_Microtime( tv );
> +RTEMS_INLINE_ROUTINE void rtems_binuptime( struct bintime *bt )
> + _Timecounter_Binuptime( bt );
> +RTEMS_INLINE_ROUTINE void rtems_nanouptime( struct timespec *ts )
> + _Timecounter_Nanouptime( ts );
> +RTEMS_INLINE_ROUTINE void rtems_microuptime( struct timeval *tv )
> + _Timecounter_Microuptime( tv );
> +RTEMS_INLINE_ROUTINE void rtems_getbintime( struct bintime *bt )
> + _Timecounter_Getbintime( bt );
> +RTEMS_INLINE_ROUTINE void rtems_getnanotime( struct timespec *ts )
> + _Timecounter_Getnanotime( ts );
> +RTEMS_INLINE_ROUTINE void rtems_getmicrotime( struct timeval *tv )
> + _Timecounter_Getmicrotime( tv );
> +RTEMS_INLINE_ROUTINE void rtems_getbinuptime( struct bintime *bt )
> + _Timecounter_Getbinuptime( bt );
> +RTEMS_INLINE_ROUTINE void rtems_getnanouptime( struct timespec *ts )
> + _Timecounter_Getnanouptime( ts );
> +RTEMS_INLINE_ROUTINE void rtems_getmicrouptime( struct timeval *tv )
> + _Timecounter_Getmicrouptime( tv );
> +#ifdef __cplusplus
> +#endif /* _RTEMS_TIMECOUNTER_H */
> diff --git a/cpukit/sapi/preinstall.am b/cpukit/sapi/preinstall.am
> index 3f864bb..4509842 100644
> --- a/cpukit/sapi/preinstall.am
> +++ b/cpukit/sapi/preinstall.am
> @@ -82,6 +82,10 @@ $(PROJECT_INCLUDE)/rtems/sptables.h: include/rtems/sptables.h $(PROJECT_INCLUDE)
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/sptables.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/sptables.h
> +$(PROJECT_INCLUDE)/rtems/timecounter.h: include/rtems/timecounter.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/timecounter.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/timecounter.h
> $(PROJECT_INCLUDE)/rtems/timespec.h: include/rtems/timespec.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/timespec.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/timespec.h
> diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
> index 235ba77..5c265a6 100644
> --- a/cpukit/sapi/src/exinit.c
> +++ b/cpukit/sapi/src/exinit.c
> @@ -44,6 +44,7 @@
> #include <rtems/score/priority.h>
> #include <rtems/score/schedulerimpl.h>
> #include <rtems/score/smpimpl.h>
> #include <rtems/score/threadimpl.h>
> #include <rtems/score/userextimpl.h>
> @@ -69,6 +70,8 @@ void rtems_initialize_data_structures(void)
> * are disabled by boot_card().
> + _Timecounter_Initialize();
> #if defined(RTEMS_MULTIPROCESSING)
> * Initialize the system state based on whether this is an MP system.
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index 55fdc99..596df68 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -94,7 +94,8 @@ include_rtems_score_HEADERS += include/rtems/score/threadqimpl.h
> include_rtems_score_HEADERS += include/rtems/score/threadsync.h
> include_rtems_score_HEADERS += include/rtems/score/timespec.h
> include_rtems_score_HEADERS += include/rtems/score/timestamp.h
> -include_rtems_score_HEADERS += include/rtems/score/timestamp64.h
> +include_rtems_score_HEADERS += include/rtems/score/timecounter.h
> +include_rtems_score_HEADERS += include/rtems/score/timecounterimpl.h
> include_rtems_score_HEADERS += include/rtems/score/tls.h
> include_rtems_score_HEADERS += include/rtems/score/tod.h
> include_rtems_score_HEADERS += include/rtems/score/todimpl.h
> @@ -317,18 +318,10 @@ libscore_a_SOURCES += src/timespecaddto.c src/timespecfromticks.c \
> src/timespecsubtract.c src/timespectoticks.c src/timespecdivide.c \
> src/timespecdividebyinteger.c src/timespecgetasnanoseconds.c
> -## TIMESTAMP_INT64_C_FILES
> -libscore_a_SOURCES += src/ts64addto.c \
> - src/ts64divide.c src/ts64equalto.c \
> - src/ts64getnanoseconds.c src/ts64getseconds.c \
> - src/ts64lessthan.c \
> - src/ts64set.c src/ts64settozero.c src/ts64subtract.c \
> - src/ts64totimespec.c src/ts64totimeval.c
> ## TOD_C_FILES
> -libscore_a_SOURCES += src/coretod.c src/coretodset.c src/coretodget.c \
> - src/coretodgetuptimetimespec.c src/coretodtickle.c \
> - src/coretodsecondssinceepoch.c src/coretodtickspersec.c \
> +libscore_a_SOURCES += src/coretod.c src/coretodset.c \
> + src/coretodtickle.c \
> + src/coretodtickspersec.c \
> src/coretodadjust.c
> ## WATCHDOG_C_FILES
> @@ -353,6 +346,7 @@ libscore_a_SOURCES += src/once.c
> libscore_a_SOURCES += src/resourceiterate.c
> libscore_a_SOURCES += src/smpbarrierwait.c
> libscore_a_SOURCES += src/kern_tc.c
> +libscore_a_SOURCES += src/tcgetscalerandmask.c
> EXTRA_DIST = src/Unlimited.txt
> diff --git a/cpukit/score/include/rtems/score/timecounter.h b/cpukit/score/include/rtems/score/timecounter.h
> index 3744a76..bae5851 100644
> --- a/cpukit/score/include/rtems/score/timecounter.h
> +++ b/cpukit/score/include/rtems/score/timecounter.h
> @@ -1,23 +1,52 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef _RTEMS_SCORE_TIMECOUNTER_H
> +#define _RTEMS_SCORE_TIMECOUNTER_H
> #include <sys/time.h>
> -void _Timecounter_Initialize(void);
> +#ifdef __cplusplus
> +extern "C" {
> +void _Timecounter_Bintime( struct bintime *bt );
> +void _Timecounter_Nanotime( struct timespec *ts );
> +void _Timecounter_Microtime( struct timeval *tv );
> +void _Timecounter_Binuptime( struct bintime *bt );
> +void _Timecounter_Nanouptime( struct timespec *ts );
> +void _Timecounter_Microuptime( struct timeval *tv );
> +void _Timecounter_Getbintime( struct bintime *bt );
> +void _Timecounter_Getnanotime( struct timespec *ts );
> +void _Timecounter_Getmicrotime( struct timeval *tv );
> -void _Timecounter_Set_clock(const struct timespec *ts);
> +void _Timecounter_Getbinuptime( struct bintime *bt );
> -void _Timecounter_Ticktock(int cnt);
> +void _Timecounter_Getnanouptime( struct timespec *ts );
> -void rtems_bintime(struct bintime *bt);
> -void rtems_nanotime(struct timespec *tsp);
> -void rtems_microtime(struct timeval *tvp);
> -void rtems_binuptime(struct bintime *bt);
> -void rtems_nanouptime(struct timespec *tsp);
> -void rtems_microuptime(struct timeval *tvp);
> -void rtems_getbintime(struct bintime *bt);
> -void rtems_getnanotime(struct timespec *tsp);
> -void rtems_getmicrotime(struct timeval *tvp);
> -void rtems_getbinuptime(struct bintime *bt);
> -void rtems_getnanouptime(struct timespec *tsp);
> -void rtems_getmicrouptime(struct timeval *tvp);
> +void _Timecounter_Getmicrouptime( struct timeval *tv );
> +#ifdef __cplusplus
> +#endif /* _RTEMS_SCORE_TIMECOUNTER_H */
> diff --git a/cpukit/score/include/rtems/score/timecounterimpl.h b/cpukit/score/include/rtems/score/timecounterimpl.h
> index 0000000..5987672
> --- /dev/null
> +++ b/cpukit/score/include/rtems/score/timecounterimpl.h
> @@ -0,0 +1,119 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifndef _RTEMS_SCORE_TIMECOUNTERIMPL_H
> +#define _RTEMS_SCORE_TIMECOUNTERIMPL_H
> +#include <sys/timetc.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#define TIMECOUNTER_DEFAULT_DRIVER_QUALITY 100
> + * @brief Starts the initialization of the timecounter.
> + * This routine sets hardclock ticks per milliseconds and assigns to the
> + * timecounters where to get the timecount information for each windup() call.
> +void _Timecounter_Initialize(void);
> + * @brief Sets the clock of the timecounter.
> + * This routine converts an input timespec into a bintime which is then set in
> + * the timecounter.
> + * @param[in] ts is a timespec for conversion.
> +void _Timecounter_Set_clock(const struct timespec *ts);
> + * @brief Sets up the ring of timecounters.
> + * This routine installs a "ring" of minimum one timecounter in the format of
> + * the input and calls the windup function afterwards.
> + * @param[in] tc is the timecounter instance of which the ring should be
> + * created.
> + * @code tc->tc_next = timecounters;
> + * timecounters = tc;
> + * (void)tc->tc_get_timecount(tc);
> + * tc_windup();
> + * @endcode
> +void _Timecounter_Install(struct timecounter *tc);
> + * @brief Interrupt Routine that triggers a windup call.
> + * Usage for timecount registers that run on binary basis.
> +void _Timecounter_Tick(void);
> + * @brief Interrupt Routine that cannot trigger a windup call.
> + * This routine is needed for a get_timecounter request where the information
> + * is received from a real time clock register that does not offer a binary
> + * basis. Here the bintime offset is generated by giving the delta and offset
> + * parameters as inputs.
> + * @param[in] delta is one timecounter interval + time from the start of the
> + * new interval.
> + * @param[in] offset is the time from the start of the new interval.
> + * @code
> + * th = timehands;
> + * ogen = th->th_generation;
> + * th->th_offset_count = offset;
> + * bintime_addx(&th->th_offset, th->th_scale * delta);
> + * @endcode
> +void _Timecounter_Tick_simple(u_int delta, u_int offset);
> + * @brief creates scaler and mask for _Timecounter_Tick_simple.
> + * Calculates the scaler and mask of the next upcoming power of 2. The scaler
> + * is the next power of 2 divided by the counter_ticks_per_clock_ticks. The
> + * mask is double the next power of 2 minus 1, as the timecounter can return a
> + * maximum value of the length of two intervals.
> + * @param[in] counter_ticks_per_clock_tick
> + * @param[out] scaler is the value of the scaling factor which has to imposed
> + * on the values returned by the get_timecount information
> + * @param[out] mask is the value of double the next power of 2 minus 1
> +void _Timecounter_Get_binary_scaler_and_mask(
> + uint32_t counter_ticks_per_clock_tick,
> + uint64_t *scaler,
> + uint32_t *mask
> +#ifdef __cplusplus
> +#endif /* _RTEMS_SCORE_TIMECOUNTERIMPL_H */
> diff --git a/cpukit/score/include/rtems/score/timestamp.h b/cpukit/score/include/rtems/score/timestamp.h
> index dbd0425..056976b 100644
> --- a/cpukit/score/include/rtems/score/timestamp.h
> +++ b/cpukit/score/include/rtems/score/timestamp.h
> @@ -42,55 +42,45 @@
> -#include <rtems/score/cpu.h>
> -#include <rtems/score/timespec.h>
> +#include "timespec.h"
> #ifdef __cplusplus
> extern "C" {
> #endif
> -#if ! ( ( CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == TRUE \
> - && CPU_TIMESTAMP_USE_INT64 == FALSE \
> - && CPU_TIMESTAMP_USE_INT64_INLINE == FALSE ) \
> - || ( CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == FALSE \
> - && CPU_TIMESTAMP_USE_INT64 == TRUE \
> - && CPU_TIMESTAMP_USE_INT64_INLINE == TRUE ) )
> - #error "Invalid SuperCore Timestamp implementations selection."
> -#endif
> -#if CPU_TIMESTAMP_USE_INT64 == TRUE || CPU_TIMESTAMP_USE_INT64_INLINE == TRUE
> - #include <rtems/score/timestamp64.h>
> -#endif
> +#define MICROSECONDS_PER_SECOND 1000000
> +#define NANOSECONDS_PER_SECOND 1000000000
> * Define the Timestamp control type.
> -#if CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == TRUE
> - typedef struct timespec Timestamp_Control;
> -#else
> - typedef Timestamp64_Control Timestamp_Control;
> -#endif
> +typedef struct bintime Timestamp_Control;
> * @brief Set timestamp to specified seconds and nanoseconds.
> - * This method sets the timestamp to the specified @a _seconds and @a _nanoseconds
> - * value.
> + * This method sets the timestamp to the specified @a _seconds and
> + * @a _nanoseconds value.
> * @param[in] _time points to the timestamp instance to validate.
> * @param[in] _seconds is the seconds portion of the timestamp
> * @param[in] _nanoseconds is the nanoseconds portion of the timestamp
> - #define _Timestamp_Set( _time, _seconds, _nanoseconds ) \
> - _Timespec_Set( _time, _seconds, _nanoseconds )
> -#else
> - _Timestamp64_Set( _time, _seconds, _nanoseconds )
> -#endif
> +RTEMS_INLINE_ROUTINE void _Timestamp_Set(
> + Timestamp_Control *_time,
> + time_t _seconds,
> + long _nanoseconds
> + struct timespec _ts;
> + _ts.tv_sec = _seconds;
> + _ts.tv_nsec = _nanoseconds;
> + timespec2bintime(&_ts, _time);
> * @brief Sets the timestamp to zero.
> @@ -100,13 +90,14 @@ extern "C" {
> * @param[in] _time points to the timestamp instance to zero.
> - #define _Timestamp_Set_to_zero( _time ) \
> - _Timespec_Set_to_zero( _time )
> -#else
> - _Timestamp64_Set_to_zero( _time )
> -#endif
> +RTEMS_INLINE_ROUTINE void _Timestamp_Set_to_zero(
> + _time->sec = 0;
> + _time->frac = 0;
> * @brief Less than operator for timestamps.
> @@ -119,13 +110,23 @@ extern "C" {
> * @retval This method returns true if @a _lhs is less than the @a _rhs and
> * false otherwise.
> - #define _Timestamp_Less_than( _lhs, _rhs ) \
> - _Timespec_Less_than( _lhs, _rhs )
> -#else
> - _Timestamp64_Less_than( _lhs, _rhs )
> -#endif
> +RTEMS_INLINE_ROUTINE bool _Timestamp_Less_than(
> + Timestamp_Control *_lhs, Timestamp_Control *_rhs
> + if ( _lhs->sec < _rhs->sec )
> + return true;
> + if ( _lhs->sec > _rhs->sec )
> + return false;
> + /* assert: lhs->tv_sec == rhs->tv_sec */
> + if ( _lhs->frac < _rhs->frac)
> + return true;
> + return false;
> * @brief Greater than operator for timestamps.
> @@ -138,8 +139,23 @@ extern "C" {
> * @retval This method returns true if @a _lhs is greater than the @a _rhs and
> * false otherwise.
> -#define _Timestamp_Greater_than( _lhs, _rhs ) \
> - _Timestamp_Less_than( _rhs, _lhs )
> +RTEMS_INLINE_ROUTINE bool _Timestamp_Greater_than(
> + return true;
> + return false;
> + if ( _lhs->frac > _rhs->frac)
> + return true;
> + return false;
> * @brief Equal to than operator for timestamps.
> @@ -152,13 +168,16 @@ extern "C" {
> * @retval This method returns true if @a _lhs is equal to @a _rhs and
> * false otherwise.
> - #define _Timestamp_Equal_to( _lhs, _rhs ) \
> - _Timespec_Equal_to( _lhs, _rhs )
> -#else
> - _Timestamp64_Equal_to( _lhs, _rhs )
> -#endif
> +RTEMS_INLINE_ROUTINE bool _Timestamp_Equal_to(
> + if (( _lhs->sec < _rhs->sec) && (_lhs->frac == _rhs->frac))
> + return true;
> + return false;
> * @brief Adds two timestamps.
> @@ -171,13 +190,15 @@ extern "C" {
> * @retval This method returns the number of seconds @a time increased by.
> - #define _Timestamp_Add_to( _time, _add ) \
> - _Timespec_Add_to( _time, _add )
> -#else
> - _Timestamp64_Add_to( _time, _add )
> -#endif
> +RTEMS_INLINE_ROUTINE time_t _Timestamp_Add_to(
> + const Timestamp_Control *_add
> + time_t seconds = _time->sec;
> + bintime_add(_time, _add);
> + return ((_time->sec) - seconds);
> * @brief Subtracts two timestamps.
> @@ -192,13 +213,17 @@ extern "C" {
> * @retval This method fills in @a _result.
> - #define _Timestamp_Subtract( _start, _end, _result ) \
> - _Timespec_Subtract( _start, _end, _result )
> -#else
> - _Timestamp64_Subtract( _start, _end, _result )
> -#endif
> +RTEMS_INLINE_ROUTINE void _Timestamp_Subtract(
> + const Timestamp_Control *_start,
> + const Timestamp_Control *_end,
> + Timestamp_Control *_result
> + _result->sec = _end->sec;
> + _result->frac = _end->frac;
> + bintime_sub(_result, _start);
> * @brief Divides a timestamp by another timestamp.
> @@ -213,13 +238,24 @@ extern "C" {
> * @retval This method fills in @a result.
> - #define _Timestamp_Divide( _lhs, _rhs, _ival_percentage, _fval_percentage ) \
> - _Timespec_Divide( _lhs, _rhs, _ival_percentage, _fval_percentage )
> -#else
> - _Timestamp64_Divide( _lhs, _rhs, _ival_percentage, _fval_percentage )
> -#endif
> +RTEMS_INLINE_ROUTINE void _Timestamp_Divide(
> + const Timestamp_Control *_lhs,
> + const Timestamp_Control *_rhs,
> + uint32_t *_ival_percentage,
> + uint32_t *_fval_percentage
> + struct timespec _time_left, _time_right;
> + bintime2timespec(_lhs, &_time_left);
> + bintime2timespec(_rhs, &_time_right);
> + _Timespec_Divide(&_time_left,
> + &_time_right,
> + _ival_percentage,
> + _fval_percentage
> * @brief Get seconds portion of timestamp.
> @@ -230,13 +266,12 @@ extern "C" {
> * @retval The seconds portion of @a _time.
> - #define _Timestamp_Get_seconds( _time ) \
> - _Timespec_Get_seconds( _time )
> -#else
> - _Timestamp64_Get_seconds( _time )
> -#endif
> +RTEMS_INLINE_ROUTINE time_t _Timestamp_Get_seconds(
> + const Timestamp_Control *_time
> + return _time->sec;
> * @brief Get nanoseconds portion of timestamp.
> @@ -247,13 +282,14 @@ extern "C" {
> * @retval The nanoseconds portion of @a _time.
> - #define _Timestamp_Get_nanoseconds( _time ) \
> - _Timespec_Get_nanoseconds( _time )
> -#else
> - _Timestamp64_Get_nanoseconds( _time )
> -#endif
> +RTEMS_INLINE_ROUTINE uint32_t _Timestamp_Get_nanoseconds(
> + bintime2timespec(_time, &_ts);
> + return _ts.tv_nsec;
> * @brief Get the timestamp as nanoseconds.
> @@ -261,16 +297,23 @@ extern "C" {
> * This method returns the timestamp as nanoseconds.
> + * @param[in] _nanoseconds adds nanoseconds since last tick
> * @retval The time in nanoseconds.
> - #define _Timestamp_Get_As_nanoseconds( _timestamp, _nanoseconds ) \
> - _Timespec_Get_As_nanoseconds( _timestamp, _nanoseconds )
> -#else
> - _Timestamp64_Get_As_nanoseconds( _timestamp, _nanoseconds )
> -#endif
> +RTEMS_INLINE_ROUTINE uint64_t _Timestamp_Get_As_nanoseconds(
> + const Timestamp_Control *_time,
> + const uint32_t _nanoseconds
> + struct timespec ts;
> + uint64_t overall_ns_val;
> + bintime2timespec(_time, &ts);
> + overall_ns_val = _Timespec_Get_As_nanoseconds(&ts, _nanoseconds);
> + return overall_ns_val;
> * @brief Convert timestamp to struct timespec.
> @@ -280,14 +323,13 @@ extern "C" {
> * @param[in] _timestamp points to the timestamp
> * @param[in] _timespec points to the timespec
> - /* in this case we know they are the same type so use simple assignment */
> - #define _Timestamp_To_timespec( _timestamp, _timespec ) \
> - *(_timespec) = *(_timestamp)
> -#else
> - _Timestamp64_To_timespec( _timestamp, _timespec )
> -#endif
> +RTEMS_INLINE_ROUTINE void _Timestamp_To_timespec(
> + const Timestamp_Control *_timestamp,
> + struct timespec *_timespec
> + bintime2timespec(_timestamp, _timespec);
> * @brief Convert timestamp to struct timeval.
> @@ -295,16 +337,13 @@ extern "C" {
> * @param[in] _timeval points to the timeval
> - #define _Timestamp_To_timeval( _timestamp, _timeval ) \
> - do { \
> - (_timeval)->tv_sec = (_timestamp)->tv_sec; \
> - (_timeval)->tv_usec = (_timestamp)->tv_nsec / 1000; \
> - } while (0)
> -#else
> - _Timestamp64_To_timeval( _timestamp, _timeval )
> -#endif
> +RTEMS_INLINE_ROUTINE void _Timestamp_To_timeval(
> + struct timeval *_timeval
> + bintime2timeval(_timestamp, _timeval);
> #ifdef __cplusplus
> diff --git a/cpukit/score/include/rtems/score/timestamp64.h b/cpukit/score/include/rtems/score/timestamp64.h
> index 39b4965..0000000
> --- a/cpukit/score/include/rtems/score/timestamp64.h
> +++ /dev/null
> @@ -1,379 +0,0 @@
> - * @file rtems/score/timestamp64.h
> - * @brief Helpers for Manipulating 64-bit Integer Timestamps
> - * This include file contains helpers for manipulating
> - * 64-bit integer timestamps.
> - * COPYRIGHT (c) 1989-2009.
> -#ifndef _RTEMS_SCORE_TIMESTAMP64_H
> -#define _RTEMS_SCORE_TIMESTAMP64_H
> - * @defgroup SuperCoreTimestamp64 SuperCore Sixty-Four Bit Timestamps
> - * @ingroup Score
> - * This handler encapsulates functionality related to manipulating
> - * the 64 bit integer implementation of SuperCore Timestamps.
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> - * This .h file is not for general use. It is an alternative
> - * implementation of Timestamps and should only be used that way.
> -#ifndef _RTEMS_SCORE_TIMESTAMP_H
> - #error "Should only be included by rtems/score/timestamp.h"
> -#endif
> - * Verify something is defined.
> -#if CPU_TIMESTAMP_USE_INT64 != TRUE && CPU_TIMESTAMP_USE_INT64_INLINE != TRUE
> - #error "SuperCore Timestamp64 implementation included but not defined."
> -#endif
> - * Define the Timestamp control type.
> -typedef int64_t Timestamp64_Control;
> -static inline void _Timestamp64_implementation_Set(
> - Timestamp64_Control *_time,
> - Timestamp64_Control _seconds,
> - Timestamp64_Control _nanoseconds
> - *_time = _seconds * 1000000000L + _nanoseconds;
> - * @brief Set 64-bit timestamp to seconds nanosecond.
> - * This method sets the timestamp to the specified seconds and nanoseconds
> - * value.
> - * @param[in] _time points to the timestamp instance to validate.
> - * @param[in] _seconds is the seconds portion of the timestamp
> - * @param[in] _nanoseconds is the nanoseconds portion of the timestamp
> -#if CPU_TIMESTAMP_USE_INT64_INLINE == TRUE
> - #define _Timestamp64_Set( _time, _seconds, _nanoseconds ) \
> - _Timestamp64_implementation_Set( _time, _seconds, _nanoseconds )
> -#else
> - void _Timestamp64_Set(
> -#endif
> -static inline void _Timestamp64_implementation_Set_to_zero(
> - *_time = 0;
> - * @brief Sets the 64-bit timestamp to zero.
> - * This method sets the timestamp to zero value.
> - * @param[in] _time points to the timestamp instance to zero.
> - #define _Timestamp64_Set_to_zero( _time ) \
> - _Timestamp64_implementation_Set_to_zero( _time )
> -#else
> - void _Timestamp64_Set_to_zero(
> -#endif
> -static inline bool _Timestamp64_implementation_Less_than(
> - const Timestamp64_Control *_lhs,
> - const Timestamp64_Control *_rhs
> - return *_lhs < *_rhs;
> - * @brief The "less than" operator for 64-bit timestamps.
> - * This method is the less than operator for timestamps.
> - * @param[in] _lhs points to the left hand side timestamp
> - * @param[in] _rhs points to the right hand side timestamp
> - * @retval This method returns true if @a _lhs is less than the @a _rhs and
> - * false otherwise.
> - #define _Timestamp64_Less_than( _lhs, _rhs ) \
> - _Timestamp64_implementation_Less_than( _lhs, _rhs )
> -#else
> - bool _Timestamp64_Less_than(
> -#endif
> -static inline bool _Timestamp64_implementation_Equal_to(
> - return *_lhs == *_rhs;
> -#define _Timestamp64_Greater_than( _lhs, _rhs ) \
> - _Timestamp64_Less_than( _rhs, _lhs )
> - * @brief The "equal to" operator for 64-bit timestamps.
> - * This method is the is equal to than operator for timestamps.
> - * @retval This method returns true if @a _lhs is equal to @a _rhs and
> - #define _Timestamp64_Equal_to( _lhs, _rhs ) \
> - _Timestamp64_implementation_Equal_to( _lhs, _rhs )
> -#else
> - bool _Timestamp64_Equal_to(
> -#endif
> -static inline void _Timestamp64_implementation_Add_to(
> - const Timestamp64_Control *_add
> - *_time += *_add;
> - * @brief Add two 64-bit timestamps.
> - * This routine adds two timestamps. The second argument is added
> - * to the first.
> - * @param[in] _time points to the base time to be added to
> - * @param[in] _add points to the timestamp to add to the first argument
> - * @retval This method returns the number of seconds @a time increased by.
> - #define _Timestamp64_Add_to( _time, _add ) \
> - _Timestamp64_implementation_Add_to( _time, _add )
> -#else
> - void _Timestamp64_Add_to(
> -#endif
> -static inline void _Timestamp64_implementation_Subtract(
> - const Timestamp64_Control *_start,
> - const Timestamp64_Control *_end,
> - Timestamp64_Control *_result
> - *_result = *_end - *_start;
> - * @brief Subtract two 64-bit timestamps.
> - * This routine subtracts two timestamps. @a result is set to
> - * @a end - @a start.
> - * @param[in] _start points to the starting time
> - * @param[in] _end points to the ending time
> - * @param[out] _result points to the difference between
> - * starting and ending time.
> - #define _Timestamp64_Subtract( _start, _end, _result ) \
> - _Timestamp64_implementation_Subtract( _start, _end, _result )
> -#else
> - void _Timestamp64_Subtract(
> -#endif
> - * @brief Divide 64-bit timestamp by another 64-bit timestamp.
> - * This routine divides a timestamp by another timestamp. The
> - * intended use is for calculating percentages to three decimal points.
> - * @param[in] _lhs points to the left hand number
> - * @param[in] _rhs points to the right hand number
> - * @param[out] _ival_percentage points to the integer portion of the average
> - * @param[out] _fval_percentage points to the thousandths of percentage
> -void _Timestamp64_Divide(
> - const Timestamp64_Control *_rhs,
> - uint32_t *_ival_percentage,
> - uint32_t *_fval_percentage
> -static inline uint32_t _Timestamp64_implementation_Get_seconds(
> - const Timestamp64_Control *_time
> - return (uint32_t) (*_time / 1000000000L);
> - * @brief Get seconds portion of a 64-bit timestamp.
> - * This method returns the seconds portion of the specified timestamp
> - * @retval The seconds portion of @a _time.
> - #define _Timestamp64_Get_seconds( _time ) \
> - _Timestamp64_implementation_Get_seconds( _time )
> -#else
> - uint32_t _Timestamp64_Get_seconds(
> -#endif
> -static inline uint32_t _Timestamp64_implementation_Get_nanoseconds(
> - return (uint32_t) (*_time % 1000000000L);
> - * @brief Get nanoseconds portion of a 64-bit timestamp.
> - * This method returns the nanoseconds portion of the specified timestamp
> - * @retval The nanoseconds portion of @a _time.
> - #define _Timestamp64_Get_nanoseconds( _time ) \
> - _Timestamp64_implementation_Get_nanoseconds( _time )
> -#else
> - uint32_t _Timestamp64_Get_nanoseconds(
> -#endif
> -static inline uint64_t _Timestamp64_implementation_Get_As_nanoseconds(
> - const Timestamp64_Control *_time,
> - const uint32_t nanoseconds
> - return *_time + (uint64_t) nanoseconds;
> - * @brief Get the 64-bit timestamp as nanoseconds.
> - * This method returns the 64-bit timestamp as it is already in nanoseconds.
> -#define _Timestamp64_Get_As_nanoseconds( _time, _nanoseconds ) \
> - _Timestamp64_implementation_Get_As_nanoseconds( _time, _nanoseconds )
> -static inline void _Timestamp64_implementation_To_timespec(
> - const Timestamp64_Control *_timestamp,
> - struct timespec *_timespec
> - _timespec->tv_sec = (time_t) (*_timestamp / 1000000000L);
> - _timespec->tv_nsec = (long) (*_timestamp % 1000000000L);
> - * @brief Convert 64-bit timestamp to struct timespec.
> - * @param[in] _timestamp points to the timestamp
> - * @param[out] _timespec points to the timespec
> - #define _Timestamp64_To_timespec( _timestamp, _timespec ) \
> - _Timestamp64_implementation_To_timespec( _timestamp, _timespec )
> -#else
> - void _Timestamp64_To_timespec(
> -#endif
> -static inline void _Timestamp64_implementation_To_timeval(
> - struct timeval *_timeval
> - _timeval->tv_sec = (time_t) (*_timestamp / 1000000000U);
> - _timeval->tv_usec = (suseconds_t) ((*_timestamp % 1000000000U) / 1000U);
> - * @brief Convert 64-bit timestamp to struct timeval.
> - * @param[out] _timeval points to the timeval
> - #define _Timestamp64_To_timeval( _timestamp, _timeval ) \
> - _Timestamp64_implementation_To_timeval( _timestamp, _timeval )
> -#else
> - void _Timestamp64_To_timeval(
> -#endif
> -#ifdef __cplusplus
> -#endif
> -#endif
> -/* end of include file */
> diff --git a/cpukit/score/include/rtems/score/tod.h b/cpukit/score/include/rtems/score/tod.h
> index 1972b0f..c0ab5e7 100644
> --- a/cpukit/score/include/rtems/score/tod.h
> +++ b/cpukit/score/include/rtems/score/tod.h
> @@ -24,15 +24,6 @@
> extern "C" {
> #endif
> - * @brief Returns the nanoseconds since the last clock tick.
> - * @ingroup ScoreTOD
> - * @return The nanoseconds since the last clock tick.
> -typedef uint32_t ( *TOD_Nanoseconds_since_last_tick_routine )( void );
> #ifdef __cplusplus
> #endif
> diff --git a/cpukit/score/include/rtems/score/todimpl.h b/cpukit/score/include/rtems/score/todimpl.h
> index ad5ed39..4fe85d4 100644
> --- a/cpukit/score/include/rtems/score/todimpl.h
> +++ b/cpukit/score/include/rtems/score/todimpl.h
> @@ -19,8 +19,8 @@
> #define _RTEMS_SCORE_TODIMPL_H
> #include <rtems/score/tod.h>
> -#include <rtems/score/isrlock.h>
> #include <rtems/score/timestamp.h>
> +#include <rtems/score/timecounterimpl.h>
> #include <time.h>
> @@ -131,25 +131,6 @@ extern "C" {
> typedef struct {
> - * @brief Current time of day value.
> - * This field is protected by the lock.
> - Timestamp_Control now;
> - * @brief System uptime.
> - Timestamp_Control uptime;
> - * @brief Lock to protect the now and uptime fields.
> - ISR_lock_Control lock;
> * @brief Time of day seconds trigger.
> * This value specifies the nanoseconds since the last time of day second.
> @@ -159,13 +140,6 @@ typedef struct {
> uint32_t seconds_trigger;
> - * @brief The current nanoseconds since last tick handler.
> - * This field must not be NULL after initialization.
> - TOD_Nanoseconds_since_last_tick_routine nanoseconds_since_last_tick;
> * @brief Indicates if the time of day is set.
> * This is true if the application has set the current
> @@ -176,12 +150,6 @@ typedef struct {
> SCORE_EXTERN TOD_Control _TOD;
> -#define _TOD_Acquire( _tod, lock_context ) \
> - _ISR_lock_ISR_disable_and_acquire( &( _tod )->lock, lock_context )
> -#define _TOD_Release( _tod, lock_context ) \
> - _ISR_lock_Release_and_ISR_enable( &( _tod )->lock, lock_context )
> * @brief Initializes the time of day handler.
> @@ -215,32 +183,18 @@ static inline void _TOD_Set(
> _TOD_Set_with_timestamp( &tod_as_timestamp );
> - * @brief Returns a snapshot of a clock.
> - * This function invokes the nanoseconds extension.
> - * @param[out] snapshot points to an area that will contain the current
> - * TOD plus the BSP nanoseconds since last tick adjustment
> - * @param[in] clock contains the current TOD
> - * @retval @a snapshot
> -Timestamp_Control *_TOD_Get_with_nanoseconds(
> - Timestamp_Control *snapshot,
> - const Timestamp_Control *clock
> static inline void _TOD_Get(
> - struct timespec *tod_as_timespec
> + Timestamp_Control *time
> - Timestamp_Control tod_as_timestamp;
> - Timestamp_Control *tod_as_timestamp_ptr;
> + _Timecounter_Bintime(time);
> - tod_as_timestamp_ptr =
> - _TOD_Get_with_nanoseconds( &tod_as_timestamp, &_TOD.now );
> - _Timestamp_To_timespec( tod_as_timestamp_ptr, tod_as_timespec );
> +static inline void _TOD_Get_as_timespec(
> + struct timespec *time
> + _Timecounter_Nanotime(time);
> @@ -255,7 +209,7 @@ static inline void _TOD_Get_uptime(
> - _TOD_Get_with_nanoseconds( time, &_TOD.uptime );
> + _Timecounter_Binuptime(time);
> @@ -266,9 +220,12 @@ static inline void _TOD_Get_uptime(
> * @param[in] time is a pointer to the uptime to be returned
> -void _TOD_Get_uptime_as_timespec(
> +static inline void _TOD_Get_uptime_as_timespec(
> + _Timecounter_Nanouptime(time);
> * @brief Number of seconds Since RTEMS epoch.
> @@ -276,7 +233,14 @@ void _TOD_Get_uptime_as_timespec(
> * The following contains the number of seconds from 00:00:00
> * January 1, TOD_BASE_YEAR until the current time of day.
> -uint32_t _TOD_Seconds_since_epoch( void );
> +static inline uint32_t _TOD_Seconds_since_epoch( void )
> + struct bintime bt;
> + _Timecounter_Bintime(&bt);
> + return bt.sec;
> * @brief Increments time of day at each clock tick.
> @@ -314,12 +278,7 @@ RTEMS_INLINE_ROUTINE void _TOD_Get_timeval(
> struct timeval *time
> - Timestamp_Control snapshot_as_timestamp;
> - Timestamp_Control *snapshot_as_timestamp_ptr;
> - snapshot_as_timestamp_ptr =
> - _TOD_Get_with_nanoseconds( &snapshot_as_timestamp, &_TOD.now );
> - _Timestamp_To_timeval( snapshot_as_timestamp_ptr, time );
> + _Timecounter_Microtime(time);
> @@ -335,18 +294,6 @@ void _TOD_Adjust(
> - * @brief Install the BSP's nanoseconds since clock tick handler
> - * @param[in] routine is the BSP's nanoseconds since clock tick method
> -RTEMS_INLINE_ROUTINE void _TOD_Set_nanoseconds_since_last_tick_handler(
> - TOD_Nanoseconds_since_last_tick_routine routine
> - _TOD.nanoseconds_since_last_tick = routine;
> * @brief Check if the TOD is Set
> * @return TRUE is the time is set. FALSE otherwise.
> diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
> index 75c8be6..b74afb8 100644
> --- a/cpukit/score/preinstall.am
> +++ b/cpukit/score/preinstall.am
> @@ -348,9 +348,13 @@ $(PROJECT_INCLUDE)/rtems/score/timestamp.h: include/rtems/score/timestamp.h $(PR
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timestamp.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timestamp.h
> -$(PROJECT_INCLUDE)/rtems/score/timestamp64.h: include/rtems/score/timestamp64.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timestamp64.h
> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timestamp64.h
> +$(PROJECT_INCLUDE)/rtems/score/timecounter.h: include/rtems/score/timecounter.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timecounter.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timecounter.h
> +$(PROJECT_INCLUDE)/rtems/score/timecounterimpl.h: include/rtems/score/timecounterimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timecounterimpl.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timecounterimpl.h
> $(PROJECT_INCLUDE)/rtems/score/tls.h: include/rtems/score/tls.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/tls.h
> diff --git a/cpukit/score/src/coretod.c b/cpukit/score/src/coretod.c
> index 2deeeba..67d5104 100644
> --- a/cpukit/score/src/coretod.c
> +++ b/cpukit/score/src/coretod.c
> @@ -20,23 +20,15 @@
> -static uint32_t _TOD_Nanoseconds_since_tick_default_handler( void )
> - return 0;
> void _TOD_Handler_initialization(void)
> - _ISR_lock_Initialize( &tod->lock, "TOD" );
> - _Timestamp_Set( &tod->now, TOD_SECONDS_1970_THROUGH_1988, 0 );
> - _Timestamp_Set_to_zero( &tod->uptime );
> - tod->nanoseconds_since_last_tick =
> - _TOD_Nanoseconds_since_tick_default_handler;
> + ts.tv_sec = TOD_SECONDS_1970_THROUGH_1988;
> + ts.tv_nsec = 0;
> + _Timecounter_Set_clock(&ts);
> /* TOD has not been set */
> tod->is_set = false;
> diff --git a/cpukit/score/src/coretodadjust.c b/cpukit/score/src/coretodadjust.c
> index 09cf01a..6097e20 100644
> --- a/cpukit/score/src/coretodadjust.c
> +++ b/cpukit/score/src/coretodadjust.c
> @@ -25,8 +25,7 @@ void _TOD_Adjust(
> const Timestamp_Control delta
> - Timestamp_Control tod;
> - Timestamp_Control *tod_ptr;
> + Timestamp_Control tod;
> * Currently, RTEMS does the adjustment in one movement.
> @@ -41,11 +40,11 @@ void _TOD_Adjust(
> _Thread_Disable_dispatch();
> - tod_ptr = _TOD_Get_with_nanoseconds( &tod, &_TOD.now );
> + _TOD_Get( &tod );
> - _Timestamp_Add_to( tod_ptr, &delta );
> + _Timestamp_Add_to( &tod, &delta );
> - _TOD_Set_with_timestamp( tod_ptr );
> + _TOD_Set_with_timestamp( &tod );
> _Thread_Enable_dispatch();
> diff --git a/cpukit/score/src/coretodget.c b/cpukit/score/src/coretodget.c
> index 70eb238..0000000
> --- a/cpukit/score/src/coretodget.c
> +++ /dev/null
> @@ -1,46 +0,0 @@
> - * @file
> - * @brief Returns a Current TOD with Nanosecond Granularity
> - * COPYRIGHT (c) 1989-2014.
> -#if HAVE_CONFIG_H
> - #include "config.h"
> -#endif
> -#include <rtems/score/isrlevel.h>
> - Timestamp_Control offset;
> - nanoseconds = ( *tod->nanoseconds_since_last_tick )();
> - now = *clock;
> - _Timestamp_Set( &offset, 0, nanoseconds );
> - _Timestamp_Add_to( &now, &offset );
> - *snapshot = now;
> - return snapshot;
> diff --git a/cpukit/score/src/coretodgetuptimetimespec.c b/cpukit/score/src/coretodgetuptimetimespec.c
> index 5980b2f..0000000
> --- a/cpukit/score/src/coretodgetuptimetimespec.c
> +++ /dev/null
> @@ -1,32 +0,0 @@
> - * @file
> - * @brief Get Uptime as struct timespec
> -#if HAVE_CONFIG_H
> -#endif
> - struct timespec *uptime
> - Timestamp_Control uptime_ts;
> - /* assume time checked for NULL by caller */
> - _TOD_Get_uptime( &uptime_ts );
> - _Timestamp_To_timespec( &uptime_ts, uptime );
> diff --git a/cpukit/score/src/coretodsecondssinceepoch.c b/cpukit/score/src/coretodsecondssinceepoch.c
> index b7bd270..0000000
> --- a/cpukit/score/src/coretodsecondssinceepoch.c
> +++ /dev/null
> @@ -1,32 +0,0 @@
> - * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
> - * embedded brains GmbH
> - * Dornierstr. 4
> - * 82178 Puchheim
> - * Germany
> - * <rtems at embedded-brains.de>
> -#if HAVE_CONFIG_H
> -#endif
> - now = tod->now;
> - return _Timestamp_Get_seconds( &now );
> diff --git a/cpukit/score/src/coretodset.c b/cpukit/score/src/coretodset.c
> index 6006e66..8cff81c 100644
> --- a/cpukit/score/src/coretodset.c
> +++ b/cpukit/score/src/coretodset.c
> @@ -27,10 +27,14 @@ void _TOD_Set_with_timestamp(
> uint32_t nanoseconds = _Timestamp_Get_nanoseconds( tod_as_timestamp );
> Watchdog_Interval seconds_next = _Timestamp_Get_seconds( tod_as_timestamp );
> Watchdog_Interval seconds_now;
> + bintime2timespec(tod_as_timestamp, &ts);
> + nanoseconds = ts.tv_nsec;
> + seconds_next = ts.tv_sec;
> @@ -41,9 +45,7 @@ void _TOD_Set_with_timestamp(
> else
> _Watchdog_Adjust_seconds( WATCHDOG_FORWARD, seconds_next - seconds_now );
> - tod->now = *tod_as_timestamp;
> tod->seconds_trigger = nanoseconds;
> tod->is_set = true;
> diff --git a/cpukit/score/src/coretodtickle.c b/cpukit/score/src/coretodtickle.c
> index 9116fc1..3d7c71e 100644
> --- a/cpukit/score/src/coretodtickle.c
> +++ b/cpukit/score/src/coretodtickle.c
> @@ -24,30 +24,10 @@
> void _TOD_Tickle_ticks( void )
> - Timestamp_Control tick;
> - uint32_t nanoseconds_per_tick;
> - nanoseconds_per_tick = rtems_configuration_get_nanoseconds_per_tick();
> - /* Convert the tick quantum to a timestamp */
> - _Timestamp_Set( &tick, 0, nanoseconds_per_tick );
> /* Update the counter of ticks since boot */
> _Watchdog_Ticks_since_boot += 1;
> - /* Update the uptime */
> - _Timestamp_Add_to( &tod->uptime, &tick );
> - /* Update the current TOD */
> - _Timestamp_Add_to( &tod->now, &tick );
> - _TOD.seconds_trigger += nanoseconds_per_tick;
> + _TOD.seconds_trigger += rtems_configuration_get_nanoseconds_per_tick();
> if ( _TOD.seconds_trigger >= 1000000000UL ) {
> _TOD.seconds_trigger -= 1000000000UL;
> _Watchdog_Tickle_seconds();
> diff --git a/cpukit/score/src/tcgetscalerandmask.c b/cpukit/score/src/tcgetscalerandmask.c
> index 0000000..a2a2db4
> --- /dev/null
> +++ b/cpukit/score/src/tcgetscalerandmask.c
> @@ -0,0 +1,40 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#if HAVE_CONFIG_H
> + #include "config.h"
> +#endif
> + uint64_t *scaler,
> + uint32_t *mask
> + uint32_t power_of_two = 1;
> + int i;
> + for ( i = 0; i < 32; ++i ) {
> + if ( power_of_two >= counter_ticks_per_clock_tick ) {
> + break;
> + power_of_two *= 2;
> + *mask = (2 * power_of_two) - 1;
> + *scaler = ((uint64_t) power_of_two << 32) / counter_ticks_per_clock_tick;
> diff --git a/cpukit/score/src/ts64addto.c b/cpukit/score/src/ts64addto.c
> index a0f4b3c..0000000
> --- a/cpukit/score/src/ts64addto.c
> +++ /dev/null
> @@ -1,31 +0,0 @@
> - * @file score/src/ts64addto.c
> - * @brief Add to a Timestamp
> - * @ingroup SuperCore
> - * COPYRIGHT (c) 1989-2008.
> -#if HAVE_CONFIG_H
> -#endif
> -#include <rtems/score/timestamp.h>
> -void _Timestamp64_Add_to(
> - _Timestamp64_implementation_Add_to( _time, _add );
> -#endif
> diff --git a/cpukit/score/src/ts64divide.c b/cpukit/score/src/ts64divide.c
> index d9a5099..0000000
> --- a/cpukit/score/src/ts64divide.c
> +++ /dev/null
> @@ -1,51 +0,0 @@
> - * @file
> - * @brief Divide Timestamp
> - * COPYRIGHT (c) 1989-2007.
> -#if HAVE_CONFIG_H
> -#endif
> -/* This method is never inlined. */
> - Timestamp64_Control answer;
> - if ( *_rhs == 0 ) {
> - *_ival_percentage = 0;
> - *_fval_percentage = 0;
> - return;
> - * This looks odd but gives the results the proper precision.
> - * TODO: Rounding on the last digit of the fval.
> - answer = (*_lhs * 100000) / *_rhs;
> - *_ival_percentage = answer / 1000;
> - *_fval_percentage = answer % 1000;
> -#endif
> diff --git a/cpukit/score/src/ts64equalto.c b/cpukit/score/src/ts64equalto.c
> index fd07474..0000000
> --- a/cpukit/score/src/ts64equalto.c
> +++ /dev/null
> @@ -1,31 +0,0 @@
> - * @file
> - * @brief Timestamp equal to Operator
> -#if HAVE_CONFIG_H
> -#endif
> -bool _Timestamp64_Equal_to(
> - return _Timestamp64_implementation_Equal_to( _lhs, _rhs );
> -#endif
> diff --git a/cpukit/score/src/ts64getnanoseconds.c b/cpukit/score/src/ts64getnanoseconds.c
> index a5da43b..0000000
> --- a/cpukit/score/src/ts64getnanoseconds.c
> +++ /dev/null
> @@ -1,30 +0,0 @@
> - * @file score/src/ts64toticks.c
> - * @brief Get Nanoseconds Portion of Timestamp
> -#if HAVE_CONFIG_H
> -#endif
> -uint32_t _Timestamp64_Get_nanoseconds(
> - return _Timestamp64_implementation_Get_nanoseconds( _time );
> -#endif
> diff --git a/cpukit/score/src/ts64getseconds.c b/cpukit/score/src/ts64getseconds.c
> index eca0536..0000000
> --- a/cpukit/score/src/ts64getseconds.c
> +++ /dev/null
> @@ -1,30 +0,0 @@
> - * @file
> - * @brief Get Seconds Portion of Timestamp
> -#if HAVE_CONFIG_H
> -#endif
> -uint32_t _Timestamp64_Get_seconds(
> - return _Timestamp64_implementation_Get_seconds( _time );
> -#endif
> diff --git a/cpukit/score/src/ts64lessthan.c b/cpukit/score/src/ts64lessthan.c
> index d147814..0000000
> --- a/cpukit/score/src/ts64lessthan.c
> +++ /dev/null
> @@ -1,31 +0,0 @@
> - * @file
> - * @brief Timestamp Less Than Operator
> - * @ingroup SuperCore Timestamp64
> -#if HAVE_CONFIG_H
> -#endif
> -bool _Timestamp64_Less_than(
> - return _Timestamp64_implementation_Less_than( _lhs, _rhs );
> -#endif
> diff --git a/cpukit/score/src/ts64set.c b/cpukit/score/src/ts64set.c
> index 22771d6..0000000
> --- a/cpukit/score/src/ts64set.c
> +++ /dev/null
> @@ -1,33 +0,0 @@
> - * @file
> - * @brief Set Timestamp to Specified Seconds and Nanoseconds
> -#if HAVE_CONFIG_H
> -#endif
> -void _Timestamp64_Set(
> - _Timestamp64_implementation_Set( _time, _seconds, _nanoseconds );
> -#endif
> diff --git a/cpukit/score/src/ts64settozero.c b/cpukit/score/src/ts64settozero.c
> index 7b319df..0000000
> --- a/cpukit/score/src/ts64settozero.c
> +++ /dev/null
> @@ -1,31 +0,0 @@
> - * @file
> - * @brief Zero a Timestamp64 Instance
> -#if HAVE_CONFIG_H
> -#endif
> -void _Timestamp64_Set_to_zero(
> - _Timestamp64_implementation_Set_to_zero( _time );
> -#endif
> diff --git a/cpukit/score/src/ts64subtract.c b/cpukit/score/src/ts64subtract.c
> index 1ee917b..0000000
> --- a/cpukit/score/src/ts64subtract.c
> +++ /dev/null
> @@ -1,31 +0,0 @@
> - * @file
> - * @brief Subtract Two Timestamps
> - * @ingroup Timestamp
> -#if HAVE_CONFIG_H
> -#endif
> -void _Timestamp64_Subtract(
> - _Timestamp64_implementation_Subtract( _start, _end, _result );
> -#endif
> diff --git a/cpukit/score/src/ts64totimespec.c b/cpukit/score/src/ts64totimespec.c
> index 7e81da7..0000000
> --- a/cpukit/score/src/ts64totimespec.c
> +++ /dev/null
> @@ -1,32 +0,0 @@
> - * @file
> - * @brief Convert Timestamp to Struct Timespec
> -#if HAVE_CONFIG_H
> -#endif
> -void _Timestamp64_To_timespec(
> - _Timestamp64_implementation_To_timespec( _timestamp, _timespec );
> -#endif
> diff --git a/cpukit/score/src/ts64totimeval.c b/cpukit/score/src/ts64totimeval.c
> index 1ac765b..0000000
> --- a/cpukit/score/src/ts64totimeval.c
> +++ /dev/null
> @@ -1,37 +0,0 @@
> - * @file
> - * @brief Convert 64-bit Timestamp to struct timeval
> - * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
> - * Obere Lagerstr. 30
> - * 82178 Puchheim
> - * Germany
> -#if HAVE_CONFIG_H
> -#endif
> -void _Timestamp64_To_timeval(
> - _Timestamp64_implementation_To_timeval( _timestamp, _timeval );
> -#endif
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
> index 9025ff3..c3fc443 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -38,6 +38,8 @@ else
> _SUBDIRS += sp29
> endif
> _SUBDIRS += spintrcritical23
> +_SUBDIRS += sptimecounter01
> +_SUBDIRS += sptimecounter02
> _SUBDIRS += spatomic01
> _SUBDIRS += spintrcritical22
> _SUBDIRS += spsem03
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
> index ae3c763..dbdd30f 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -41,6 +41,8 @@ AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
> # Explicitly list all Makefiles here
> AC_CONFIG_FILES([Makefile
> spintrcritical23/Makefile
> +sptimecounter02/Makefile
> +sptimecounter01/Makefile
> spatomic01/Makefile
> spglobalcon01/Makefile
> spintrcritical22/Makefile
> diff --git a/testsuites/sptests/spclock_err01/init.c b/testsuites/sptests/spclock_err01/init.c
> index ab5c00a..087c8d4 100644
> --- a/testsuites/sptests/spclock_err01/init.c
> +++ b/testsuites/sptests/spclock_err01/init.c
> @@ -115,14 +115,6 @@ rtems_task Init(
> puts( "TA1 - rtems_clock_get_tod_timeval - RTEMS_NOT_DEFINED" );
> - puts( "TA1 - rtems_clock_set_nanoseconds_extension - RTEMS_INVALID_ADDRESS" );
> - status = rtems_clock_set_nanoseconds_extension( NULL );
> - fatal_directive_status(
> - status,
> - RTEMS_INVALID_ADDRESS,
> - "rtems_clock_set_nanoseconds_extension NULL param"
> /* NULL parameter */
> status = rtems_clock_set( NULL );
> diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
> index f427bd2..3e01466 100644
> --- a/testsuites/sptests/spsize/size.c
> +++ b/testsuites/sptests/spsize/size.c
> @@ -390,9 +390,6 @@ uninitialized =
> /*timerimpl.h*/ (sizeof _Timer_Information) +
> -/*tod.h*/ (sizeof _TOD.now) +
> - (sizeof _TOD.uptime) +
> /*tqdata.h*/ 0 +
> /*types.h*/ 0 +
> diff --git a/testsuites/sptests/sptimecounter02/Makefile.am b/testsuites/sptests/sptimecounter02/Makefile.am
> index 0000000..498c24e
> --- /dev/null
> +++ b/testsuites/sptests/sptimecounter02/Makefile.am
> @@ -0,0 +1,19 @@
> +rtems_tests_PROGRAMS = sptimecounter02
> +sptimecounter02_SOURCES = init.c
> +dist_rtems_tests_DATA = sptimecounter02.scn sptimecounter02.doc
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> +LINK_OBJS = $(sptimecounter02_OBJECTS)
> +LINK_LIBS = $(sptimecounter02_LDLIBS)
> +sptimecounter02$(EXEEXT): $(sptimecounter02_OBJECTS) $(sptimecounter02_DEPENDENCIES)
> + @rm -f sptimecounter02$(EXEEXT)
> + $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/sptests/sptimecounter02/init.c b/testsuites/sptests/sptimecounter02/init.c
> index 0000000..781401f
> --- /dev/null
> +++ b/testsuites/sptests/sptimecounter02/init.c
> @@ -0,0 +1,266 @@
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> +#ifdef HAVE_CONFIG_H
> +#endif
> +#define _KERNEL
> +#include <sys/time.h>
> +#include <stdlib.h>
> +#include <stdio.h>
> +#include <inttypes.h>
> +#include <assert.h>
> +#include <unistd.h>
> +#include <rtems.h>
> +#include <rtems/counter.h>
> +#include <rtems/test.h>
> +#include "tmacros.h"
> +const char rtems_test_name[] = "SPTIMECOUNTER_2";
> +#define MASTER_PRIORITY 1
> +#define WORKER_PRIORITY 2
> +#define CPU_COUNT 32
> +#define DURATION_LENGTH 2
> +typedef struct {
> + rtems_test_parallel_context base;
> + struct timecounter tc_soft;
> + struct timecounter tc_cpu_counter;
> + u_int tc_soft_counter;
> + uint32_t binuptime_per_job[CPU_COUNT];
> + uint32_t rtemsuptime_per_job[CPU_COUNT];
> +} timecounter_context;
> +typedef struct {
> + struct bintime start_bin;
> + struct bintime end_bin;
> + struct bintime diff;
> +} test_variables;
> +static timecounter_context test_instance;
> +static test_variables test_values;
> +static rtems_interval test_duration(void)
> + return DURATION_LENGTH * rtems_clock_get_ticks_per_second();
> +static u_int test_get_timecount_null(struct timecounter *tc)
> + return 0;
> +static u_int test_get_timecount_cpu(struct timecounter *tc)
> + return 0xffffffff - rtems_counter_read();
> +static void register_hardware_tc_null(timecounter_context *ctx)
> + struct timecounter *tc_cpu = &ctx->tc_cpu_counter;
> + tc_cpu->tc_get_timecount = test_get_timecount_null;
> + tc_cpu->tc_counter_mask = 0xffffffff;
> + tc_cpu->tc_frequency = rtems_counter_nanoseconds_to_ticks(1000000000);
> + tc_cpu->tc_quality = 2000;
> + _Timecounter_Install(tc_cpu);
> + * Start of Timers
> +static rtems_interval test_bintime_init(
> + rtems_test_parallel_context *base,
> + void *arg,
> + size_t active_workers
> + return test_duration();
> +static void test_bintime_body(
> + void *arg,
> + size_t active_workers,
> + size_t worker_index
> + timecounter_context *ctx = (timecounter_context *) base;
> + uint32_t counter = 0;
> + test_variables *values = &test_values;
> + while (!rtems_test_parallel_stop_job(&ctx->base)) {
> + ++counter;
> + rtems_binuptime(&bt);
> + if (counter == 1){
> + values->start_bin = bt;
> + values->end_bin = bt;
> + values->diff = bt;
> + bintime_sub(&values->diff, &values->start_bin);
> + printf("\n%" PRIu32 " %" PRIu64 "\n", values->start_bin.sec,
> + values->start_bin.frac);
> + printf("%" PRIu32 " %" PRIu64 "\n", values->end_bin.sec,
> + values->end_bin.frac);
> + assert((values->diff.sec == DURATION_LENGTH) ||
> + ((values->diff.sec == DURATION_LENGTH - 1) &&
> + (values->diff.frac > UINT64_C(18000000000000000000))) ||
> + ((values->diff.sec == DURATION_LENGTH + 1) &&
> + (values->end_bin.frac < UINT64_C(2000000000000000000)))
> + ctx->binuptime_per_job[worker_index] = counter;
> +static void test_bintime_fini(
> + void *arg,
> + size_t i;
> + printf(" <BinuptimeTest activeWorker=\"%zu\">\n", active_workers);
> + for (i = 0; i < active_workers; ++i) {
> + printf(
> + " <Counter worker=\"%zu\">%" PRIu32 "</Counter>\n",
> + (i+1), ctx->binuptime_per_job[i]);
> + printf(" </BinuptimeTest>\n");
> +static rtems_interval test_bintime_null_init(
> + void *arg,
> + timecounter_context *ctx = &test_instance;
> + register_hardware_tc_null(ctx);
> +static void test_bintime_null_body(
> + void *arg,
> + ++counter;
> +static void test_bintime_null_fini(
> + void *arg,
> + size_t i;
> + printf(" <BinuptimenullTest activeWorker=\"%zu\">\n", active_workers);
> + printf(
> + printf(" </BinuptimenullTest>\n");
> +static const rtems_test_parallel_job timecounter_jobs[] = {
> + .init = test_bintime_init,
> + .body = test_bintime_body,
> + .fini = test_bintime_fini,
> + .cascade = true
> + .init = test_bintime_null_init,
> + .body = test_bintime_null_body,
> + .fini = test_bintime_null_fini,
> + .cascade = true
> + * Start of Init
> +static void Init(rtems_task_argument arg)
> + TEST_BEGIN();
> + printf("<TEST>\n");
> + rtems_test_parallel(
> + &ctx->base,
> + NULL,
> + &timecounter_jobs[0],
> + RTEMS_ARRAY_SIZE(timecounter_jobs)
> + printf("</TEST>\n");
> + TEST_END();
> + rtems_test_exit(0);
> +#define CONFIGURE_MICROSECONDS_PER_TICK 1000
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS (2 + CPU_COUNT - 1)
> +#define CONFIGURE_MAXIMUM_TIMERS 2
> +#define CONFIGURE_MAXIMUM_PERIODS 1
> +#define CONFIGURE_SMP_APPLICATION
> +#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/sptests/sptimecounter02/sptimecounter02.doc b/testsuites/sptests/sptimecounter02/sptimecounter02.doc
> index 0000000..56e8bb6
> --- /dev/null
> +++ b/testsuites/sptests/sptimecounter02/sptimecounter02.doc
> @@ -0,0 +1,11 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: sptimecounter02
> +directives:
> + TBD
> +concepts:
> + TBD
> diff --git a/testsuites/sptests/sptimecounter02/sptimecounter02.scn b/testsuites/sptests/sptimecounter02/sptimecounter02.scn
> index 0000000..e69de29
> 1.8.4.5
> devel mailing list
> devel at rtems.org
