[PATCH 3/4] new rtems environment with the implementation of FreeBSD timecounters; modifications of certain tests in the testsuite New test: timecounter02
    Sebastian Huber
    Wed Apr  1 18:54:18 UTC 2015
----- Gedare Bloom <gedare at rtems.org> schrieb:
> On Wed, Apr 1, 2015 at 11:58 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
> > On 4/1/2015 10:01 AM, Gedare Bloom wrote:
> >> I didn't read much of this, but it needs doxygen, and probably part of
> >> the previous patch should be merged in here, or some better
> >> splitting/recombining of patches so I don't have to review code that
> >> gets fixed. It's worth repeating, the "rtems_*time" functions are not
> >> following the API conventions of rtems_package_method, it should be
> >> rtems_timecounter_*time like rtems_timecounter_bintime.
> >> Please use a short git-commit message for the first line, and longer
> >> git commit message after a blank line. This will avoid really long
> >> lines in git log, and long subjects in git-send-email. I guess this
> >> advice is in the Git page
> >> (https://devel.rtems.org/wiki/Developer/Git).
> > It is already combined so I am not going to complain but I see a method
> > renamed
> > in here (_TOD_Get). Personally I like a series of small patches and that
> > is an
> > example of something that could have been done independently.  Remember
> > smaller patches are easier for everyone to review. It is often hard to
> > think that
> > way as you are working and knees deep in it, but it is important.
> > Add an _ after _Timecount_Get and rtems_get_ in various API methods. But the
> > rtems_get methods are (as Gedare pointed out) named incorrectly per the
> > RTEMS API naming patterns.
> The _ after get may not be needed if there is a reason such as wanting
> to be close to an upstream interface.
The names are derived from the FreeBSD <sys/time.h> kernel space API, e.g. bintime() -> rtems_bintime().  These functions have per se nothing to do with timecounters.  The timecounters are just one way to implement this API.  So maybe the <rtems/timecounter.h> header file is wrongly named, what about <rtems/time.h>?
The driver interface function is _Timecounter_Install().  Should we provide a rtems_timecounter_install()?
