[PATCH 21/42] LIBPCI: use RTEMS_INLINE_ROUTINE
    Daniel Hellstrom
    daniel at gaisler.com
    Tue Apr 14 11:32:48 UTC 2015
 cpukit/libpci/pci/access.h |   53 ++++++++++++++++++++++---------------------
 cpukit/libpci/pci/irq.h    |   22 ++++++++++-------
 2 files changed, 40 insertions(+), 35 deletions(-)
diff --git a/cpukit/libpci/pci/access.h b/cpukit/libpci/pci/access.h
index 7755b7a..f7df9e9 100644
--- a/cpukit/libpci/pci/access.h
+++ b/cpukit/libpci/pci/access.h
@@ -14,6 +14,7 @@
 #include <stdint.h>
 #include <libcpu/byteorder.h>
+#include <rtems/score/basedefs.h>
 #include <pci.h>
 /* Let BSP configure load/store from PCI */
@@ -129,32 +130,32 @@ extern int pci_access_drv_register(struct pci_access_drv *drv);
 extern void pci_modify_cmdsts(pci_dev_t dev, uint32_t mask, uint32_t val);
 /* Enable Memory in command register */
-static inline void pci_mem_enable(pci_dev_t dev)
+RTEMS_INLINE_ROUTINE void pci_mem_enable(pci_dev_t dev)
 	pci_modify_cmdsts(dev, PCIM_CMD_MEMEN, PCIM_CMD_MEMEN);
-static inline void pci_mem_disable(pci_dev_t dev)
+RTEMS_INLINE_ROUTINE void pci_mem_disable(pci_dev_t dev)
 	pci_modify_cmdsts(dev, PCIM_CMD_MEMEN, 0);
-static inline void pci_io_enable(pci_dev_t dev)
+RTEMS_INLINE_ROUTINE void pci_io_enable(pci_dev_t dev)
 	pci_modify_cmdsts(dev, PCIM_CMD_PORTEN, PCIM_CMD_PORTEN);
-static inline void pci_io_disable(pci_dev_t dev)
+RTEMS_INLINE_ROUTINE void pci_io_disable(pci_dev_t dev)
 	pci_modify_cmdsts(dev, PCIM_CMD_PORTEN, 0);
-static inline void pci_master_enable(pci_dev_t dev)
+RTEMS_INLINE_ROUTINE void pci_master_enable(pci_dev_t dev)
 	pci_modify_cmdsts(dev, PCIM_CMD_BUSMASTEREN, PCIM_CMD_BUSMASTEREN);
-static inline void pci_master_disable(pci_dev_t dev)
+RTEMS_INLINE_ROUTINE void pci_master_disable(pci_dev_t dev)
 	pci_modify_cmdsts(dev, PCIM_CMD_BUSMASTEREN, 0);
@@ -180,25 +181,25 @@ extern void pci_io_w16(uint32_t adr, uint16_t data);
 extern void pci_io_w32(uint32_t adr, uint32_t data);
 /* Translate PCI address into CPU accessible address */
-static inline int pci_pci2cpu(uint32_t *address, int type)
+RTEMS_INLINE_ROUTINE int pci_pci2cpu(uint32_t *address, int type)
 	return pci_access_ops.translate(address, type, 0);
 /* Translate CPU accessible address into PCI address (for DMA) */
-static inline int pci_cpu2pci(uint32_t *address, int type)
+RTEMS_INLINE_ROUTINE int pci_cpu2pci(uint32_t *address, int type)
 	return pci_access_ops.translate(address, type, 1);
 /*** Read/Write a register over PCI Memory Space ***/
-static inline uint8_t pci_ld8(volatile uint8_t *addr)
+RTEMS_INLINE_ROUTINE uint8_t pci_ld8(volatile uint8_t *addr)
 	return *addr;
-static inline void pci_st8(volatile uint8_t *addr, uint8_t val)
+RTEMS_INLINE_ROUTINE void pci_st8(volatile uint8_t *addr, uint8_t val)
 	*addr = val;
@@ -207,42 +208,42 @@ static inline void pci_st8(volatile uint8_t *addr, uint8_t val)
 /* BSP has decided Big Endian PCI Bus (non-standard) */
-static inline uint16_t pci_ld_le16(volatile uint16_t *addr)
+RTEMS_INLINE_ROUTINE uint16_t pci_ld_le16(volatile uint16_t *addr)
 	return ld_be16(addr);
-static inline void pci_st_le16(volatile uint16_t *addr, uint16_t val)
+RTEMS_INLINE_ROUTINE void pci_st_le16(volatile uint16_t *addr, uint16_t val)
 	st_be16(addr, val);
-static inline uint32_t pci_ld_le32(volatile uint32_t *addr)
+RTEMS_INLINE_ROUTINE uint32_t pci_ld_le32(volatile uint32_t *addr)
 	return ld_be32(addr);
-static inline void pci_st_le32(volatile uint32_t *addr, uint32_t val)
+RTEMS_INLINE_ROUTINE void pci_st_le32(volatile uint32_t *addr, uint32_t val)
 	st_be32(addr, val);
-static inline uint16_t pci_ld_be16(volatile uint16_t *addr)
+RTEMS_INLINE_ROUTINE uint16_t pci_ld_be16(volatile uint16_t *addr)
 	return ld_le16(addr);
-static inline void pci_st_be16(volatile uint16_t *addr, uint16_t val)
+RTEMS_INLINE_ROUTINE void pci_st_be16(volatile uint16_t *addr, uint16_t val)
 	st_le16(addr, val);
-static inline uint32_t pci_ld_be32(volatile uint32_t *addr)
+RTEMS_INLINE_ROUTINE uint32_t pci_ld_be32(volatile uint32_t *addr)
 	return ld_le32(addr);
-static inline void pci_st_be32(volatile uint32_t *addr, uint32_t val)
+RTEMS_INLINE_ROUTINE void pci_st_be32(volatile uint32_t *addr, uint32_t val)
 	st_le32(addr, val);
@@ -251,42 +252,42 @@ static inline void pci_st_be32(volatile uint32_t *addr, uint32_t val)
 /* Little Endian PCI Bus */
 	st_le16(addr, val);
 	st_le32(addr, val);
 	st_be16(addr, val);
 	st_be32(addr, val);
diff --git a/cpukit/libpci/pci/irq.h b/cpukit/libpci/pci/irq.h
index 3a7dfe4..d8cb0a2 100644
--- a/cpukit/libpci/pci/irq.h
+++ b/cpukit/libpci/pci/irq.h
@@ -1,8 +1,5 @@
 /* PCI IRQ Library
- * IRQ handling does not have so much with PCI to do, this library depends
- * on the BSP to implement shared interrupts.
  * COPYRIGHT (c) 2010 Cobham Gaisler AB.
  * The license and distribution terms for this file may be
@@ -10,13 +7,19 @@
  * http://www.rtems.com/license/LICENSE.
+/* IRQ handling does not have so much with PCI to do, this library depends
+ * on the BSP to implement shared interrupts.
 #ifndef __PCI_IRQ_H__
 #define __PCI_IRQ_H__
 #include <bsp.h>
+#include <rtems/irq-extension.h>
 /* PCI Handler (ISR) called when IRQ is generated by any of the PCI devices
- * connected to the same PCI IRQ Pin. This is been defined the same way as
+ * connected to the same PCI IRQ Pin. This has been defined the same way as
  * rtems_interrupt_handler in order for BSPs to "direct-map" the register
  * and unregister functions rtems_interrupt_handler_install/remove
@@ -37,7 +40,7 @@ extern int pci_dev_irq(pci_dev_t dev);
  *  isr       Function pointer to the ISR
  *  arg       Second argument to function isr
-static inline int pci_interrupt_register(int irq, const char *info,
+RTEMS_INLINE_ROUTINE int pci_interrupt_register(int irq, const char *info,
 						pci_isr isr, void *arg)
 	return BSP_PCI_shared_interrupt_register(irq, info, isr, arg);
@@ -50,7 +53,8 @@ static inline int pci_interrupt_register(int irq, const char *info,
-static inline int pci_interrupt_unregister(int irq, pci_isr isr, void *arg)
+RTEMS_INLINE_ROUTINE int pci_interrupt_unregister(int irq, pci_isr isr,
+						  void *arg)
 	return BSP_PCI_shared_interrupt_unregister(irq, isr, arg);
@@ -66,7 +70,7 @@ static inline int pci_interrupt_unregister(int irq, pci_isr isr, void *arg)
-static inline void pci_interrupt_unmask(int irq)
+RTEMS_INLINE_ROUTINE void pci_interrupt_unmask(int irq)
 	BSP_PCI_shared_interrupt_unmask(irq);
@@ -82,7 +86,7 @@ static inline void pci_interrupt_unmask(int irq)
-static inline void pci_interrupt_mask(int irq)
+RTEMS_INLINE_ROUTINE void pci_interrupt_mask(int irq)
 	BSP_PCI_shared_interrupt_mask(irq);
@@ -96,7 +100,7 @@ static inline void pci_interrupt_mask(int irq)
-static inline void pci_interrupt_clear(int irq)
+RTEMS_INLINE_ROUTINE void pci_interrupt_clear(int irq)
 	BSP_PCI_shared_interrupt_clear(irq);
1.7.0.4
