[PING][PATCH v2] Change the assert in _Thread_Dispatch_decrement_disable_level
    Martin Galvan
    martin.galvan at tallertechnologies.com
    Fri Apr 17 12:35:09 UTC 2015
Thanks a lot!
On Fri, Apr 17, 2015 at 7:18 AM, Sebastian Huber
> I checked in a slightly modified version.
> On 16/04/15 16:27, Martin Galvan wrote:
>> While cpu_self->thread_dispatch_disable_level shouldn't ever be zero, it
>> would be better to check it before doing the decrement.
>> Changes in v2:
>>   * Modified the asserts as requested in
>> https://lists.rtems.org/pipermail/devel/2015-February/009821.html.
>>   cpukit/score/src/threaddispatchdisablelevel.c | 6 +++++-
>>   1 file changed, 5 insertions(+), 1 deletion(-)
>> diff --git a/cpukit/score/src/threaddispatchdisablelevel.c
>> b/cpukit/score/src/threaddispatchdisablelevel.c
>> index 158fc39..6043fe7 100644
>> --- a/cpukit/score/src/threaddispatchdisablelevel.c
>> +++ b/cpukit/score/src/threaddispatchdisablelevel.c
>> @@ -107,11 +107,15 @@ uint32_t _Thread_Dispatch_decrement_disable_level(
>> void )
>>     cpu_self = _Per_CPU_Get();
>>     disable_level = cpu_self->thread_dispatch_disable_level;
>> +  _Assert( disable_level > 0);
>>     --disable_level;
>>     cpu_self->thread_dispatch_disable_level = disable_level;
>>     _Giant_Do_release( cpu_self );
>> -  _Assert( disable_level != 0 || _Giant.owner_cpu != cpu_self );
>> +  _Assert( ( disable_level == 0 && _Giant.owner_cpu != cpu_self )
>> +    || ( disable_level != 0 && _Giant.owner_cpu == cpu_self )
>>     _Profiling_Thread_dispatch_enable( cpu_self, disable_level );
>>     _ISR_Enable_without_giant( isr_level );
>> 2.3.4
Martin Galvan
Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: 54 351 4217888 / +54 351 4218211
