[PATCH] [RPI BSP] mailbox
Thu Apr 23 02:27:25 UTC 2015
On 4/19/2015 2:17 PM, QIAO YANG wrote:
> Here is a modified patch for mailbox.  If there's still anything
> against the convention, please point it out and I'll correct it
> immediately. The mailbox implementation might also be needed by other
> rpi bsp developpers.
My understanding is that the mailbox is used to determine the board
version and memory size.
What did you use the mailbox for to test it?
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> index c6133df..70bc01d 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> @@ -43,6 +43,7 @@ include_bsp_HEADERS +=
> ../shared/include/arm-release-id.h
>  include_bsp_HEADERS += include/irq.h
>  include_bsp_HEADERS += include/mmu.h
>  include_bsp_HEADERS += include/usart.h
> +include_bsp_HEADERS += include/mailbox.h
>  include_bsp_HEADERS += include/raspberrypi.h
>  include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
> @@ -123,6 +124,9 @@ libbsp_a_SOURCES += misc/timer.c
>  # I2C
> +# Mailbox
> +libbsp_a_SOURCES += misc/mailbox.c
>  # Cache
>  libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
>  libbsp_a_SOURCES += ../../../libcpu/arm/shared/include/cache_.h
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
> b/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
> new file mode 100644
> index 0000000..fa6a0c2
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
> @@ -0,0 +1,33 @@
> + * @file
> + * @ingroup raspberrypi
> + * @brief mailbox support.
> + * Copyright (c) 2015 Yang Qiao
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE
> +#ifndef LIBBSP_ARM_RASPBERRYPI_MAILBOX_H
> +#define LIBBSP_ARM_RASPBERRYPI_MAILBOX_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +extern unsigned int  raspberrypi_mailbox_read(unsigned int channel);
> +extern void raspberrypi_mailbox_write(unsigned int channel, unsigned
> int data);
> +#ifdef __cplusplus
> +#endif  /* LIBBSP_ARM_RASPBERRYPI_MAILBOX_H */
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
> b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
> index c33e22a..3240404 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
> +++ b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
> @@ -208,6 +208,55 @@
> + * @name Mailbox Registers
> +#define BCM2835_MBOX_BASE (RPI_PERIPHERAL_BASE+0xB880)
> +#define BCM2835_MBOX_PEEK (BCM2835_MBOX_BASE+0x10)
> +#define BCM2835_MBOX_READ (BCM2835_MBOX_BASE+0x00)
> +#define BCM2835_MBOX_WRITE (BCM2835_MBOX_BASE+0x20)
> +#define BCM2835_MBOX_STATUS (BCM2835_MBOX_BASE+0x18)
> +#define BCM2835_MBOX_SENDER (BCM2835_MBOX_BASE+0x14)
> +#define BCM2835_MBOX_CONFIG (BCM2835_MBOX_BASE+0x1C)
> +#define BCM2835_MBOX_SUCCESS (BCM2835_MBOX_BASE+0x80000000)
> +#define BCM2835_MBOX_FULL (BCM2835_MBOX_BASE+0x80000000)
> +#define BCM2835_MBOX_EMPTY (BCM2835_MBOX_BASE+0x40000000)
> +* @name Mailbox Channels
> +/* Power Manager channel */
> +#define BCM2835_MBOX_CHANNEL_PM         0
> +/* Framebuffer channel */
> +#define BCM2835_MBOX_CHANNEL_FB         1
> + /* Virtual UART channel */
> +#define BCM2835_MBOX_CHANNEL_VUART      2
> + /* VCHIQ channel */
> +#define BCM2835_MBOX_CHANNEL_VCHIQ      3
> + /* LEDs channel */
> +#define BCM2835_MBOX_CHANNEL_LED        4
> + /* Button channel */
> +#define BCM2835_MBOX_CHANNEL_BUTTON     5
> + /* Touch screen channel */
> +#define BCM2835_MBOX_CHANNEL_TOUCHS     6
> +/* Property tags (ARM <-> VC) channel */
> +#define BCM2835_MBOX_CHANNEL_PROP_AVC   8
> + /* Property tags (VC <-> ARM) channel */
> +#define BCM2835_MBOX_CHANNEL_PROP_VCA   9
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
> b/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
> index 0000000..2a63a41
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
> @@ -0,0 +1,44 @@
> + * @file
> +#include <stdint.h>
> +#include <bsp/raspberrypi.h>
> +#include <bsp/mailbox.h>
> +unsigned int raspberrypi_mailbox_read (unsigned int channel)
> +  unsigned int data;
> +  unsigned int read_channel;
> +  while ( 1 )
> +    while (BCM2835_REG (BCM2835_MBOX_STATUS ) & BCM2835_MBOX_EMPTY);
> +    data = BCM2835_REG (BCM2835_MBOX_READ );
> +    read_channel = (unsigned int) (data & 0xF );
> +    if (read_channel == channel)
> +      return (data & 0xFFFFFFF0);
> +void raspberrypi_mailbox_write(unsigned int channel, unsigned int data)
> +  while (BCM2835_REG(BCM2835_MBOX_STATUS) & BCM2835_MBOX_FULL);
> +  BCM2835_REG(BCM2835_MBOX_WRITE) =
> +    (data & 0xFFFFFFF0) |
> +    (unsigned int) (channel & 0xF);
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
> b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
> index 70259e2..4cb7ed6 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
> +++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
> @@ -126,6 +126,10 @@ $(PROJECT_INCLUDE)/bsp/usart.h: include/usart.h
> $(PROJECT_INCLUDE)/bsp/$(dirstam
>      $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/usart.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/usart.h
> +$(PROJECT_INCLUDE)/bsp/mailbox.h: include/mailbox.h
> $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mailbox.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mailbox.h
>  $(PROJECT_INCLUDE)/bsp/raspberrypi.h: include/raspberrypi.h
>      $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/raspberrypi.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/raspberrypi.h
> On Apr 16, 2015, at 11:20 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Are you working to make the corrections I mentioned?
>> On Tue, Apr 7, 2015 at 10:05 AM, Gedare Bloom <gedare at rtems.org
>> <mailto:gedare at rtems.org>> wrote:
>>> On Mon, Apr 6, 2015 at 5:12 PM, QIAO YANG <yangqiao0505 at me.com
>>>> # I2C
>>>> +# Mailbox
>>>> # Cache
>>>> index 0000000..abdb258
>>>> --- /dev/null
>>>> @@ -0,0 +1,7 @@
>>> Need file header documentation. Please see
>>> https://devel.rtems.org/wiki/Developer/Coding/Conventions
>>>> +#ifndef MAILBOX_H
>>>> +#define MAILBOX_H
>>>> +extern unsigned int readmailbox(unsigned int channel);
>>>> +extern void writemailbox(unsigned int channel, unsigned int data);
>>> Please use function names with a "namespace". the usual convention in
>>> RTEMS is to use Package_Class_Method like raspberrypi_mailbox_read()
>>> and raspberrypi_mailbox_write().
>>>> +#endif /* MAILBOX_H */
>>>> \ No newline at end of file
>>>> index c33e22a..e4ce18f 100644
>>>> @@ -208,6 +208,52 @@
>>>> + * NOTE:
>>>> +/* Property tags (ARM <-> Video Core) channel */
>>>> + /* Property tags (Video Core <-> ARM) channel */
>>>> index 0000000..7bfb7e3
>>>> --- /dev/null
>>>> @@ -0,0 +1,22 @@
>>>> +unsigned int readmailbox ( unsigned int channel )
>>>> + while ( 1 )
>>>> + while ( BCM2835_REG ( BCM2835_MBOX_STATUS ) &
>>>> BCM2835_MBOX_EMPTY );
>>>> + data = BCM2835_REG ( BCM2835_MBOX_READ );
>>>> + read_channel = ( unsigned int ) ( data & 0xF );
>>>> + if ( read_channel == channel )
>>>> + return ( data & 0xFFFFFFF0 );
>>> The white spaces look wrong here. Are they tabs? Or 8 blank spaces?
>>> Please check the style rules in the Coding Conventions page.
>>>> +void writemailbox( unsigned int channel, unsigned int data )
>>>> + while ( BCM2835_REG ( BCM2835_MBOX_STATUS ) & BCM2835_MBOX_FULL );
>>>> + BCM2835_REG (BCM2835_MBOX_WRITE) = ( data & 0xFFFFFFF0 ) | (unsigned
>>>> int) ( channel & 0xF );
>>>> Here is a patch for rpi bsp which include the operation and chanel
>>>> defininitions for mailbox and its implementations.
>>>> I've only tested the framebuffer with it and it works well : set
>>>> the screen
>>>> size and get the informations.
>>>> Andre used it for sd card reading. I've checked it out and added full
>>>> channel definitions.
>>>> Please point it out if further tests should be done.
>>>> YANG QIAO
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org <mailto:devel at rtems.org>
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150422/9c4efcb9/attachment-0002.html>
