GSoC 2015 RPi USB Support
Yurii Shevtsov ungetch at gmail.com
Sat Aug 1 21:00:20 UTC 2015
During debugging of compiled Nexus module(driver) I found out that
content which suppose to be created in RTEMS_BSD_DEFINE_SET(nexus,
rtems_bsd_device) is empty, That should mean that either it is not
found or cannot be read. Please, let me know why empty content is not
create any error message and in what situation it can be empty.
2015-06-29 19:50 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
> So, it is empty.
>  .rtemsroset.bsd.nexus.begin
>                 0x001104bc        0x0 ./libbsd.a(rtems-bsd-nexus.c.16.o)
>                 0x001104bc                _bsd__start_set_nexus
>  .rtemsroset.bsd.nexus.end
>                 0x001104bc                _bsd__stop_set_nexus
> What will be next step? My repo:
> https://github.com/gtament/rtems-libbsd/commit/cf3f0fcafef3bcb9b0ec80d8c57e1304689ebace
> 2015-06-29 9:43 GMT+03:00 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>> You can debug this issue on Qemu. The Nexus childes are registered in a
>> linker set, so I would consult the linker map file.  It should look like
>> this:
>>                 0x000000000052ef7c        0x0 libbsd.a(rtems-bsd-nexus.o)
>>                 0x000000000052ef7c _bsd__start_set_nexus
>>  .rtemsroset.bsd.nexus.content
>>                 0x000000000052ef7c       0x28
>> testsuite/telnetd01/test_main.o
>>                 0x000000000052efa4        0x0 libbsd.a(rtems-bsd-nexus.o)
>>                 0x000000000052efa4 _bsd__stop_set_nexus
>> The  .rtemsroset.bsd.nexus.content section must be non-empty.
>> On 27/06/15 16:39, Yurii Shevtsov wrote:
>>> Any ideas? Maybe I did some typo? Maybe you can compile and try it in
>>> qemu?
>>> 2015-06-26 17:05 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>>>> 2015-06-25 16:00 GMT+03:00 Sebastian Huber
>>>>> I would set a break point to nexus_probe(). In this loop
>>>>>      SET_FOREACH(nd, nexus) {
>>>>>          device_add_child(dev, nd->name, nd->unit);
>>>>> your device must get added. I would also set break points to the probe
>>>>> and
>>>>> attach functions of your device.
>>>> Added printfs()
>>>>      printf("before setforeach\n");
>>>>          printf("setforeach: %s\n", nd->name);
>>>> Got only 'before setforeach' in console. So it doesn't step into loop.
>>>> Any ideas? Also I already had printfs in my driver's probe and attach,
>>>> also got no output.
>>>>> On 25/06/15 14:50, Yurii Shevtsov wrote:
>>>>>> This is ping message, with small update: the problem is not on the
>>>>>> linking stage, driver is linked to testsuite (checked with objdump)
>>>>>> 2015-06-21 17:57 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>>>>>>> Hello)
>>>>>>> Now I have apps from libbsd testsuite running. But DWC OTG driver
>>>>>>> doesn't
>>>>>>> loads.
>>>>>>> I added this lines to init01/test_main.c:
>>>>>>> +SYSINIT_NEED_USB_CORE;
>>>>>>> +SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
>>>>>>> (I know it's bad hardcode)
>>>>>>> If I run it. I get only this:
>>>>>>>     nexus0: <RTEMS Nexus device>
>>>>>>>     devctl: +nexus0 at   on root0
>>>>>>>     devctl: !system=IFNET subsystem=lo0 type=ATTACH
>>>>>>> Of course, I modified rtemsbsd/include/machine/rtems-bsd-sysinit.h and
>>>>>>> rtemsbsd/include/bsp/nexus-devices.h (took vlues from working DTS) and
>>>>>>> did other nexus-related changes to drivers. You can find changes in my
>>>>>>> repo https://github.com/gtament/rtems-libbsd/
>>>>>>> So I need some kind of code review, please.
>>>>>>> P.S. All testsuites (netshell01, usb01) with shell hangs without any
>>>>>>> output.
>>>>>>> Thanks in advance!
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>> Sebastian Huber, embedded brains GmbH
>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>> Phone   : +49 89 189 47 41-16
>>>>> Fax     : +49 89 189 47 41-09
>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>> PGP     : Public key available on request.
>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
