[PATCH] Fix missing include for PTHREAD_MINIMUM_STACK_SIZE
Sun Aug 2 15:20:01 UTC 2015
On 08/01/2015 12:48 PM, Jan Sommer wrote:
> Am Samstag, 1. August 2015, 12:31:53 schrieb Joel Sherrill:
>> On 08/01/2015 12:24 PM, Jan Sommer wrote:
>>> Yes, I needed to add it to make the ada-examples compile.
>> Did it need to be included anywhere other than libgnat/adasupp.c?
> Well, so far I haven't encountered the problem somewhere else, but have been working with the Ada-examples mainly atm.
>> Sebastian reworked public vs private .h files and more includes moved
>> to .c files. Since everything but Ada specific support files compile
>> on every target, I am prone to want to fix the file that needs this.
> I see. I just saw that pthreadimpl.h defines a call to a function it does not include and thought it might be slipped at some point because it's not used often.
> I don't mind keeping it local. My goal is to spend less time with the examples in the future anyway ;-)
I did a test build of 4.11 and master this morning. No patch was
needed to built libgnat.
But the Ada tests have an init.c which needs some love. Did you
attempt to build the Ada tests? Just curious before I dive too far
into fixing ada-tests/support/init.c.
>> I would check for my patches but I appear to have deleted my RTEMS
>> clone since then and lost the small patch I had. :(
>> --joel
>>> Am Samstag, 1. August 2015, 12:08:12 schrieb Joel Sherrill:
>>>> Can you give a configuration or file that broke with this?
>>>> I recall that I had a local patch that just added this line to an Ada specific C file. Nothing else broke.
>>>> On August 1, 2015 5:51:31 AM CDT, Jan Sommer<soja-lists at aries.uberspace.de>   wrote:
>>>>> cpukit/posix/include/rtems/posix/pthreadimpl.h | 1 +
>>>>> 1 file changed, 1 insertion(+)
>>>>> diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h
>>>>> b/cpukit/posix/include/rtems/posix/pthreadimpl.h
>>>>> index f95ac9c..33fa33d 100644
>>>>> --- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
>>>>> +++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
>>>>> @@ -24,6 +24,7 @@
>>>>> #include<rtems/posix/threadsup.h>
>>>>> #include<rtems/score/objectimpl.h>
>>>>> #include<rtems/score/threadimpl.h>
>>>>> +#include<rtems/score/stackimpl.h>
>>>>> #include<rtems/score/assert.h>
>>>>> #ifdef __cplusplus
>>>> --joel
-- Joel Sherrill
Ask me about RTEMS: a free RTOS
Support and Training Available
