[PATCH] Fix missing include for PTHREAD_MINIMUM_STACK_SIZE
Jan Sommer soja-lists at aries.uberspace.de
Sun Aug 2 17:35:29 UTC 2015
Am Sonntag, 2. August 2015, 10:34:05 schrieb Joel Sherrill:
> Top posting.. ada-tests now build on at least 4.11. I committed
> the same patch to the master so they should build there. I
> didn't run any.
Quick question: How do I build the tests?
The configure output says "--enable-tests          enable tests (default:samples)"
And looking at enable-tests.m4 it seems other options are yes and no, so the ada-tests will build if I set it to "yes"?
Are they part of "make all", because I remember in the beginning I couldn't find the built samples.
> --joel
> On 08/02/2015 10:20 AM, Joel Sherrill wrote:
> > On 08/01/2015 12:48 PM, Jan Sommer wrote:
> >> Am Samstag, 1. August 2015, 12:31:53 schrieb Joel Sherrill:
> >>> On 08/01/2015 12:24 PM, Jan Sommer wrote:
> >>>> Yes, I needed to add it to make the ada-examples compile.
> >>> Did it need to be included anywhere other than libgnat/adasupp.c?
> >> Well, so far I haven't encountered the problem somewhere else, but have been working with the Ada-examples mainly atm.
> >>> Sebastian reworked public vs private .h files and more includes moved
> >>> to .c files. Since everything but Ada specific support files compile
> >>> on every target, I am prone to want to fix the file that needs this.
> >> I see. I just saw that pthreadimpl.h defines a call to a function it does not include and thought it might be slipped at some point because it's not used often.
> >> I don't mind keeping it local. My goal is to spend less time with the examples in the future anyway ;-)
> > I did a test build of 4.11 and master this morning. No patch was
> > needed to built libgnat.
> > But the Ada tests have an init.c which needs some love. Did you
> > attempt to build the Ada tests? Just curious before I dive too far
> > into fixing ada-tests/support/init.c.
> >>> I would check for my patches but I appear to have deleted my RTEMS
> >>> clone since then and lost the small patch I had. :(
> >>> --joel
> >>>> Am Samstag, 1. August 2015, 12:08:12 schrieb Joel Sherrill:
> >>>>> Can you give a configuration or file that broke with this?
> >>>>> I recall that I had a local patch that just added this line to an Ada specific C file. Nothing else broke.
> >>>>> On August 1, 2015 5:51:31 AM CDT, Jan Sommer<soja-lists at aries.uberspace.de>    wrote:
> >>>>>> cpukit/posix/include/rtems/posix/pthreadimpl.h | 1 +
> >>>>>> 1 file changed, 1 insertion(+)
> >>>>>> diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h
> >>>>>> b/cpukit/posix/include/rtems/posix/pthreadimpl.h
> >>>>>> index f95ac9c..33fa33d 100644
> >>>>>> --- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
> >>>>>> +++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
> >>>>>> @@ -24,6 +24,7 @@
> >>>>>> #include<rtems/posix/threadsup.h>
> >>>>>> #include<rtems/score/objectimpl.h>
> >>>>>> #include<rtems/score/threadimpl.h>
> >>>>>> +#include<rtems/score/stackimpl.h>
> >>>>>> #include<rtems/score/assert.h>
> >>>>>> #ifdef __cplusplus
> >>>>> --joel
