Uniprocessor implementation of Nested Mutex problem.
Saurabh Gadia
gadia at usc.edu
Thu Aug 6 00:33:14 UTC 2015
For surrender we don't disable thread dispatching for uniprocessor. So is
that the thread can be interleaved?
Thanks,
Saurabh Gadia
On Wed, Aug 5, 2015 at 9:01 AM, Gedare Bloom <gedare at rtems.org> wrote:
> These functions are called with interrupts disabled. However,
> _CORE_mutex_Seize_interrupt_blocking() enables interrupts, so an isr
> can preempt the thread, but but it will not be interleaved with
> another thread because thread dispatching is disabled around the isr
> enabled section. I don't believe surrender has any such situations.
> Gedare
> On Tue, Aug 4, 2015 at 9:39 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> > Hi,
> > So on uniprocessor can we assume that a thread calling
> > _CORE_mutex_Seize_body or _CORE_mutex_Surrender never gets preempted or
> > interleaved as if it holds a global lock. Whcih means that we can create
> a
> > JPF model for same using global lock.
> > Thanks,
> > Saurabh Gadia
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150805/beff1111/attachment-0001.html>
