GSoC 2015 RPi USB Support
Yurii Shevtsov ungetch at gmail.com
Thu Aug 6 20:57:40 UTC 2015
What do you mean by "getting pulled"?
2015-08-06 23:48 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
> On 8/6/2015 3:42 PM, Yurii Shevtsov wrote:
>> 2015-08-06 23:36 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>> On 8/6/2015 3:22 PM, Yurii Shevtsov wrote:
>>>> Ping! Any news?
>>> The people with experience with the libbsd code is quite small. :(
>>>> 2015-08-05 18:29 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>>>>> The problem is that rtemsroset.bsd.nexus.content doesn't exist in
>>>>> final elf. If I change driver's name in RTEMS_BSD_DEFINE_NEXUS_DEVICE
>>>>> macro, linker will throw an error
>>>>> (.rtemsroset.bsd.nexus.content+0x10): undefined reference to '%wrong
>>>>> driver's name%'. Otherwise with correct name - no errors(warnings) and
>>>>> no nexus.content section. How can you explain this??
>>> The RTEMS_BSD_DEFINE_NEXUS_DEVICE() macro must reference a bus/mexus,
>>> not a regular device driver. I would expect a nexus device for the Pi
>>> to be in
>>> https://github.com/freebsd/freebsd/tree/master/sys/arm/broadcom/bcm2835
>>> or pointed to by a file in there.
>>> Look at the configuration for the various bsps in nexus-devices.h and
>>> then at the source the macros refer to.
>>> Raspberry Pi source will have to be imported from the FreeBSD tree.
>> Of course, I did it!)
>> https://github.com/gtament/rtems-libbsd/commit/cf3f0fcafef3bcb9b0ec80d8c57e1304689ebace
> Is bcm283x_dwcotg* getting pulled into your build?
>>>>> 2015-08-02 18:02 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>> On 08/01/2015 04:00 PM, Yurii Shevtsov wrote:
>>>>>>> During debugging of compiled Nexus module(driver) I found out that
>>>>>>> content which suppose to be created in RTEMS_BSD_DEFINE_SET(nexus,
>>>>>>> rtems_bsd_device) is empty, That should mean that either it is not
>>>>>>> found or cannot be read. Please, let me know why empty content is not
>>>>>>> create any error message and in what situation it can be empty.
>>>>>> Sebastian just added the pc386 to the nexus-devices file. Make sure
>>>>>> the bsp.h is tripping the conditional logic in that file to get the Pi
>>>>>> path as a minimum.
>>>>>> Then you are going to need to add the appropriate devices for Pi
>>>>>> USB.  If the Pi  doesn't have one of the standard USB controllers,
>>>>>> then
>>>>>> you will have to import the source for it from FreeBSD.
>>>>>> The pc386 is stuck at the point where it detects the NIC configured
>>>>>> but needs resources. I am going to try to debug that.
>>>>>>> 2015-06-29 19:50 GMT+03:00 Yurii Shevtsov<ungetch at gmail.com>:
>>>>>>>> So, it is empty.
>>>>>>>>     .rtemsroset.bsd.nexus.begin
>>>>>>>>                    0x001104bc        0x0
>>>>>>>> ./libbsd.a(rtems-bsd-nexus.c.16.o)
>>>>>>>>                    0x001104bc                _bsd__start_set_nexus
>>>>>>>>     .rtemsroset.bsd.nexus.end
>>>>>>>>                    0x001104bc        0x0
>>>>>>>>                    0x001104bc                _bsd__stop_set_nexus
>>>>>>>> What will be next step? My repo:
>>>>>>>> 2015-06-29 9:43 GMT+03:00 Sebastian
>>>>>>>> Huber<sebastian.huber at embedded-brains.de>:
>>>>>>>>> You can debug this issue on Qemu. The Nexus childes are registered
>>>>>>>>> in
>>>>>>>>> a
>>>>>>>>> linker set, so I would consult the linker map file.  It should look
>>>>>>>>> like
>>>>>>>>> this:
>>>>>>>>>                    0x000000000052ef7c        0x0
>>>>>>>>> libbsd.a(rtems-bsd-nexus.o)
>>>>>>>>>                    0x000000000052ef7c _bsd__start_set_nexus
>>>>>>>>>                    0x000000000052ef7c       0x28
>>>>>>>>> testsuite/telnetd01/test_main.o
>>>>>>>>>                    0x000000000052efa4        0x0
>>>>>>>>>                    0x000000000052efa4 _bsd__stop_set_nexus
>>>>>>>>> The  .rtemsroset.bsd.nexus.content section must be non-empty.
>>>>>>>>> On 27/06/15 16:39, Yurii Shevtsov wrote:
>>>>>>>>>> Any ideas? Maybe I did some typo? Maybe you can compile and try it
>>>>>>>>>> in
>>>>>>>>>> qemu?
>>>>>>>>>> 2015-06-26 17:05 GMT+03:00 Yurii Shevtsov<ungetch at gmail.com>:
>>>>>>>>>>> 2015-06-25 16:00 GMT+03:00 Sebastian Huber
>>>>>>>>>>>> I would set a break point to nexus_probe(). In this loop
>>>>>>>>>>>>         SET_FOREACH(nd, nexus) {
>>>>>>>>>>>>             device_add_child(dev, nd->name, nd->unit);
>>>>>>>>>>>> your device must get added. I would also set break points to the
>>>>>>>>>>>> probe
>>>>>>>>>>>> and
>>>>>>>>>>>> attach functions of your device.
>>>>>>>>>>> Added printfs()
>>>>>>>>>>>         printf("before setforeach\n");
>>>>>>>>>>>             printf("setforeach: %s\n", nd->name);
>>>>>>>>>>> Got only 'before setforeach' in console. So it doesn't step into
>>>>>>>>>>> loop.
>>>>>>>>>>> Any ideas? Also I already had printfs in my driver's probe and
>>>>>>>>>>> attach,
>>>>>>>>>>> also got no output.
>>>>>>>>>>>> On 25/06/15 14:50, Yurii Shevtsov wrote:
>>>>>>>>>>>>> This is ping message, with small update: the problem is not on
>>>>>>>>>>>>> the
>>>>>>>>>>>>> linking stage, driver is linked to testsuite (checked with
>>>>>>>>>>>>> objdump)
>>>>>>>>>>>>> 2015-06-21 17:57 GMT+03:00 Yurii Shevtsov<ungetch at gmail.com>:
>>>>>>>>>>>>>> Hello)
>>>>>>>>>>>>>> Now I have apps from libbsd testsuite running. But DWC OTG
>>>>>>>>>>>>>> driver
>>>>>>>>>>>>>> doesn't
>>>>>>>>>>>>>> loads.
>>>>>>>>>>>>>> I added this lines to init01/test_main.c:
>>>>>>>>>>>>>> +SYSINIT_NEED_USB_CORE;
>>>>>>>>>>>>>> +SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
>>>>>>>>>>>>>> (I know it's bad hardcode)
>>>>>>>>>>>>>> If I run it. I get only this:
>>>>>>>>>>>>>>        nexus0:<RTEMS Nexus device>
>>>>>>>>>>>>>>        devctl: +nexus0 at   on root0
>>>>>>>>>>>>>>        devctl: !system=IFNET subsystem=lo0 type=ATTACH
>>>>>>>>>>>>>> Of course, I modified
>>>>>>>>>>>>>> rtemsbsd/include/machine/rtems-bsd-sysinit.h
>>>>>>>>>>>>>> and
>>>>>>>>>>>>>> rtemsbsd/include/bsp/nexus-devices.h (took vlues from working
>>>>>>>>>>>>>> DTS)
>>>>>>>>>>>>>> and
>>>>>>>>>>>>>> did other nexus-related changes to drivers. You can find
>>>>>>>>>>>>>> changes
>>>>>>>>>>>>>> in
>>>>>>>>>>>>>> my
>>>>>>>>>>>>>> repo https://github.com/gtament/rtems-libbsd/
>>>>>>>>>>>>>> So I need some kind of code review, please.
>>>>>>>>>>>>>> P.S. All testsuites (netshell01, usb01) with shell hangs
>>>>>>>>>>>>>> without
>>>>>>>>>>>>>> any
>>>>>>>>>>>>>> output.
>>>>>>>>>>>>>> Thanks in advance!
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>>>>> Sebastian Huber, embedded brains GmbH
>>>>>>>>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>>>>>>>>> Phone   : +49 89 189 47 41-16
>>>>>>>>>>>> Fax     : +49 89 189 47 41-09
>>>>>>>>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>>>>>>>>> PGP     : Public key available on request.
>>>>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>>>>>>>>>>>> EHUG.
>>>>>>>>> EHUG.
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
>>>>>> -- Joel Sherrill
>>>>>> Ask me about RTEMS: a free RTOS
>>>>>> Support and Training Available
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
