GSoC 2015 RPi USB Support
Thu Aug 6 21:23:31 UTC 2015
On 8/6/2015 4:16 PM, Yurii Shevtsov wrote:
> 2015-08-07 0:08 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>> On August 6, 2015 3:57:40 PM CDT, Yurii Shevtsov <ungetch at gmail.com> wrote:
>>> What do you mean by "getting pulled"?
>> As I understood things, you had a linked executable but an empty section. Just curious if your devices were showing up at all.
> Yes, exactly. If you mean is probe function being executed, the answer is ''no"
You have to associate the drivers with a nexus bus.  Something like this
SYSINIT_DRIVER_REFERENCE(mmc, dw_mmc);
SYSINIT_DRIVER_REFERENCE(mmcsd, mmc);
That's from the Altera Cyclone.
You only configured a nexus device and didn't hang anything off it.
>>> 2015-08-06 23:48 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>> On 8/6/2015 3:42 PM, Yurii Shevtsov wrote:
>>>>> 2015-08-06 23:36 GMT+03:00 Joel Sherrill
>>>>>> On 8/6/2015 3:22 PM, Yurii Shevtsov wrote:
>>>>>>> Ping! Any news?
>>>>>> The people with experience with the libbsd code is quite small. :(
>>>>>>> 2015-08-05 18:29 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>>>>>>>> The problem is that rtemsroset.bsd.nexus.content doesn't exist in
>>>>>>>> final elf. If I change driver's name in
>>> RTEMS_BSD_DEFINE_NEXUS_DEVICE
>>>>>>>> macro, linker will throw an error
>>>>>>>> (.rtemsroset.bsd.nexus.content+0x10): undefined reference to
>>> '%wrong
>>>>>>>> driver's name%'. Otherwise with correct name - no
>>> errors(warnings) and
>>>>>>>> no nexus.content section. How can you explain this??
>>>>>> The RTEMS_BSD_DEFINE_NEXUS_DEVICE() macro must reference a
>>> bus/mexus,
>>>>>> not a regular device driver. I would expect a nexus device for the
>>> Pi
>>>>>> to be in
>>> https://github.com/freebsd/freebsd/tree/master/sys/arm/broadcom/bcm2835
>>>>>> or pointed to by a file in there.
>>>>>> Look at the configuration for the various bsps in nexus-devices.h
>>> and
>>>>>> then at the source the macros refer to.
>>>>>> Raspberry Pi source will have to be imported from the FreeBSD tree.
>>>>> Of course, I did it!)
>>> https://github.com/gtament/rtems-libbsd/commit/cf3f0fcafef3bcb9b0ec80d8c57e1304689ebace
>>>> Is bcm283x_dwcotg* getting pulled into your build?
>>>>>>>> 2015-08-02 18:02 GMT+03:00 Joel Sherrill
>>>>>>>>> On 08/01/2015 04:00 PM, Yurii Shevtsov wrote:
>>>>>>>>>> During debugging of compiled Nexus module(driver) I found out
>>> that
>>>>>>>>>> content which suppose to be created in
>>> RTEMS_BSD_DEFINE_SET(nexus,
>>>>>>>>>> rtems_bsd_device) is empty, That should mean that either it is
>>> not
>>>>>>>>>> found or cannot be read. Please, let me know why empty content
>>> is not
>>>>>>>>>> create any error message and in what situation it can be empty.
>>>>>>>>> Sebastian just added the pc386 to the nexus-devices file. Make
>>> sure
>>>>>>>>> the bsp.h is tripping the conditional logic in that file to get
>>> the Pi
>>>>>>>>> path as a minimum.
>>>>>>>>> Then you are going to need to add the appropriate devices for Pi
>>>>>>>>> USB.  If the Pi  doesn't have one of the standard USB
>>> controllers,
>>>>>>>>> then
>>>>>>>>> you will have to import the source for it from FreeBSD.
>>>>>>>>> The pc386 is stuck at the point where it detects the NIC
>>> configured
>>>>>>>>> but needs resources. I am going to try to debug that.
>>>>>>>>>> 2015-06-29 19:50 GMT+03:00 Yurii Shevtsov<ungetch at gmail.com>:
>>>>>>>>>>> So, it is empty.
>>>>>>>>>>>      .rtemsroset.bsd.nexus.begin
>>>>>>>>>>>                     0x001104bc        0x0
>>>>>>>>>>> ./libbsd.a(rtems-bsd-nexus.c.16.o)
>>>>>>>>>>>                     0x001104bc
>>> _bsd__start_set_nexus
>>>>>>>>>>>      .rtemsroset.bsd.nexus.end
>>>>>>>>>>>                     0x001104bc        0x0
>>>>>>>>>>>                     0x001104bc
>>> _bsd__stop_set_nexus
>>>>>>>>>>> What will be next step? My repo:
>>>>>>>>>>> 2015-06-29 9:43 GMT+03:00 Sebastian
>>>>>>>>>>> Huber<sebastian.huber at embedded-brains.de>:
>>>>>>>>>>>> You can debug this issue on Qemu. The Nexus childes are
>>> registered
>>>>>>>>>>>> in
>>>>>>>>>>>> a
>>>>>>>>>>>> linker set, so I would consult the linker map file.  It
>>> should look
>>>>>>>>>>>> like
>>>>>>>>>>>> this:
>>>>>>>>>>>>                     0x000000000052ef7c        0x0
>>>>>>>>>>>> libbsd.a(rtems-bsd-nexus.o)
>>>>>>>>>>>>                     0x000000000052ef7c _bsd__start_set_nexus
>>>>>>>>>>>>                     0x000000000052ef7c       0x28
>>>>>>>>>>>> testsuite/telnetd01/test_main.o
>>>>>>>>>>>>                     0x000000000052efa4        0x0
>>>>>>>>>>>>                     0x000000000052efa4 _bsd__stop_set_nexus
>>>>>>>>>>>> The  .rtemsroset.bsd.nexus.content section must be non-empty.
>>>>>>>>>>>> On 27/06/15 16:39, Yurii Shevtsov wrote:
>>>>>>>>>>>>> Any ideas? Maybe I did some typo? Maybe you can compile and
>>> try it
>>>>>>>>>>>>> in
>>>>>>>>>>>>> qemu?
>>>>>>>>>>>>> 2015-06-26 17:05 GMT+03:00 Yurii
>>>>>>>>>>>>>> 2015-06-25 16:00 GMT+03:00 Sebastian Huber
>>>>>>>>>>>>>>> I would set a break point to nexus_probe(). In this loop
>>>>>>>>>>>>>>>          SET_FOREACH(nd, nexus) {
>>>>>>>>>>>>>>>              device_add_child(dev, nd->name, nd->unit);
>>>>>>>>>>>>>>> your device must get added. I would also set break points
>>> to the
>>>>>>>>>>>>>>> probe
>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>> attach functions of your device.
>>>>>>>>>>>>>> Added printfs()
>>>>>>>>>>>>>>          printf("before setforeach\n");
>>>>>>>>>>>>>>              printf("setforeach: %s\n", nd->name);
>>>>>>>>>>>>>> Got only 'before setforeach' in console. So it doesn't step
>>> into
>>>>>>>>>>>>>> loop.
>>>>>>>>>>>>>> Any ideas? Also I already had printfs in my driver's probe
>>> and
>>>>>>>>>>>>>> attach,
>>>>>>>>>>>>>> also got no output.
>>>>>>>>>>>>>>> On 25/06/15 14:50, Yurii Shevtsov wrote:
>>>>>>>>>>>>>>>> This is ping message, with small update: the problem is
>>> not on
>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>> linking stage, driver is linked to testsuite (checked
>>> with
>>>>>>>>>>>>>>>> objdump)
>>>>>>>>>>>>>>>> 2015-06-21 17:57 GMT+03:00 Yurii
>>>>>>>>>>>>>>>>> Hello)
>>>>>>>>>>>>>>>>> Now I have apps from libbsd testsuite running. But DWC
>>> OTG
>>>>>>>>>>>>>>>>> driver
>>>>>>>>>>>>>>>>> doesn't
>>>>>>>>>>>>>>>>> loads.
>>>>>>>>>>>>>>>>> I added this lines to init01/test_main.c:
>>>>>>>>>>>>>>>>> +SYSINIT_NEED_USB_CORE;
>>>>>>>>>>>>>>>>> +SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
>>>>>>>>>>>>>>>>> (I know it's bad hardcode)
>>>>>>>>>>>>>>>>> If I run it. I get only this:
>>>>>>>>>>>>>>>>>         nexus0:<RTEMS Nexus device>
>>>>>>>>>>>>>>>>>         devctl: +nexus0 at   on root0
>>>>>>>>>>>>>>>>>         devctl: !system=IFNET subsystem=lo0 type=ATTACH
>>>>>>>>>>>>>>>>> Of course, I modified
>>>>>>>>>>>>>>>>> rtemsbsd/include/machine/rtems-bsd-sysinit.h
>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>> rtemsbsd/include/bsp/nexus-devices.h (took vlues from
>>> working
>>>>>>>>>>>>>>>>> DTS)
>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>> did other nexus-related changes to drivers. You can find
>>>>>>>>>>>>>>>>> changes
>>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>>> my
>>>>>>>>>>>>>>>>> repo https://github.com/gtament/rtems-libbsd/
>>>>>>>>>>>>>>>>> So I need some kind of code review, please.
>>>>>>>>>>>>>>>>> P.S. All testsuites (netshell01, usb01) with shell hangs
>>>>>>>>>>>>>>>>> without
>>>>>>>>>>>>>>>>> any
>>>>>>>>>>>>>>>>> output.
>>>>>>>>>>>>>>>>> Thanks in advance!
>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>>>>>>>> Sebastian Huber, embedded brains GmbH
>>>>>>>>>>>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>>>>>>>>>>>> Phone   : +49 89 189 47 41-16
>>>>>>>>>>>>>>> Fax     : +49 89 189 47 41-09
>>>>>>>>>>>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>>>>>>>>>>>> PGP     : Public key available on request.
>>>>>>>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im
>>> Sinne des
>>>>>>>>>>>>>>> EHUG.
>>>>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>>> des
>>>>>>>>>>>> EHUG.
>>>>>>>>>> devel mailing list
>>>>>>>>>> devel at rtems.org
>>>>>>>>> -- Joel Sherrill
>>>>>>>>> Ask me about RTEMS: a free RTOS
>>>>>>>>> Support and Training Available
>>>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>> Support Available                (256) 722-9985
>> --joel
