GSoC 2015 RPi USB Support
    Yurii Shevtsov
    ungetch at gmail.com
    Thu Aug  6 21:41:04 UTC 2015
These macroses are placed here
https://github.com/gtament/rtems-libbsd/blob/cf3f0fcafef3bcb9b0ec80d8c57e1304689ebace/rtemsbsd/include/machine/rtems-bsd-sysinit.h
And of course I added proper lines to specific testsuites, like
init01. And IRC, without this macro driver just won't be linked
2015-08-07 0:34 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
> On 8/6/2015 4:29 PM, Yurii Shevtsov wrote:
>> Isn't this line enough?
>> SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus)
> I was looking in nexus-devices.h since that is BSP specific.
> I wasn't expecting a generic macro.
> But where is that referenced? That is a macro that somewhere
> should be referencing so it is expanded.
> I would expect to see
> below the nexus definition in nexus-devices.h.
> Anyway, it is never being expanded so that definition has no impact.
> Whether it will work and find the right bus, is another issue
> but it isn't putting code in for sure. :)
> I have the pc386 to the point where it the RTEMS nexus device
> is trying to find em on the legacy bus but it is configured
> as being on pci. Need to run down that or trick it to work.
> But the probe is working.
> --joel
>> 2015-08-07 0:23 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>> On 8/6/2015 4:16 PM, Yurii Shevtsov wrote:
>>>> 2015-08-07 0:08 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>> On August 6, 2015 3:57:40 PM CDT, Yurii Shevtsov <ungetch at gmail.com>
>>>>> wrote:
>>>>>> What do you mean by "getting pulled"?
>>>>> As I understood things, you had a linked executable but an empty
>>>>> section.
>>>>> Just curious if your devices were showing up at all.
>>>> Yes, exactly. If you mean is probe function being executed, the answer
>>>> is
>>>> ''no"
>>> You have to associate the drivers with a nexus bus.  Something like this
>>> SYSINIT_DRIVER_REFERENCE(mmc, dw_mmc);
>>> SYSINIT_DRIVER_REFERENCE(mmcsd, mmc);
>>> That's from the Altera Cyclone.
>>> You only configured a nexus device and didn't hang anything off it.
>>>>>> 2015-08-06 23:48 GMT+03:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>>> On 8/6/2015 3:42 PM, Yurii Shevtsov wrote:
>>>>>>>> 2015-08-06 23:36 GMT+03:00 Joel Sherrill
>>>>>>>>> On 8/6/2015 3:22 PM, Yurii Shevtsov wrote:
>>>>>>>>>> Ping! Any news?
>>>>>>>>> The people with experience with the libbsd code is quite small. :(
>>>>>>>>>> 2015-08-05 18:29 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>>>>>>>>>>> The problem is that rtemsroset.bsd.nexus.content doesn't exist in
>>>>>>>>>>> final elf. If I change driver's name in
>>>>>> RTEMS_BSD_DEFINE_NEXUS_DEVICE
>>>>>>>>>>> macro, linker will throw an error
>>>>>>>>>>> (.rtemsroset.bsd.nexus.content+0x10): undefined reference to
>>>>>> '%wrong
>>>>>>>>>>> driver's name%'. Otherwise with correct name - no
>>>>>> errors(warnings) and
>>>>>>>>>>> no nexus.content section. How can you explain this??
>>>>>>>>> The RTEMS_BSD_DEFINE_NEXUS_DEVICE() macro must reference a
>>>>>> bus/mexus,
>>>>>>>>> not a regular device driver. I would expect a nexus device for the
>>>>>> Pi
>>>>>>>>> to be in
>>>>>> https://github.com/freebsd/freebsd/tree/master/sys/arm/broadcom/bcm2835
>>>>>>>>> or pointed to by a file in there.
>>>>>>>>> Look at the configuration for the various bsps in nexus-devices.h
>>>>>> and
>>>>>>>>> then at the source the macros refer to.
>>>>>>>>> Raspberry Pi source will have to be imported from the FreeBSD tree.
>>>>>>>> Of course, I did it!)
>>>>>> https://github.com/gtament/rtems-libbsd/commit/cf3f0fcafef3bcb9b0ec80d8c57e1304689ebace
>>>>>>> Is bcm283x_dwcotg* getting pulled into your build?
>>>>>>>>>>> 2015-08-02 18:02 GMT+03:00 Joel Sherrill
>>>>>>>>>>>> On 08/01/2015 04:00 PM, Yurii Shevtsov wrote:
>>>>>>>>>>>>> During debugging of compiled Nexus module(driver) I found out
>>>>>> that
>>>>>>>>>>>>> content which suppose to be created in
>>>>>> RTEMS_BSD_DEFINE_SET(nexus,
>>>>>>>>>>>>> rtems_bsd_device) is empty, That should mean that either it is
>>>>>> not
>>>>>>>>>>>>> found or cannot be read. Please, let me know why empty content
>>>>>> is not
>>>>>>>>>>>>> create any error message and in what situation it can be empty.
>>>>>>>>>>>> Sebastian just added the pc386 to the nexus-devices file. Make
>>>>>> sure
>>>>>>>>>>>> the bsp.h is tripping the conditional logic in that file to get
>>>>>> the Pi
>>>>>>>>>>>> path as a minimum.
>>>>>>>>>>>> Then you are going to need to add the appropriate devices for Pi
>>>>>>>>>>>> USB.  If the Pi  doesn't have one of the standard USB
>>>>>> controllers,
>>>>>>>>>>>> then
>>>>>>>>>>>> you will have to import the source for it from FreeBSD.
>>>>>>>>>>>> The pc386 is stuck at the point where it detects the NIC
>>>>>> configured
>>>>>>>>>>>> but needs resources. I am going to try to debug that.
>>>>>>>>>>>>> 2015-06-29 19:50 GMT+03:00 Yurii Shevtsov<ungetch at gmail.com>:
>>>>>>>>>>>>>> So, it is empty.
>>>>>>>>>>>>>>       .rtemsroset.bsd.nexus.begin
>>>>>>>>>>>>>>                      0x001104bc        0x0
>>>>>>>>>>>>>> ./libbsd.a(rtems-bsd-nexus.c.16.o)
>>>>>>>>>>>>>>                      0x001104bc
>>>>>> _bsd__start_set_nexus
>>>>>>>>>>>>>>       .rtemsroset.bsd.nexus.end
>>>>>>>>>>>>>>                      0x001104bc        0x0
>>>>>>>>>>>>>>                      0x001104bc
>>>>>> _bsd__stop_set_nexus
>>>>>>>>>>>>>> What will be next step? My repo:
>>>>>>>>>>>>>> 2015-06-29 9:43 GMT+03:00 Sebastian
>>>>>>>>>>>>>> Huber<sebastian.huber at embedded-brains.de>:
>>>>>>>>>>>>>>> You can debug this issue on Qemu. The Nexus childes are
>>>>>> registered
>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>> a
>>>>>>>>>>>>>>> linker set, so I would consult the linker map file.  It
>>>>>> should look
>>>>>>>>>>>>>>> like
>>>>>>>>>>>>>>> this:
>>>>>>>>>>>>>>>                      0x000000000052ef7c        0x0
>>>>>>>>>>>>>>> libbsd.a(rtems-bsd-nexus.o)
>>>>>>>>>>>>>>>                      0x000000000052ef7c _bsd__start_set_nexus
>>>>>>>>>>>>>>>                      0x000000000052ef7c       0x28
>>>>>>>>>>>>>>> testsuite/telnetd01/test_main.o
>>>>>>>>>>>>>>>                      0x000000000052efa4        0x0
>>>>>>>>>>>>>>>                      0x000000000052efa4 _bsd__stop_set_nexus
>>>>>>>>>>>>>>> The  .rtemsroset.bsd.nexus.content section must be non-empty.
>>>>>>>>>>>>>>> On 27/06/15 16:39, Yurii Shevtsov wrote:
>>>>>>>>>>>>>>>> Any ideas? Maybe I did some typo? Maybe you can compile and
>>>>>> try it
>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>> qemu?
>>>>>>>>>>>>>>>> 2015-06-26 17:05 GMT+03:00 Yurii
>>>>>>>>>>>>>>>>> 2015-06-25 16:00 GMT+03:00 Sebastian Huber
>>>>>>>>>>>>>>>>>> I would set a break point to nexus_probe(). In this loop
>>>>>>>>>>>>>>>>>>           SET_FOREACH(nd, nexus) {
>>>>>>>>>>>>>>>>>>               device_add_child(dev, nd->name, nd->unit);
>>>>>>>>>>>>>>>>>> your device must get added. I would also set break points
>>>>>> to the
>>>>>>>>>>>>>>>>>> probe
>>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>>> attach functions of your device.
>>>>>>>>>>>>>>>>> Added printfs()
>>>>>>>>>>>>>>>>>           printf("before setforeach\n");
>>>>>>>>>>>>>>>>>               printf("setforeach: %s\n", nd->name);
>>>>>>>>>>>>>>>>> Got only 'before setforeach' in console. So it doesn't step
>>>>>> into
>>>>>>>>>>>>>>>>> loop.
>>>>>>>>>>>>>>>>> Any ideas? Also I already had printfs in my driver's probe
>>>>>> and
>>>>>>>>>>>>>>>>> attach,
>>>>>>>>>>>>>>>>> also got no output.
>>>>>>>>>>>>>>>>>> On 25/06/15 14:50, Yurii Shevtsov wrote:
>>>>>>>>>>>>>>>>>>> This is ping message, with small update: the problem is
>>>>>> not on
>>>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>>>> linking stage, driver is linked to testsuite (checked
>>>>>> with
>>>>>>>>>>>>>>>>>>> objdump)
>>>>>>>>>>>>>>>>>>> 2015-06-21 17:57 GMT+03:00 Yurii
>>>>>>>>>>>>>>>>>>>> Hello)
>>>>>>>>>>>>>>>>>>>> Now I have apps from libbsd testsuite running. But DWC
>>>>>> OTG
>>>>>>>>>>>>>>>>>>>> driver
>>>>>>>>>>>>>>>>>>>> doesn't
>>>>>>>>>>>>>>>>>>>> loads.
>>>>>>>>>>>>>>>>>>>> I added this lines to init01/test_main.c:
>>>>>>>>>>>>>>>>>>>> +SYSINIT_NEED_USB_CORE;
>>>>>>>>>>>>>>>>>>>> +SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
>>>>>>>>>>>>>>>>>>>> (I know it's bad hardcode)
>>>>>>>>>>>>>>>>>>>> If I run it. I get only this:
>>>>>>>>>>>>>>>>>>>>          nexus0:<RTEMS Nexus device>
>>>>>>>>>>>>>>>>>>>>          devctl: +nexus0 at   on root0
>>>>>>>>>>>>>>>>>>>>          devctl: !system=IFNET subsystem=lo0 type=ATTACH
>>>>>>>>>>>>>>>>>>>> Of course, I modified
>>>>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>>>>> rtemsbsd/include/bsp/nexus-devices.h (took vlues from
>>>>>> working
>>>>>>>>>>>>>>>>>>>> DTS)
>>>>>>>>>>>>>>>>>>>> and
>>>>>>>>>>>>>>>>>>>> did other nexus-related changes to drivers. You can find
>>>>>>>>>>>>>>>>>>>> changes
>>>>>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>>>>>> my
>>>>>>>>>>>>>>>>>>>> repo https://github.com/gtament/rtems-libbsd/
>>>>>>>>>>>>>>>>>>>> So I need some kind of code review, please.
>>>>>>>>>>>>>>>>>>>> P.S. All testsuites (netshell01, usb01) with shell hangs
>>>>>>>>>>>>>>>>>>>> without
>>>>>>>>>>>>>>>>>>>> any
>>>>>>>>>>>>>>>>>>>> output.
>>>>>>>>>>>>>>>>>>>> Thanks in advance!
>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>>>>>>>>>>> Sebastian Huber, embedded brains GmbH
>>>>>>>>>>>>>>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>>>>>>>>>>>>>>> Phone   : +49 89 189 47 41-16
>>>>>>>>>>>>>>>>>> Fax     : +49 89 189 47 41-09
>>>>>>>>>>>>>>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>>>>>>>>>>>>>>> PGP     : Public key available on request.
>>>>>>>>>>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im
>>>>>> Sinne des
>>>>>>>>>>>>>>>>>> EHUG.
>>>>>>>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>>>>>> des
>>>>>>>>>>>>>>> EHUG.
>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>> -- Joel Sherrill
>>>>>>>>>>>> Ask me about RTEMS: a free RTOS
>>>>>>>>>>>> Support and Training Available
>>>>>>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>>>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>>>>> Support Available                (256) 722-9985
>>>>> --joel
