xilinx microblaze
emanuel stiebler emu at e-bbes.com
Fri Aug 7 05:01:20 UTC 2015
Hi all,
should it still work, didn't see anything about it for a while on this
list, tried yesterday, and the source-builder failed in newlib:
microblaze-rtems4.11-ar rc ../libc.a *.o
microblaze-rtems4.11-ranlib libc.a
rm -rf tmp
make[8]: Leaving directory
'/cygdrive/d/_home/emu/RTEMS.Work/rtems-source-builder/rtems/build/microblaze-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-pc-cygwin-1/build/microblaze-rtems4.11/m/mh/le/newlib/libc'
Makefile:675: recipe for target 'all-recursive' failed
make[7]: Leaving directory
make[7]: *** [all-recursive] Error 1
Makefile:627: recipe for target 'all-recursive' failed
make[6]: *** [all-recursive] Error 1
make[6]: Leaving directory
'/cygdrive/d/_home/emu/RTEMS.Work/rtems-source-builder/rtems/build/microblaze-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-pc-cygwin-1/build/microblaze-rtems4.11/m/mh/le/newlib'
make[5]: *** [all] Error 2
Makefile:450: recipe for target 'all' failed
make[5]: Leaving directory
make[4]: *** [multi-do] Error 1
Makefile:1188: recipe for target 'multi-do' failed
make[4]: Leaving directory
'/cygdrive/d/_home/emu/RTEMS.Work/rtems-source-builder/rtems/build/microblaze-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-pc-cygwin-1/build/microblaze-rtems4.11/newlib'
make[3]: *** [all-multi] Error 2
Makefile:1104: recipe for target 'all-multi' failed
make[3]: Leaving directory
make[2]: *** [all] Error 2
make[2]: Leaving directory
Makefile:11086: recipe for target 'all-target-newlib' failed
make[1]: Leaving directory
'/cygdrive/d/_home/emu/RTEMS.Work/rtems-source-builder/rtems/build/microblaze-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-pc-cygwin-1/build'
make[1]: *** [all-target-newlib] Error 2
Makefile:866: recipe for target 'all' failed
make: *** [all] Error 2
shell cmd failed: sh -ex
/cygdrive/d/_home/emu/RTEMS.Work/rtems-source-builder/rtems/build/microblaze-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-pc-cygwin-1/doit
error: building
   See error report:
rsb-report-microblaze-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-pc-cygwin-1.txt
Build Set: Time 2:12:55.482808
