i386 build fail
Gedare Bloom gedare at gwu.edu
Fri Aug 7 19:25:27 UTC 2015
 This screenshot appears to show results from running apt.
What guide are you following to try to build rtems? The best guide is
the GSoC getting started guide on our Trac wiki, first you may want to
follow it exactly to build the sparc/sis, and then switch the
architecture with i386 and the bsp with pc386.
Gedare
On Fri, Aug 7, 2015 at 3:12 PM, punit vara <punitvara at gmail.com> wrote:
> I have tried to build rtems-i386 in my laptop .I am using Ubuntu 15.04
> 64-bit .I have tried 5-6 times but all times build fail error.So please help
> to fix this error.
> Please find the attachment of error screenshot
