SMP support for Raspberry Pi 2
Rohini Kulkarni
krohini1593 at gmail.com
Sun Aug 9 17:43:10 UTC 2015
There is no documentation or information from forums I can find to get a
lead. I suppose i will go ahead with mailboxes. Each core has 4 mailboxes,
usage being left to us. One of the mailboxes can be used here.
On Sun, Aug 9, 2015 at 2:28 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On August 8, 2015 3:17:01 PM CDT, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> >Can mailboxes be useful here? Nothing else that is coming to my mind
> They may be and I am seeing references to ARM's own mpcore which uses the
> GIC. This appears to be SOC specific but ARM has recommendations which may
> be followed by the SOC manufacturer
> >On Sun, Aug 9, 2015 at 1:44 AM, Rohini Kulkarni <krohini1593 at gmail.com>
> >wrote:
> >Hi,
> >I am stuck at how to set up IPI for Pi 2. This is a document I have
> >referred to get an idea of interrupts. Would be great to get some help
> >on how to proceed.
> >On Fri, Jul 31, 2015 at 7:33 PM, Joel Sherrill
> ><joel.sherrill at oarcorp.com> wrote:
> >On 7/31/2015 8:11 AM, Rohini Kulkarni wrote:
> >Hi,
> >How is the number of processors to be used for an application
> >specified?
> >The used count minimum of that supported in hardware and that
> >configured. How to specify the latter?
> https://docs.rtems.org/doc-current/share/rtems/html/c_user/Configuring-a-System-SMP-Specific-Configuration-Parameters.html#Configuring-a-System-SMP-Specific-Configuration-Parameters
> >and see the smptests. Many of which do specify the maximum.
> >Thanks.
> >On 29 Jul 2015 15:29, "Sebastian Huber"
> ><sebastian.huber at embedded-brains.de
> ><mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 29/07/15 11:52, Rohini Kulkarni wrote:
> >On Tue, Jul 28, 2015 at 12:24 PM, Sebastian Huber
> ><mailto:sebastian.huber at embedded-brains.de>>> wrote:
> > Hello Rohini,
> > please use the devel list.
> > On 28/07/15 07:41, Rohini Kulkarni wrote:
> > Hi,
> > I wish to understand where the interprocessor interrupts are
> > used during the boot process. During final initialization of
> > SMP I can see
> > rtems_interrupt_handler_install(
> > ARM_GIC_IRQ_SGI_0,
> > "IPI",
> > RTEMS_INTERRUPT_UNIQUE,
> > bsp_inter_processor_interrupt,
> > NULL
> > Raspberry Pi 2 does not have the generic interrupt controller.
> > Interrupt routing will have to be handled differently. So I
> > wish to understand how/ where it is used. I suppose this might
> > be the problem.
> > Sorry, that the documentation is so scattered. I think we should
> > move everything into the CPU Architecture Supplement. It would be
> > nice if you can help to improve the documentation since you have a
> > different view point.
> > You must install the IPI during the system initialization. It is
> > raised via the _CPU_SMP_Send_interrupt() function, for an example
> > see arm-a9mpcore-smp.c.
> >I could locate the function in arm-a9mpcore-smp.c. but it would be
> >helpful if I can know where this being called from, a deeper call
> >hierarchy, so that I can ascertain this is a problem. I can see a
> >Send_messgae function call this. But don't know where the send message
> >is being called from.
> >You can run one of the SMP tests on the realview_pbx_a9_qemu_smp BSP on
> >Qemu and set a break point to _CPU_SMP_Send_interrupt() if you want to
> >know how it is used.
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone : +49 89 189 47 41-16
> > Fax : +49 89 189 47 41-09
> >E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> >Joel Sherrill, Ph.D. Director of Research & Development
> >joel.sherrill at OARcorp.com On-Line Applications Research
> >Ask me about RTEMS: a free RTOS Huntsville AL 35805
> >Support Available (256) 722-9985
> >Rohini Kulkarni
> >Rohini Kulkarni
> --joel
Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150809/31cbeb32/attachment-0001.html>
