[PATCH 1/7] add libpng bset
YANG QIAO
yangqiao0505 at me.com
Mon Aug 10 12:48:21 UTC 2015
rtems/config/4.11/graphics/libpng.bset | 20 +++++++++
rtems/config/graphics/libpng-1.5.22-1.cfg | 22 ++++++++++
source-builder/config/libpng-1.cfg | 69 +++++++++++++++++++++++++++++++
3 files changed, 111 insertions(+)
create mode 100644 rtems/config/4.11/graphics/libpng.bset
create mode 100644 rtems/config/graphics/libpng-1.5.22-1.cfg
create mode 100644 source-builder/config/libpng-1.cfg
diff --git a/rtems/config/4.11/graphics/libpng.bset b/rtems/config/4.11/graphics/libpng.bset
new file mode 100644
index 0000000..4df0e03
--- /dev/null
+++ b/rtems/config/4.11/graphics/libpng.bset
@@ -0,0 +1,20 @@
+# Build set for libpng
+%define release 1
+# RTEMS Version
+%define rtems_version 4.11
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# Build libpng.
+graphics/libpng-1.5.22-1.cfg
diff --git a/rtems/config/graphics/libpng-1.5.22-1.cfg b/rtems/config/graphics/libpng-1.5.22-1.cfg
index 0000000..48313b7
--- /dev/null
+++ b/rtems/config/graphics/libpng-1.5.22-1.cfg
@@ -0,0 +1,22 @@
+# libpng 1.5.22
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# libpng Version
+%define libpng_version 1.5.22
+%define libpng_src_dir_revision 15
+%hash md5 libpng-%{libpng_version}.tar.gz 8d10c6267c8da60454ef703c4cb11876
+# libpng Build configuration
+%include %{_configdir}/libpng-1.cfg
diff --git a/source-builder/config/libpng-1.cfg b/source-builder/config/libpng-1.cfg
index 0000000..ef67f82
--- /dev/null
+++ b/source-builder/config/libpng-1.cfg
@@ -0,0 +1,69 @@
+# libpng
+# This configuration file configure's, make's and install's libpng.
+%define release 1
+%endif
+Name: libpng-v%{libpng_version}-%{_host}-%{release}
+Summary: libpng is the official PNG reference library
+Version: %{libpng_version}
+Release: %{release}
+URL: http://www.libpng.org/
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# libpng Source
+%source set libpng ftp://ftp.simplesystems.org/pub/libpng/png/src/libpng%{libpng_src_dir_revision}/libpng-%{libpng_version}.tar.gz
+# Prepare the source code.
+%prep
+ build_top=$(pwd)
+ source_dir_libpng="libpng-%{libpng_version}"
+ %source setup libpng -q -n libpng-%{libpng_version}
+ %patch setup libpng -p1
+ cd ${build_top}
+%build
+ build_top=$(pwd)
+ %{build_directory}
+ mkdir -p ${build_dir}
+ cd ${build_dir}
+ %{host_build_flags}
+ ../${source_dir_libpng}/configure \
+ --host=%{_host} \
+ --prefix=%{_prefix} \
+ --bindir=%{_bindir} \
+ --exec_prefix=%{_exec_prefix} \
+ --includedir=%{_includedir} \
+ --libdir=%{_libdir} \
+ --libexecdir=%{_libexecdir} \
+ --mandir=%{_mandir} \
+ --infodir=%{_infodir} \
+ --datadir=%{_datadir} \
+ --disable-shared
+ %{__make} %{?_smp_mflags} all
+ cd ${build_top}
+%install
+ build_top=$(pwd)
+ %{__rmdir} $SB_BUILD_ROOT
+ cd ${build_dir}
+ %{__make} DESTDIR=$SB_BUILD_ROOT install
+ cd ${build_top}
2.1.0
