[PATCH 4/7] add t1lib bset (patch url should be changed after it is merged into rtems git server)
YANG QIAO yangqiao0505 at me.com
Mon Aug 10 12:48:24 UTC 2015
 rtems/config/4.11/graphics/t1lib.bset   | 20 +++++++++
 rtems/config/graphics/t1lib-5.1.2-1.cfg | 21 +++++++++
 source-builder/config/t1lib-1.cfg       | 75 +++++++++++++++++++++++++++++++++
 3 files changed, 116 insertions(+)
 create mode 100644 rtems/config/4.11/graphics/t1lib.bset
 create mode 100644 rtems/config/graphics/t1lib-5.1.2-1.cfg
 create mode 100644 source-builder/config/t1lib-1.cfg
diff --git a/rtems/config/4.11/graphics/t1lib.bset b/rtems/config/4.11/graphics/t1lib.bset
new file mode 100644
index 0000000..63b4f73
--- /dev/null
+++ b/rtems/config/4.11/graphics/t1lib.bset
@@ -0,0 +1,20 @@
+# Build set for adobe type 1 library
+%define release 1
+# RTEMS Version
+%define rtems_version 4.11
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# Build t1lib.
+graphics/t1lib-5.1.2-1.cfg
diff --git a/rtems/config/graphics/t1lib-5.1.2-1.cfg b/rtems/config/graphics/t1lib-5.1.2-1.cfg
index 0000000..da18ba1
--- /dev/null
+++ b/rtems/config/graphics/t1lib-5.1.2-1.cfg
@@ -0,0 +1,21 @@
+# t1lib 5.1.2
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# t1lib Version
+%define t1lib_version 5.1.2
+%hash md5 t1lib-%{t1lib_version}.tar.gz a5629b56b93134377718009df1435f3c
+# t1lib Build configuration
+%include %{_configdir}/t1lib-1.cfg
diff --git a/source-builder/config/t1lib-1.cfg b/source-builder/config/t1lib-1.cfg
index 0000000..72913e1
--- /dev/null
+++ b/source-builder/config/t1lib-1.cfg
@@ -0,0 +1,75 @@
+# t1lib
+# This configuration file configure's, make's and install's t1lib.
+%define release 1
+%endif
+Name:      t1lib-v%{t1lib_version}-%{_host}-%{release}
+Summary:   t1lib is the official PNG reference library
+Version:   %{t1lib_version}
+Release:   %{release}
+URL:     http://www.t1lib.org/
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# t1lib Source
+%source set t1lib ftp://ftp.netbsd.org/pub/pkgsrc/distfiles/t1lib-%{t1lib_version}.tar.gz
+%patch add t1lib https://raw.githubusercontent.com/yangqiao/rtems-tools/graphics/tools/4.11/t1lib/t1lib-5.1.2.diff
+%hash md5 t1lib-5.1.2.diff 196b0e39e36cab5afc6c5c280dcbe9bc
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  source_dir_t1lib="t1lib-%{t1lib_version}"
+  %source setup t1lib -q -n t1lib-%{t1lib_version}
+  %patch setup t1lib -p1
+  cd ${build_top}
+# Build the source code.
+# The configure should be run in the source dir
+%build
+  build_top=$(pwd)
+  %{build_directory}
+  cd ${source_dir_t1lib}
+  %{host_build_flags}
+   ./configure \
+    --host=%{_host} \
+    --prefix=%{_prefix} \
+    --bindir=%{_bindir} \
+    --exec_prefix=%{_exec_prefix} \
+    --includedir=%{_includedir} \
+    --libdir=%{_libdir} \
+    --libexecdir=%{_libexecdir} \
+    --mandir=%{_mandir} \
+    --infodir=%{_infodir} \
+    --datadir=%{_datadir} \
+    --disable-shared \
+    --without-athena --without-x
+  %{__make} %{?_smp_mflags} without_doc
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  %{__rmdir} $SB_BUILD_ROOT
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  cd ${build_top}
2.1.0
