[PATCH 1/2] add t1lib patch
Mon Aug 10 17:14:58 UTC 2015
ping Pavel..
how do these look?
On 8/10/2015 7:48 AM, YANG QIAO wrote:
> From: YANG Qiao <yangqiao0505 at me.com>
>   tools/4.11/t1lib/t1lib-5.1.2.diff | 15 +++++++++++++++
>   1 file changed, 15 insertions(+)
>   create mode 100644 tools/4.11/t1lib/t1lib-5.1.2.diff
> diff --git a/tools/4.11/t1lib/t1lib-5.1.2.diff b/tools/4.11/t1lib/t1lib-5.1.2.diff
> new file mode 100644
> index 0000000..5e27472
> --- /dev/null
> +++ b/tools/4.11/t1lib/t1lib-5.1.2.diff
> @@ -0,0 +1,15 @@
> +--- t1lib-5.1.2.orig/configure  2015-06-28 23:12:59.394297125 +0200
> ++++ t1lib-5.1.2/configure 2015-06-28 23:15:44.066290147 +0200
> +@@ -24758,11 +24758,7 @@
> +   echo $ECHO_N "(cached) $ECHO_C" >&6
> + else
> +   if test "$cross_compiling" = yes; then
> +-  { { echo "$as_me:$LINENO: error: cannot run test program while cross compiling
> +-See \`config.log' for more details." >&5
> +-echo "$as_me: error: cannot run test program while cross compiling
> +-See \`config.log' for more details." >&2;}
> +-   { (exit 1); exit 1; }; }
> ++  ac_64bit_type="<none>"
> + else
> +   cat >conftest.$ac_ext <<_ACEOF
> + /* confdefs.h.  */
