[PATCH] GSoC: Cache configurations Raspberry Pi 2 support
Gedare Bloom gedare at gwu.edu
Tue Aug 11 13:59:12 UTC 2015
Yeah until you or someone can figure out how to get the .ARM.exidx
section from being placed in the .bss, a quick work-around would be to
provide an alternate code to clear the bss that does something like...
memset(bsp_section_bss_begin, 0, __exidx_start - bsp_section_bss_begin);
memset(__exidx_start, 0, bsp_section_bss_end);
On Tue, Aug 11, 2015 at 9:32 AM, Rohini Kulkarni <krohini1593 at gmail.com> wrote:
> OK! So is there any immediate solution which can be tried?
> On Tue, Aug 11, 2015 at 6:32 PM, Gedare Bloom <gedare at gwu.edu> wrote:
>> I can see the following pertinent information:
>> [15] .bss              NOBITS          001156e0 0a8fd8 00fab0 00  WA  0
>> 0 32
>> The bss section starts at 0x1156e0, has size 0xfab0, and is writeable.
>> In the symbol table we can see:
>>   7825: 001156e0     0 NOTYPE  GLOBAL DEFAULT   15 bsp_section_bss_begin
>> The bsp_section_bss_begin variable has value 0x1156e0, this is good.
>>  8729: 0000fab0     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_bss_size
>> The bsp_section_bss_size is 0xfab0, which is also good.
>> Looking at the segments I see one possible oddity. Look at the first and
>> last
>> Type           Offset   VirtAddr   PhysAddr   FileSiz MemSiz  Flg Align
>> EXIDX          0x0a3fb8 0x001106b8 0x001106b8 0x00008 0x00008 R   0x4
>> LOAD           0x093900 0x00100000 0x00100000 0x156d8 0x7efc000 RW  0x20
>> The first one starts inside of the second! This could well be the
>> reason for your problem. The .ARM.exidx section is being define
>> read-only, and is being put into a segment that overlaps with the
>> segment that catches most of the RW memory.
>> Gedare
>> On Mon, Aug 10, 2015 at 4:23 PM, Rohini Kulkarni <krohini1593 at gmail.com>
>> wrote:
>> > I did a readelf on the rki elf. I have attached the file. Is this
>> > information helping in anyway?
>> > On Wed, Aug 5, 2015 at 9:16 PM, Gedare Bloom <gedare at gwu.edu> wrote:
>> >> In arm/shared/startup/linkcmds.base these barriers are used to add
>> >> gaps in the memory layout at link-time to accommodate for the size
>> >> requirements of the MMU. xbarrier aligns the executable region,
>> >> robarrier aligns the read-only memory, and rwbarrier aligns the
>> >> read-write memory.
>> >> On Tue, Aug 4, 2015 at 6:23 PM, Rohini Kulkarni <krohini1593 at gmail.com>
>> >> wrote:
>> >> > On Wed, Aug 5, 2015 at 1:47 AM, Gedare Bloom <gedare at gwu.edu> wrote:
>> >> >> On Tue, Aug 4, 2015 at 2:18 PM, Rohini Kulkarni
>> >> >> wrote:
>> >> >> > On Tue, Jul 28, 2015 at 5:51 AM, Pavel Pisa
>> >> >> > <ppisa4lists at pikron.com>
>> >> >> > wrote:
>> >> >> >> Hello Rohini and Gedare,
>> >> >> >> On Friday 24 of July 2015 15:33:03 Gedare Bloom wrote:
>> >> >> >> > What are the values of bsp_section_bss_begin, and
>> >> >> >> > bsp_section_bss_size?
>> >> >> >> > Apparently, the memset is trying to write into the .text (code)
>> >> >> >> > section, which is a very bad thing to do indeed.
>> >> >> >> Qiao Yang in RPi 1 BSP now works in the similar
>> >> >> >> area to enable right graphic memory mapping.
>> >> >> >> So my guess is that there could be problem caused
>> >> >> >> by used MMU mode granularity, which is is 1 MB so
>> >> >> >> if RO and RW sections are present in the same 1MB
>> >> >> >> aligned block ten there can be problem. It depends
>> >> >> >> which section is filled the first. If data and then
>> >> >> >> text (RO) the troubles begin. If the order is vice
>> >> >> >> versa then some part of text can be RW instead of RO,
>> >> >> >> but it should work and cache should not be a problem.
>> >> >> >> But I have not dig into this case too much.
>> >> >> >> Only short glimpse.
>> >> >> >> One option is to define 1 MB alignment between text
>> >> >> >> ad data for RPi case. There is quite a lot of memory
>> >> >> >> when compared to most RTEMS embedded targets to the
>> >> >> >> waste is not so important.
>> >> >> > I didn't quite get what this means. I have no clue on how to
>> >> >> > proceed
>> >> >> > with
>> >> >> > this.
>> >> >> The MMU defines memory regions in 1MB chunks. Each chunk can have
>> >> >> its
>> >> >> own permissions (read-only, or read-write) set. If the .text and
>> >> >> .data
>> >> >> (or some other section) overlaps in the same 1MB chunk, and the
>> >> >> wrong
>> >> >> permission gets set, then there can be a problem e.g. part of .data
>> >> >> might be RO or part of .text might be RW.
>> >> >> Did you try the code Sebastian posted? to change the robarrier to
>> >> >> rwbarrier?
>> >> > What exactly are these barriers?
>> >> >> Gedare
>> >> >> >> Best wishes,
>> >> >> >>               Pavel
>> >> >> >> On Friday 24 of July 2015 21:55:00 Rohini Kulkarni wrote:
>> >> >> >> > Hi,
>> >> >> >> > I have attached the report containing outputs of
>> >> >> >> > arm-rtems4.11-size
>> >> >> >> > and
>> >> >> >> > arm-rtems4.11-nm -S.
>> >> >> >> > From arm-rtems4.11-nm -S I don't see how memset() is accessing
>> >> >> >> > .text
>> >> >> >> > section. The start and end values for both are not overlapping.
>> >> >> >> > On Fri, Jul 24, 2015 at 7:03 PM, Gedare Bloom <gedare at gwu.edu>
>> >> >> >> > wrote:
>> >> >> >> > > On Fri, Jul 24, 2015 at 3:30 AM, Rohini Kulkarni
>> >> >> >> > > wrote:
>> >> >> >> > > > On 24 Jul 2015 12:35, "Sebastian Huber" <
>> >> >> >> > > sebastian.huber at embedded-brains.de>
>> >> >> >> > > > wrote:
>> >> >> >> > > >> On 23/07/15 23:24, Rohini Kulkarni wrote:
>> >> >> >> > > >>> I could finally get back to this issue. I used Pi 1 for
>> >> >> >> > > >>> debugging,
>> >> >> >> > > >>> but the reason for this problem will apply to Pi 2 also.
>> >> >> >> > > >>> With text section set to ARMV7_MMU_CODE_CACHED ( which
>> >> >> >> > > >>> implies
>> >> >> >> > > >>> read
>> >> >> >> > > only)
>> >> >> >> > > >>> , a data abort exception occurs with memset() inside
>> >> >> >> > > bsp_start_clear_bss()
>> >> >> >> > > >>> function. An illegal write access to an address according
>> >> >> >> > > >>> to
>> >> >> >> > > >>> me.
>> >> >> >> > > >> Which exception and which address? Something is not
>> >> >> >> > > >> working
>> >> >> >> > > >> here.
>> >> >> >> > > > This is a part of the debugging output. When I used
>> >> >> >> > > ARMV7_MMU_CODE_CACHED.
>> >> >> >> > > > (gdb) s
>> >> >> >> > > > bsp_start_clear_bss ()
>> >> >> >> > > >     at
>> >> >> >> > > > ../../../../../.././raspberrypi/lib/include/bsp/start.h:126
>> >> >> >> > > > 126      memset(bsp_section_bss_begin, 0, (size_t)
>> >> >> >> > > > bsp_section_bss_size);
>> >> >> >> > > (code)
>> >> >> >> > > > (gdb) s
>> >> >> >> > > > memset (m=0x1157e0, c=0, n=64176)
>> >> >> >> > > >     at
>> >> >> >> > > > ../../../../../gcc-4.9.2/newlib/libc/string/memset.c:59
>> >> >> >> > > > 59    ../../../../../gcc-4.9.2/newlib/libc/string/memset.c:
>> >> >> >> > > > No
>> >> >> >> > > > such
>> >> >> >> > > > file
>> >> >> >> > > or
>> >> >> >> > > > directory.
>> >> >> >> > > > (gdb) s
>> >> >> >> > > > 49    in
>> >> >> >> > > > (gdb) s
>> >> >> >> > > > _ARMV4_Exception_data_abort_default ()
>> >> >> >> > > >     at
>> >> >> >> > > ../../../../../../../../rtems-local/rtems/c/src/../../cpukit/score/cpu/ar
>> >> >> >> > >m/armv4-exception-default.S:71
>> >> >> >> > > > 71        sub    sp, #MORE_CONTEXT_SIZE
>> >> >> >> > > > When I set text section flag to ARMV7_MMU_READ_WRITE, the
>> >> >> >> > > > system
>> >> >> >> > > > starts
>> >> >> >> > > > successfully.
>> >> >> >> > > >> Sebastian Huber, embedded brains GmbH
>> >> >> >> > > >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> >> >> >> > > >> Phone   : +49 89 189 47 41-16
>> >> >> >> > > >> Fax     : +49 89 189 47 41-09
>> >> >> >> > > >> E-Mail  : sebastian.huber at embedded-brains.de
>> >> >> >> > > >> PGP     : Public key available on request.
>> >> >> >> > > >> Diese Nachricht ist keine geschäftliche Mitteilung im
>> >> >> >> > > >> Sinne
>> >> >> >> > > >> des
>> >> >> >> > > >> EHUG.
>> >> >> >> > > > _______________________________________________
>> >> >> >> > > > devel mailing list
>> >> >> >> > > > devel at rtems.org
>> >> >> >> > > > http://lists.rtems.org/mailman/listinfo/devel
>> >> >> > Rohini Kulkarni
>> >> >> > devel mailing list
>> >> >> > devel at rtems.org
>> >> > Rohini Kulkarni
>> > Rohini Kulkarni
>> > devel mailing list
>> > devel at rtems.org
> Rohini Kulkarni
