Fwd: SMP support for Raspberry Pi 2
Rohini Kulkarni krohini1593 at gmail.com
Tue Aug 11 19:06:12 UTC 2015
Hi,
I would have to register the related mailbox interrupt and associate it
with a handler that should be same as
_SMP_Inter_processor_interrupt_handler(). Am I right?
>From where can I get a reference of how to do this?
On 11 Aug 2015 00:41, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
> The source for the CPU supplement is in doc/cpu_supplement in
> the RTEMS tree.
> I do not know when the latest online was built so reading it
> there is probably safest.
> To build it, you will likely have to install some texinfo and
> texlive tools.
> cd $r/doc
> ../bootstrap
> cd ../..
> mkdir b-doc
> cd b-doc
> $r/doc/configure --enable-maintainer-mode \
>   --prefix=DIRECTORY
> make
> make install
> That should be similar to how it is built.
> --joel
> On 8/10/2015 1:35 PM, Rohini Kulkarni wrote:
>> The documentation that Sebastian was referring to.
>> On Tue, Jul 28, 2015 at 12:24 PM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de <mailto:
>> sebastian.huber at embedded-brains.de>> wrote:
>>     Hello Rohini,
>>     please use the devel list.
>>     On 28/07/15 07:41, Rohini Kulkarni wrote:
>>         Hi,
>>         I wish to understand where the interprocessor interrupts are used
>> during the boot process. During final initialization of SMP I can see
>>         rtems_interrupt_handler_install(
>>                ARM_GIC_IRQ_SGI_0,
>>                "IPI",
>>                RTEMS_INTERRUPT_UNIQUE,
>>                bsp_inter_processor_interrupt,
>>                NULL
>>         Raspberry Pi 2 does not have the generic interrupt controller.
>> Interrupt routing will have to be handled differently. So I wish to
>> understand how/ where it is used. I suppose this might be the problem.
>>     Sorry, that the documentation is so scattered.  I think we should
>> move everything into the CPU Architecture Supplement. It would be nice if
>> you can help to improve the documentation since you have a different view
>> point.
>> What is the CPU Architecture Supplement?
>>     You must install the IPI during the system initialization. It is
>> raised via the _CPU_SMP_Send_interrupt() function, for an example see
>> arm-a9mpcore-smp.c.
>>         Thanks.
>>         On Wed, Jul 22, 2015 at 7:08 PM, Rohini Kulkarni <
>> krohini1593 at gmail.com <mailto:krohini1593 at gmail.com> <mailto:
>> krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>>> wrote:
>>              Ok. Qemu suggestion seems helpful for the cache configuration
>>              issue though. I am trying with Pi 1.
>>              Thanks.
>>              On 22 Jul 2015 18:59, "Sebastian Huber"
>>              <sebastian.huber at embedded-brains.de <mailto:
>>              <mailto:sebastian.huber at embedded-brains.de <mailto:
>> sebastian.huber at embedded-brains.de>>> wrote:
>>                  Sorry, I cannot help you here since I never worked with a
>>                  Raspberry Pi.
>>                  --         Sebastian Huber, embedded brains GmbH
>>                  Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>                  Phone   : +49 89 189 47 41-16
>>                  Fax     : +49 89 189 47 41-09
>>                  E-Mail  : sebastian.huber at embedded-brains.de <mailto:
>>                  PGP     : Public key available on request.
>>                  Diese Nachricht ist keine geschäftliche Mitteilung im
>> Sinne
>>                  des EHUG.
>>         Rohini Kulkarni
>>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> Rohini Kulkarni
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150812/3e48ce8b/attachment.html>
