Fwd: Re: [PATCH] GSoC: Cache configurations Raspberry Pi 2 support
Rohini Kulkarni
krohini1593 at gmail.com
Tue Aug 11 20:02:50 UTC 2015
Yes I have tried this. Didn't work out :(
On 11 Aug 2015 19:56, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
> Hi
> Has this been tried?
> -------- Forwarded Message --------
> Subject: Re: [PATCH] GSoC: Cache configurations Raspberry Pi 2 support
> Date: Tue, 28 Jul 2015 01:57:44 -0500
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> To: Rohini Kulkarni <krohini1593 at gmail.com>, Gedare Bloom <gedare at gwu.edu>
> CC: rtems-devel at rtems.org <devel at rtems.org>
> On 24/07/15 21:55, Rohini Kulkarni wrote:
>> Hi,
>> I have attached the report containing outputs of arm-rtems4.11-size
>> and arm-rtems4.11-nm -S.
>> From arm-rtems4.11-nm -S I don't see how memset() is accessing .text
>> section. The start and end values for both are not overlapping.
> Maybe this patch helps:
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
> b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
> index f1ad11c..f3b6232 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
> @@ -62,7 +62,8 @@ REGION_ALIAS ("REGION_NOCACHE_LOAD", RAM);
> bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size
> : 4096;
> bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size
> : 1024;
> -bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ?
> bsp_section_robarrier_align : 1M;
> +bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ?
> bsp_section_rwbarrier_align : 1M;
> bsp_translation_table_base = ORIGIN (RAM_MMU);
> INCLUDE linkcmds.armv4
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150812/48b098db/attachment-0001.html>
