[PATCH 1/1] add t1lib patch
Wed Aug 12 14:00:35 UTC 2015
On 8/12/2015 8:18 AM, QIAO YANG wrote:
> Hi,
> So here I patch the configure.in file instead of its output. If this one is good to go, I'll send you the two other patches for microwindows-bset and t1lib-bset , with its' correct patch urls.
The patch has to include the source (configure.in) and generated
file (configure). Once the patch is applied, the configure script
should match what would be generated but the end user is not expected
to be able to generate the configure script.
Include both files and ensure the configure is actually generated
from the latest configure.in.
> Best wishes
> On Aug 12, 2015, at 02:16 AM, YANG QIAO <yangqiao0505 at me.com> wrote:
>> From: YANG Qiao <yangqiao0505 at me.com <mailto:yangqiao0505 at me.com>>
>> tools/4.11/t1lib/t1lib-5.1.2.diff | 58 +++++++++++++++++++++++++++++++++++++++
>> 1 file changed, 58 insertions(+)
>> create mode 100644 tools/4.11/t1lib/t1lib-5.1.2.diff
>> diff --git a/tools/4.11/t1lib/t1lib-5.1.2.diff b/tools/4.11/t1lib/t1lib-5.1.2.diff
>> new file mode 100644
>> index 0000000..1c59e2b
>> --- /dev/null
>> +++ b/tools/4.11/t1lib/t1lib-5.1.2.diff
>> @@ -0,0 +1,58 @@
>> +--- t1lib-5.1.2.orig/configure.in 2015-08-12 14:35:01.064674452 +0200
>> ++++ t1lib-5.1.2/configure.in 2015-08-12 14:35:05.148674279 +0200
>> +@@ -225,14 +225,52 @@
>> + dnl **** Check which ANSI integer type is 64 bit
>> +-AC_CACHE_CHECK( "which ANSI integer type is 64 bit", ac_64bit_type,
>> +- AC_TRY_RUN([
>> ++echo $ECHO_N "checking \"which ANSI integer type is 64 bit\"... $ECHO_C" >&6
>> ++if test "${ac_64bit_type+set}" = set; then
>> ++ echo $ECHO_N "(cached) $ECHO_C" >&6
>> ++else
>> ++ if test "$cross_compiling" = yes; then
>> ++ ac_64bit_type="<none>"
>> ++else
>> ++ cat >conftest.$ac_ext <<_ACEOF
>> ++/* confdefs.h. */
>> ++_ACEOF
>> ++cat confdefs.h >>conftest.$ac_ext
>> ++cat >>conftest.$ac_ext <<_ACEOF
>> ++/* end confdefs.h. */
>> + int main(void) {
>> + if (sizeof(long)==8)
>> + return(0);
>> + else
>> + return(1);
>> +-}], ac_64bit_type="long", ac_64bit_type="<none>"))
>> ++_ACEOF
>> ++rm -f conftest$ac_exeext
>> ++if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
>> ++ (eval $ac_link) 2>&5
>> ++ ac_status=$?
>> ++ echo "$as_me:$LINENO: \$? = $ac_status" >&5
>> ++ (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
>> ++ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
>> ++ (eval $ac_try) 2>&5
>> ++ ac_status=$?
>> ++ (exit $ac_status); }; }; then
>> ++ ac_64bit_type="long"
>> ++else
>> ++ echo "$as_me: program exited with status $ac_status" >&5
>> ++echo "$as_me: failed program was:" >&5
>> ++sed 's/^/| /' conftest.$ac_ext >&5
>> ++( exit $ac_status )
>> ++ac_64bit_type="<none>"
>> ++fi
>> ++rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
>> ++fi
>> ++fi
>> ++echo "$as_me:$LINENO: result: $ac_64bit_type" >&5
>> ++echo "${ECHO_T}$ac_64bit_type" >&6
>> + if test "$ac_64bit_type" = "long"
>> + then
>> + T1_AA_TYPE64="-DT1_AA_TYPE64=long"
>> 2.1.0
