Uniprocessor implementation of nested mutex problem of priority inversion.
Thu Aug 13 12:43:11 UTC 2015
Saurabh,
Please pull from rtems.git again, create a new branch from 'master',
and apply your changes to the branch. It's too hard to review code
that is not all by itself on a branch.
Gedare
On Thu, Aug 13, 2015 at 5:28 AM, Saurabh Gadia <gadia at usc.edu> wrote:
> Hi,
> I have implemented uniprocessor model of nested mutex problem in rtems. its
> still in basic form. I tried to multiplex it with the existing solution but
> was finding hard time. To push ahead, I decided to have separate functions
> for uniprocessor and SMP(kept default behavior) and with your review
> comments will know what to do. Following is the link for the git repo:
> https://github.com/saurabhgadia4/rtems/commits/master and its JPF branch:
> https://github.com/saurabhgadia4/lock-model/blob/uniproc-new1/rtems/Mutex.java
> I have also tested spsem01, 02, 03 test cases. Following are the links for
> the test case results which states output before solution and after applying
> the solution. I am still not getting whether my code is passing spsem03 test
> or not. How can I verify that?
> Test Case Link:
> https://drive.google.com/folderview?id=0B44HRKVuGCkFfnFDVmxqQzZZUzljNUg4YmVPZmEybEp2Q0NNclpvS2FvemZ4Tm5Xa19nemM&usp=sharing
> Thanks,
> Saurabh Gadia
